Old Aug 04, 2014, 06:16 AM
midelic's Avatar
Joined Apr 2012
Hasi,
How about posting a video to see it flying.
midelic is offline Find More Posts by midelic
Latest blog entry: DIY Multiprotocol TX Module
Old Aug 04, 2014, 06:56 AM
Hasi's Avatar
Austria, Stmk., Graz
Joined Sep 2011
Originally Posted by midelic View Post
Hasi,
Someone has already asked me this, but I don't really have a camera besides my phone and I can't fly and film the same time.
Hasi is offline Find More Posts by Hasi
Old Aug 04, 2014, 07:49 AM
Joined Jun 2013
well, you can try this way to make a video
John michel is online now Find More Posts by John michel
Old Aug 06, 2014, 04:16 AM
midelic's Avatar
Joined Apr 2012
For who is interested :
For stable crisp flying with mwii brushed I used these settings.
Flying mode: ANGLE
PID rol/pitch rate= 0.8
PID YAW rate =0.4
RC rate =1.0
Expo=0.34
LEVEL P -11.
My TX dual rate =60%. except yaw rate(100%)
Old Aug 08, 2014, 02:25 AM
United States, CA, Santa Monica
Joined Jul 2011
Does anyone know if FlySky's GT2B transmitter uses the same protocol as detailed in the first post?
Lpbug is offline Find More Posts by Lpbug
Old Aug 11, 2014, 12:40 PM
Joined Jun 2012
Yes they do. I've use the 3ch receiver in a plane and 6ch in cars a few times with my PSX firmware modded GT3C and original GT3 transmitters.
RevDWC is offline Find More Posts by RevDWC
Old Aug 11, 2014, 01:01 PM
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
The psx firmware, does that use a playstation controller?
djdavies83 is online now Find More Posts by djdavies83
Old Aug 11, 2014, 11:36 PM
Joined Jun 2012
No, a guy over at rctech dot net rewrote the firmware for the GT3B and GT3C controllers. It cures a lot of bugs and really opens up the available features. Think of it as ER9X for a car radio.
Old Aug 11, 2014, 11:55 PM
Joined Jun 2013
that sound good, thanks for info
Old Aug 16, 2014, 08:55 AM
Joined Jun 2014
Greetings!
I am kinda new to RC world and amateur in electronics. So as you've already guessed, I have tons of questions :P
Won't bother you much here, since I've always wanted to learn things by my own, as much as possible. But the amount of information that I've absorbed in past 3 days is just rediculous.
For start, I would like to build Tx/Rx on my own. Starting first with small range project, just to learn basics. Then I'd like to proceed to a bigger project, Arduino controlled gimball on quadro. Yeah well quadro is still under construction and as a future mechanical engineer I have no problem in construction but electronics... that's another story :P
I've done some of small, cheap and amateur projects (like MiniSumo-Bot, GhostRider lights in car, doorbell -.-). But I would like more I believe that RC world offers endless posibilities.
So yeah enough of cheap talking and back to topic. So for the first project I'd like to built a Tx-Rx without arduino (I have tons of electric components including Ard-Uno and Ard-Nano).
Curently I am struggling to understand what is the meaning of FUSE settings in first post of Midelic?
Best of regards from Slovenia!
Aljaz Jelen
AljazJelen is offline Find More Posts by AljazJelen
Old Aug 16, 2014, 09:19 AM
midelic's Avatar
Joined Apr 2012
To understand fuses start with fuse calculator and the meaning of each fuse you find on the net.......Start introduce the fuses from first post in fuse calculator and see what's changing from default..There are few fuses you should consider changing fuse for setting the avr frequency ,,internal clock or external(Xtal) ,,BOD....EESAVE.......the rest should be kept as default if you don't know what they are what they do.
Warning:
changing fuses without some knowledge about them may lock your chip.However if using arduino boards wich have already bootloader in ......no need changing fuses.Their fuses are already set.
http://www.engbedded.com/fusecalc/
Old Aug 21, 2014, 11:42 AM
Joined Jun 2014
Thanks for your reply Midelic!
I've got a tiny little question. Which Tx/Rx (in combination with arduino) modules you suggest for sending data wireless?
I need a range of atleast 500 metres in open ground. Oh yeah and keep in mind that I am not a beginner in Arduino nor a pro :P
Here is the list of modules I currently think of. Feel free to add more!
Si4432
RFM22B (or any other of RFM series)
A7105
NRF24
XL7105
Regards!
Aljaz Jelen
Old Aug 21, 2014, 12:11 PM
midelic's Avatar
Joined Apr 2012
For long range is better in UHF frequency,,I think better refine your search in at least 2 parts ......2,.4GHz modules(A7105 NRF,CC2500) fair range and UHF 433 MHZ modules(SI 4432. RFM22B...) longer range for even longer range..you may also want a look here.
http://www.rcgroups.com/forums/showthread.php?t=2079662
I cannot advise more I'm biased to 2.4Ghz modules...
Sold flysky th9x, flysky tx module, flysky 8ch rx snakecrew Aircraft - General - Radio Equipment (FS/W) 7 Oct 02, 2013 02:58 PM
Mini-HowTo TH9X Turnigy FlySky IMax modify module to SMA and 1W booster DIY FPV rotaryboots Radios 3 Jun 08, 2013 02:32 PM
Wanted Flysky 9x V1 RF module gdenton3 Aircraft - General - Radio Equipment (FS/W) 0 Aug 16, 2012 08:58 PM
Wanted Flysky 9x V1 RF module gdenton3 Aircraft - General - Radio Equipment (FS/W) 3 Sep 13, 2011 02:27 PM
Sold Flysky V2 RF Module, Antenna and 8 ch Receiver, $30 shipped CONUS ek123 Aircraft - General - Radio Equipment (FS/W) 0 Nov 20, 2010 01:43 AM
