Old Mar 15, 2015, 06:52 PM
Jim409 is offline
Find More Posts by Jim409
United States, NE, Grand Island
Joined Dec 2009
My Hadron flew into the ground on a hand launce and I can't find the prop/collet that went on the motor shaft.
I see Tower Hobbies have collets (Great Plains) but I have no idea what size I need or any place else to order one.
Jim
Jim409 is offline Find More Posts by Jim409
Old Mar 16, 2015, 08:04 PM
Jim409 is offline
Joined Dec 2009
Found what I needed
Jim
Old Mar 17, 2015, 10:36 AM
Dadawada is offline
Find More Posts by Dadawada
Dadawada's Avatar
United States, NC, Cary
Joined May 2014
New Launch Method
Found a new launch method that has worked flawlessly.
There is no need to "throw" the plane at all. All I do now is go full throttle and then holding the plane at a slight nose high angle I just sort of toss it up sort of like I would toss a ball into a target like a trash can. It doesn't even have to be hard. Just sorta hold it by the hand grips underneath, go full throttle, and toss it like you would a ball overhand.
The plane will launch smoothly into a powered glide and build speed as it climbs...piece of cake.
Dadawada is offline Find More Posts by Dadawada
Old Mar 17, 2015, 11:13 AM
Fentonflyers is offline
Find More Posts by Fentonflyers
United States, MO, Fenton
Joined Jan 2012
Just make sure to follow through or you will be on the way to the ER...
Fentonflyers is offline Find More Posts by Fentonflyers
Old Apr 05, 2015, 11:02 PM
Deadstick 8409 is offline
Find More Posts by Deadstick 8409
Deadstick 8409's Avatar
Joined May 2010
Originally Posted by Unisolblade View Post
Well first 2 launches were perfectly fine. The third launch cut me 3 times preaty bad which got stichted at the hospital, my hand litterly pulverized the prop too
The worst thing is at least 2 weeks no flying
Sorry to hear mate!
I have not flown mine yet, waiting for my afromini fc board.
Is it possible to launch no power and then hit it?
Deadstick 8409 is offline Find More Posts by Deadstick 8409
Old Apr 11, 2015, 09:20 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
KCinNC's Avatar
United States, NC, Mooresville
Joined Aug 2007
Originally Posted by Deadstick 8409 View Post
Sorry to hear mate!
this thing is on the heavyside....so you need some good air under it to make sure it stays in the air. a bungee or catapult launcher would probably work
KCinNC is offline Find More Posts by KCinNC
Old Apr 12, 2015, 06:48 AM
doug.wagner is offline
Find More Posts by doug.wagner
I can fix that!
doug.wagner's Avatar
United States, ME, Bangor
Joined Jul 2011
Sorry to hear mate!
I've had a hard time coordinating that when flying by myself, but when flying with my buddy, it's the only way I'll do it. I wait until the plane has left his hand, and then hit full throttle.
I may take a chance with my fingers, but I won't with anyone else's.
doug.wagner is offline Find More Posts by doug.wagner
Old May 04, 2015, 10:49 PM
randynsaudi is offline
Find More Posts by randynsaudi
randynsaudi's Avatar
United States, LA, Blanchard
Joined Jan 2006
myself i grip mine on the top and give it a underhand toss
randynsaudi is offline Find More Posts by randynsaudi
Old May 25, 2015, 09:47 AM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
tower hobbies has a sale going on ,I just picked one up for 129.00 shipped , hurry sale ends soon. my apologize if this is considered spam. I do not work for them . I just wanted to share the savings for those interested in a spare or new one
cheers
THESANDMAN is offline Find More Posts by THESANDMAN
Old May 25, 2015, 09:50 AM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Wow, that's a great deal on a fun to fly plane
Sammy70 is offline Find More Posts by Sammy70
Old May 25, 2015, 10:11 AM
Joined May 2010
It is a fun airplane to FPV. With a very light set up it is a easy plane to hand launch. I removed the rudder servo and thrust servo, put in a gps antenna and flight control board (afro mini naze32, 1.7 grams), RMRC micro cam, 2200mah 3 cell, and it is very light. It can actually fly fairly slow set like this.
Old May 25, 2015, 12:31 PM
THESANDMAN's Avatar
Joined Oct 2010
im planning on setting mine up as a bank and yak ,no rudder or thrust servos. so it should save some weight .
Old May 31, 2015, 02:44 PM
THESANDMAN's Avatar
Joined Oct 2010
Originally Posted by KRProton View Post
Saw this talk of ESC, props, etc. and thought I'd chime in just for fun.
We didn't size the prop to the ESC. We sized the prop to the motor, then the ESC to the two.
At some point during development I was requested to test the 4S setup on the 3S prop (the 6 x 5). I thought it was a ridiculous, but I obliged. I also tested some larger props. The results (not so ridiculous) are in my spreadsheet attached.
Looks like one could get away with larger props, but this is unofficial results. If you call Product Support with a fried motor or ESC because you ran it on a larger prop, well, good luck with that.
I don't feel the recommended props are undersized at all. The Hadron has plenty of thrust to launch easily on either setup (it does launch slightly better with the larger prop on 3S though). We found the best balance between thrust (diameter) and speed (pitch) with the chosen props. Other props we experimented with were all within the same general range within +/- .5" in pitch or diameter. If one wanted to experiment with larger diameter props for more thrust, then lower the pitch accordingly (to maintain similar load/current) have at it!
Tim
Last edited by THESANDMAN; Jun 07, 2015 at 12:21 AM. Reason: answered my own question
Old Jun 07, 2015, 12:25 AM
THESANDMAN's Avatar
Joined Oct 2010
got to fly the hadron this weekend , awesome plane . I would get another one . this plane would make a very sweet hi speed delta wing . which I am going to do in the near future , I am looking at maybe 150 with the power set I have laying in my closet .
Old Yesterday, 11:12 AM
Joined May 2010
This is now my favorite FPV plane. Getting 8 or so minutes out of a 2200 40c battery, going easy on the battery, mostly just doing low passes across the club. Leaps out of my hand for launch. Smooth flier.
Sold Flyzone Beaver, Flyzone C350 Corcalis, TH P-51 JimVanLoo Aircraft - Electric - Airplanes (FS/W) 0 Jan 08, 2013 01:15 PM
Alert Man arrested at Large Hadron Collider FL Knifemaker Life, The Universe, and Politics 48 Sep 04, 2010 08:38 AM
Discussion Live webcam from the CERN Large Hadron Collider Arbo Life, The Universe, and Politics 7 Apr 04, 2010 02:17 PM
Discussion Great news: Large Hadron Collider [U]probably[/U] won't destroy Earth lakedude Life, The Universe, and Politics 53 Dec 19, 2009 11:00 AM
Discussion Large Hadron Collider... Oh the loonies. Accu157 Life, The Universe, and Politics 48 May 14, 2008 01:39 AM
