View Poll Results: Which type of combat do you prefer?
One design (same plane shape/size) with common and battery) 1 4.35%
Similiar planes (Kens single motor combat planes) and common motor and battery. 14 60.87%
No limits except battery size (900 mAh 2S) 3 13.04%
Anything that flies....no limits 5 21.74%
Voters: 23. You may not vote on this poll
Old Jul 11, 2014, 11:30 AM
umop apisdn - downside up
United States, MI, West Bloomfield Township
Joined Sep 2012
Originally Posted by dz1sfb View Post
Mike, Don, Jordon, and myself have flown here. I already submitted the location to Owen. See if you remember where this is.
Ken
Once again, Ken is da man even though he used a different name than the one I knew. I will accept both.
Any others?
Let me know if you need more clues.
Owen
nagromnewo is online now Find More Posts by nagromnewo
Old Jul 11, 2014, 02:09 PM
Slipping the Surly Bonds
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
In fact there is a pictureof that site in this thread.
Men
dz1sfb is online now Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Jul 11, 2014, 08:50 PM
Joined Sep 2012
Men
Indeed there is.
C'mon guys! Is nobody else able to figure this out. The road in the photo should make you happy anyway...
Owen
Old Jul 11, 2014, 09:09 PM
Flys Like A Brick
Bob_B's Avatar
Washington, MI
Joined Nov 2010
.... from Kens hint
Bob_B is online now Find More Posts by Bob_B
Old Jul 11, 2014, 09:25 PM
Joined Sep 2012
Originally Posted by Bob_B View Post
.... from Kens hint
It don't count unless you tell me about it....
Owen
Old Yesterday, 03:27 AM
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
I am sorry to hear your going away Don. Did not realize it was your last night.
Big thanks to Don for starting this thread! it is widely read by even folks who do not fly with us.
Don, you will have to spread the madness wherever you go, sharing the fun of foam flight and combat.
I think I hear the Unclub President thinking up a rhyme,
Ken
Was that a hint?
The boys are sad, at Stony Creek,
they don’t know what to say,
Because, it seems “Strong Motors” Don
has uped and moved away.
No more he’ll be the Combat King
as he often was before.
All good things must end sometime,
and now he’s shut that door.
Of course the flying will not stop,
it will go on and on,
It’s just that now they’ll do it,
missing their good mate, Don.
Whiskers is online now Find More Posts by Whiskers
Old Yesterday, 06:53 AM
treefinder
springer's Avatar
SE MI
Ahhh, so true, so poignant, so SEMFF.
So anyone flying this weekend?
springer is online now Find More Posts by springer
Old Yesterday, 02:42 PM
Old Bold Pilot
got-one's Avatar
USA, MI, Rochester
Joined Nov 2008
Originally Posted by Whiskers View Post
Was that a hint?
I read this poem
as a tear welled in my eye.
Please come back and fly.
Dave F
got-one is offline Find More Posts by got-one
Old Yesterday, 04:19 PM
Whiskers's Avatar
Joined Feb 2010
It's not just missing friendship
that brings tears to the eyes.
With Don no longer coming,
who'll bring the guys' supplies?
Last edited by Whiskers; Yesterday at 07:24 PM. Reason: Fixed a plural possessive.
Old Yesterday, 08:30 PM
Joined Sep 2012
Monitor battery :(
Hi
I received my FPV stuff from China today, but unfortunately, the monitor was DOA. On further investigation, I found that the built in 1s lipo battery is showing an unhealthy 0V.
I dug a little further and found that there is actually 2.8V if I measure direct on the cell instead of after the tiny little PCB that's on the battery.
Since I am using a proper LiPo charger, can I simply bypass the PCB and connect direct to the battery? I would charge it up very slowly the first time to see how it behaves.
On another note, I maidened Donna's SloGo (Tiggerooo) today and ran into an unexpected problem. I was using Donna's Champ TX and a 6ch featherlight receiver. I ran out of range and nosed in the plane after about 50 yards. We've certainly had the Champ much further away with no problems and I've been using LemonRX receivers in everything for about a year including specking out the TLAR to get good photos lots of times.
Anyway, I've installed a new LemonRX just in case and set the plane up to use my TX, so hopefully that'll work better. I also found the plane to be very sensitive to the control surfaces, so I have reduced the throws to less than half of what I had. The good news is that she climbed out nicely without turning either way, so I expect the remaiden to go much better.
The airframe itself survived the nosein without a scratch save for a broken propeller, but the wing moving in the crash ripped off a servo wire, so I've moved the RX to the underside of the nose. Since one of the goals was to make the plane crash resistant, I reckon this was a success.
Owen
Old Yesterday, 09:04 PM
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Thank you Wiskers. That was nice.
Ken
Old Yesterday, 09:30 PM
dbacon's Avatar
Shelby Twp, MI
Joined May 2006
Yes you can charge the LiPo directly with a proper charger. A LiPo charger can have any number of features, including a short charge for it to see what the battery capacity is and set itself to 1C charging current. If you can manually set the charging current to 1C, then you don't need this feature.
Another feature is a safety feature that keeps it from charging a low battery, I don't know the minimum volts, but it could be in the range of 3.0 to 3.3 Volts. If you have this feature, you must charge some other way to get it above that cutoff. Not exactly recommended, but you might get away with it. I use the NiCD mode, very carefully.
All of them have a max Volts of 4.2 but some USB chargers exceed that, that is why they are not proper LiPo chargers.
dbacon is offline Find More Posts by dbacon
Old Today, 08:57 AM
Joe The Ripper
United States, MI, Washington
Joined Sep 2011
Whiskers you certainly authored a fitting farwell message. I for one am voting to keep you in your current capacity as our unpresident, as your performance has been exemplary.
Joe
fannonjk is online now Find More Posts by fannonjk
Flyers in SE Michigan Fungoo Electric Plane Talk 17 Feb 03, 2014 07:25 PM
E-flyer clubs in SE Michigan? LBM Electric Plane Talk 8 Dec 17, 2008 05:31 AM
Yippee! Any Foamy Flyers On Or Near Elizabeth City, N.c??? nieves50 Foamies (Kits) 31 Mar 06, 2004 08:11 PM
Flint, Michigan E-Flyers ??? crashnburn Electric Plane Talk 21 Dec 04, 2001 04:54 PM
Slope sites SE Michigan or NW Ohio? daveh Electric Sailplanes 4 Jul 27, 2001 06:37 PM
