Old Sep 29, 2012, 04:22 AM
Altura is offline
Find More Posts by Altura
Altura's Avatar
France, IdF, Paris
Joined May 2011
This 5.8G 200mW (TX5823) 5v compatible ?
Hi all,
Until know I only found 5v compatible 200mw tx at FPVHobby but I found this one in aliexpress for 15$ only.
Do you know if it's a real 5v compatible module?
I've just received it, it's marked tx5823-101016.
Thanks for your help.
Vincent
Altura is offline Find More Posts by Altura
Old Oct 01, 2012, 01:15 PM
Altura is offline
Altura's Avatar
France, IdF, Paris
Joined May 2011
AliExpress just told me they will send me the specification datasheet.
Wait and see.
Old Oct 01, 2012, 02:19 PM
FPVLand is offline
Find More Posts by FPVLand
Joined May 2012
Not suprise, Rangevideo is selling 5V Tx since long time.
Datasheet here : http://www.rangevideo.com/index.php?...roducts_id=304
FPVLand is offline Find More Posts by FPVLand
Old Oct 01, 2012, 03:09 PM
rcall is offline
Find More Posts by rcall
FPVing for fun...
rcall's Avatar
Joined Jul 2003
Rangevideo's are in a different band, not the same as FPVHobby's or Aliexpress'
rcall is offline Find More Posts by rcall
Old Oct 01, 2012, 03:29 PM
VRflyer is offline
Find More Posts by VRflyer
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Originally Posted by Altura View Post
Hi all,
Vincent
Pas sur si ca va t`aider, mais les nano camera fonctionne sur 3.3V quand on enleve le regulateur. Alors il devient simple d`alimenter le TX et la cam tous les deux a 3.3V avec un regulateur lineaire comme celui de Flytron:
http://www.flytron.com/camera-transm...regulator.html
mais si tu utilise une cam qui doit avoir 5V, alors je comprend que tu veux un tx 5V aussi
nano cam 3.3V apres modification: http://www.foxtechfpv.com/fh10c-v9-12v-pal-p-531.html
VRflyer is offline Find More Posts by VRflyer
Old Oct 02, 2012, 12:15 PM
Altura is offline
Altura's Avatar
France, IdF, Paris
Joined May 2011
They've sent me the datasheet and... this module seems 5.5v capable.
I use to power the video TX and the camera on the 5v ESC BEC.
That's a good news. This makes this module really cheap (15$ plus 4$ shipping) for a 200mw TX.
Hoping the datasheet is not lying
Old Oct 02, 2012, 04:25 PM
VRflyer is offline
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
You will pull 250mA from your BEC. Be sure it have enough Amperage
Old Oct 02, 2012, 04:58 PM
_Sibi_ is online now
Find More Posts by _Sibi_
_Sibi_'s Avatar
Joined Aug 2008
Altura,
is the unit compatible with the following channels (or the RC 305 Receiver from Foxtech):
Ch1:5705mhz , Ch2:5685mhz , Ch3:5665mhz , Ch4:5645mhz , Ch5:5885mhz , Ch6:5905 , Ch7:5925mhz , Ch8:5945mhz
_Sibi_ is online now Find More Posts by _Sibi_
Old Oct 03, 2012, 12:08 AM
Alman is online now
Find More Posts by Alman
Alman's Avatar
Canada, Quebec
Joined May 2001
Please look at the second page of the datasheet you received and look at PIN 4. Is it label as 3.3V power DC IN? Only first page shows 3.5 to 5.5V operating Voltage!
Alman is online now Find More Posts by Alman
Old Oct 03, 2012, 01:24 PM
Altura is offline
Altura's Avatar
France, IdF, Paris
Joined May 2011
No problem Turnigy Plush 6A BEC can drive 800mA.
Ch1:5705mhz , Ch2:5685mhz , Ch3:5665mhz , Ch4:5645mhz , Ch5:5885mhz , Ch6:5905 , Ch7:5925mhz , Ch8:5945mhz?
Yes
Good point! You are right the datasheet is quite ambiguous...
Anyone can try with 5V? ... before me
Old Oct 10, 2012, 06:55 PM
Opt is offline
Opt
Find More Posts by Opt
Opt
New Zealand, Auckland
Joined Oct 2010
Did you try it?
Opt is offline Find More Posts by Opt
Old Oct 10, 2012, 07:18 PM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
open it and check if theres a regulator :P
the 3.3v module will work on 1S lipos, it just heats and uhm, may eventually fail... dunno if a true 5v makes it burn right off.
CrashMeUp is offline Find More Posts by CrashMeUp
Old Oct 13, 2012, 04:35 AM
bofred is offline
Find More Posts by bofred
Kungshatt
Joined Mar 2008
hi, how low can voltage go without turning it of? maybe a diod will do the job from one cell lipo!?
Ibought one to try out
bofred is offline Find More Posts by bofred
Old Oct 13, 2012, 01:15 PM
Crashomatic
CrashMeUp's Avatar
Joined May 2010
diode should work
the spec sheet is on sky-rf.com
Old Oct 14, 2012, 08:33 PM
Alman is online now
Alman's Avatar
Canada, Quebec
Joined May 2001
the 3.3v module will work on 1s lipos, it just heats and uhm, may eventually fail... Dunno if a true 5v makes it burn right off.
Description: Aliexpress - DFHOBBY - TX5823
No regulator, 3.3V module.
This is Aliexpress - DFHOBBY - TX5823 ''5V'' module.
Discussion Tx/Rx connectors on 200mW 5.8G system learn2turn FPV Talk 2 Jul 26, 2012 05:34 PM
Discussion Wireless 5.8g tx 200mw,400mw,1000mw bigheadfpv Philippines 0 Jul 21, 2012 10:48 PM
Discussion 900MHZ 1500mw v.s. 5.8g 200mw DYORD FPV Talk 6 Jul 01, 2012 07:42 PM
Help! Helpr with Foxtech 5.8G 200mw Channels dk31 FPV Talk 2 Jun 17, 2012 05:19 PM
Discussion RC4Y 5.8G 200mW transmitter for FPV free shipping RC4YFPV Hot Online Deals 6 Jun 13, 2012 09:23 PM
