Old Oct 25, 2004, 08:02 PM
tigerbug's Avatar
Loveland, Oh
Joined Aug 2004
Choices to replace GWS 350 C motor
Been flying e-starter for a couple of months now. Originally had major problems getting into the air. It came with speed 400 and a 1060 prop. Long story short my batteries weren't strong enough and plane would drop out of the sky. Broke tail section off but have sinced glued back.
I have since replaced my batts with 9.6volts, 8 cell 1400 AA NIMH. Also use a CC Pixie 20P Speed Control. Flew better but the 400 motor is quite heavy and makes the plane a heavy flier as well. Also messes with the CG as well. I then replaced the 400 with the GWS 350 and much better.
New problem is I just burned out the motor and it only had a minimal number of flights.
Question: What motor options do I have that will mount the same as the GWS and still be able to use the CC 20P and my battery packs. Batts are too new to replace and I am not ready to move into Lipos. Probably will make that change in the spring.
What are my options to at least maintain the 350 performance or actually increase a bit?
tigerbug is offline Find More Posts by tigerbug
Old Oct 25, 2004, 08:13 PM
darrell_f's Avatar
United States, FL, Melbourne Beach
Joined Dec 2003
You probably can't do much better until you go brushless/li-poly. With 8 cells, you can't expect more than about 20 flights for the 350. Try a APC 9X7 prop for a little more performance and a little longer motor life.
darrell_f is offline Find More Posts by darrell_f
Old Oct 25, 2004, 09:50 PM
Parrothead Extraordinaire
Mark Gund's Avatar
Island of Margaritaville.No parallels of latitude or longitude mark the spot exactly. Passports are not required
Joined Sep 2002
Hi-Max 2015
Mark Gund is offline Find More Posts by Mark Gund
Old Oct 26, 2004, 06:36 AM
Which way is up?
Ft Myers, Fl
Joined Feb 2003
I run a hi max 2015-4100 in a d box with an 11x5 or 12x6 on lipos on a 13oz plane, way better than the can motor in both power and efficiency.
Jim
jbird is offline Find More Posts by jbird
Old Oct 26, 2004, 11:47 PM
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by tigerbug
...I have since replaced my batts with 9.6volts, 8 cell 1400 AA NIMH.
You've hit the same brick wall I did. 350 motors burn up fast on 8 cells! If you want to stay with the NiMH (like I did), I can highly recommend the brushless AXI 2212-26. Fits in a GWS 400 gearbox (with very minor mod), but WITH NO GEARS. Performs great on 8 cells (much better than the 350), but you'd also need to get a brushless ESC like the Phoenix 10 (or to be safer, the 25). This doesn't meet all your criteria, but I'm afraid this is the plague of brushed motors.
Tom Frank is offline Find More Posts by Tom Frank
Old Oct 27, 2004, 03:03 AM
Texy's Avatar
Newbury, UK
Joined Aug 2002
I bet the AA battery pack is heavy as well (by today's standards).
You have 3 choices, as I see it. All of which are gonna cost you course.
Go the lipo route. IT doesn't have to cost the earth - you can get the older etech 1200 2s pack for around $25, or less. Then build your own lipo charger - lots of choices, and very simple designs.
Go the brushless route, but choose a diy cd-rom type kit from ACW - it will fit into
your gws gearbox. Of course you will need to buy a new controller - the ph10 will do nicely with the cd-rom.
3rd choice - both of the above.
Texy
Texy is offline Find More Posts by Texy
Old Oct 27, 2004, 03:14 AM
shoreline, washington
Joined Sep 2002
i have been flying a21 oz plane wth 8 cellsx 1050 kans/mah. 5.33-1 gws box, 9x6 apc sf prop.
with a Sagami 280 bb, aka tower electrifly 280 bb. about 25 bucks for the motor.
i did advance the timing for reverse rotation to match the gear box, slips into gws gb cheapest solution next to lipo/ brushless/new esc.
sloppytypist is offline Find More Posts by sloppytypist
For Sale gws 350 c motor and gearbox rudyhal Aircraft - Electric - Power Systems (FS/W) 7 Jun 26, 2006 10:35 PM
Is the shock flyer brushed motor or the gws 350 c gearing better? Mat Foamies (Kits) 0 Nov 11, 2004 05:46 PM
motor to replace GWS 350 in E-starter tigerbug Foamies (Kits) 6 Oct 26, 2004 08:28 AM
FS NEW GWS 350 C box/motor from Formosa skyking99 Aircraft - Electric - Airplanes (FS/W) 0 Nov 02, 2003 10:34 PM
FS NEW GWS 350 C box/motor from Corsair mlehman Aircraft - Electric - Airplanes (FS/W) 2 Nov 02, 2003 08:57 PM
