Old Feb 11, 2013, 09:56 AM
steeg is offline
Find More Posts by steeg
United States, CA, Costa Mesa
Joined Oct 2009
Question
hoywire wire query
will type 304 stainless steel spring tmper .012 wire
work in a hotwire foam cutting setup?
i can get it easy from mcmastercarr
steve
steeg is offline Find More Posts by steeg
Old Feb 11, 2013, 10:44 AM
David Forbes is offline
Find More Posts by David Forbes
David Forbes's Avatar
United States, FL, Gainesville
Joined Dec 2005
Stainless fishing leader works great, available in lots of guages. Malin Hardwire is one brand, try your local bait shop.
Dave
David Forbes is offline Find More Posts by David Forbes
Old Feb 11, 2013, 11:50 AM
MarkRebuck is offline
Find More Posts by MarkRebuck
Joined Oct 2006
Stainless steel wire, 0.012 inch diameter will work fine. I use 0.012 inch stainless steel leader wire which I picked up at a local outdoor supply store.
http://www.rcgroups.com/forums/showp...8&postcount=22 probably answers every question a person could have about cutting foam with a hot wire. If you spend 10 minutes or so reading that post, you'll understand the tradeoffs with going thicker/thinner.
Foam choice, wire choice, bow length, bow tension, length of cut, and power supply voltage/current all combine to effect the quality of your cuts. If you change any one of those variables, you'll have to adjust something else to get the results you want. The good news is that there is a huge range of perfectly acceptable options for each variable.
MarkRebuck is offline Find More Posts by MarkRebuck
Old Feb 14, 2013, 03:15 PM
RWCLOUD is offline
Find More Posts by RWCLOUD
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
Mark, thats a very good link! Thanks for posting it.
Blue Skies..........................Tim
RWCLOUD is offline Find More Posts by RWCLOUD
Discussion DX8 TX Owners, DSMX query mts247 Australia 14 Feb 10, 2013 07:44 AM
Sold Servo wire crimpers, terminals and wire. gravityking Aircraft - General - Miscellaneous (FS/W) 2 Feb 09, 2013 11:15 PM
Discussion Associate Membership Query systemspeciali Royal Air Force Model Aircraft Association (RAFMAA) 1 Feb 07, 2013 12:45 AM
Discussion DX5e query PETERRAKE Scratchbuilt Indoor and Micro Models 23 Jan 12, 2013 04:13 AM
Wires Wires Wires Everywhere fly4fun Foamies (Kits) 18 Dec 10, 2004 09:30 PM
