Old Jun 28, 2015, 08:14 AM
tnemelc is offline
Find More Posts by tnemelc
Joined Apr 2013
Hi Gang,
i just flew my Naze32 CleanFlight driven fpv racer today. Setup was quite easy with this thread.
I run CF 1.9.0, dys SN30A ESCs with BLHeli 13.2 (oneshot & damping light), MT2204 2300kv motors, 6045props on 4S HeatRC 2200mah 40-80C.
It flew just like a boss! Maybe some very slight PID changing could make it perfect, but it felt really good to fly it.
Anyway, so i raced it over an acre and did quite aggressive maneuvers, and on two flights my quad suddenly flipped to one side and crashed. As far as ive seen it really just flips over the side. It did not tilt or fall for- or backwards... I swapped ESCs but the problem was still there on the second flight. 3-4mins without the slightest issue and then all of a sudden it crashs.
Fortunately i built a tank, so only the props were damaged.
I flew in manual all the time.
Has anyone a clue what have caused this?
Thanks for any hint! Happy flights, stay safe
tnemelc is offline Find More Posts by tnemelc
Old Jun 28, 2015, 10:12 AM
mxracer33x is online now
Find More Posts by mxracer33x
United States, CA, Chico
Joined Mar 2014
Could be some desyncing. What is your looptime? I have had issues occasionally and ended up at 2500 with great reliability.
mxracer33x is online now Find More Posts by mxracer33x
Old Jun 28, 2015, 10:16 AM
JohnOCFII is offline
Find More Posts by JohnOCFII
United States, MN, Eagan
Joined Feb 2012
Originally Posted by Firepower View Post
Two wires from the GPS go to the Naze. I have this GPS.
http://www.nextfpv.com.au/products/m...le-u-blox-7-8g
You need 4 wires from the GPS to the Naze32. Trasmit, Receive, +5V and Ground.
I've got a Dragon Fly 32 Pro (Flip32+ clone) and am using a soft serial connection.
I've attached a diagram of a Naze32 with an attached GPS. I dowloaded it from somewhere on the Internet, so I can't give credit or point to the site for more information.
John
JohnOCFII is offline Find More Posts by JohnOCFII
Old Jun 28, 2015, 10:17 AM
tnemelc is offline
Joined Apr 2013
Thanks for your answer!
I thought oneshot doesnt act on loops anymore? The escs "waits" for the next signal and doesnt check the signals in a loop. But i set 1500 in the GUI
What about ground wiring to the naze from the escs? Does every signal needs its ground? I've adapted the power distribution from another racer and i only went with the signals to the naze. Could this be it? But if yes, why do they spin at all?
EDIT: i've crimped all the ESC grounds together and connected them to the Naze, but it still flipped on 2 of 3 flights. Besides this it flies really great, i just dont know what to try next...
Its exactly like in this video (not me), except mine flips to the right side every time
Blackout with Naze32 random flip (0 min 28 sec)
Old Jun 28, 2015, 03:26 PM
Tom T is offline
Find More Posts by Tom T
Learning to crash
United States, IN, Indianapolis
Joined May 2014
Any logical reason Im not getting the auto level when Im in horizon mode? It works great in angle mode (snaps right back to level when I let off the stick). Only had a short time to do a couple of maiden hover tests this morning on the blackout, but pretty sure it wasnt self leveling in horizon mode. Heading out again in an hour or so as soon as the winds die down some.
Tom T is offline Find More Posts by Tom T
Old Jun 28, 2015, 07:40 PM
jd_ is offline
jd_
Find More Posts by jd_
jd_
Joined Sep 2012
Smooth Naze32 Ride
Freestyle Flight Sunnysky 2207 & ZTW Spider 20A / Blackout Mini H Quad Clone Flown With DragonLink (7 min 38 sec)
jd_ is offline Find More Posts by jd_
Old Yesterday, 08:28 AM
Hanni1312 is online now
Find More Posts by Hanni1312
Team WarpSquad
Germany
Joined Mar 2014
Hello my naze keeps on buzzing while connected to the USB port. Is this normal?
Please help
Hanni1312 is online now Find More Posts by Hanni1312
Old Yesterday, 10:39 AM
Stuka_99 is offline
Find More Posts by Stuka_99
Callsign: Zulu
Stuka_99's Avatar
Somewhere in the skies!
Joined Feb 2011
A guess is its the low voltage alarm settings.
Stuka_99 is offline Find More Posts by Stuka_99
Old Yesterday, 04:38 PM
tfelog is online now
Find More Posts by tfelog
United States, NY, Saratoga Springs
Joined Feb 2014
What does it mean when it says "communication with bootloader failed"
tfelog is online now Find More Posts by tfelog
Old Today, 09:29 AM
RM_Sparks is offline
Find More Posts by RM_Sparks
We Do It With FRQZ
RM_Sparks's Avatar
United States, CA, San Diego
Joined Aug 2009
Does anyone know which diode is the 5v protection for the board coming off of the motor pins? When I connect my esc to the board I get no lights, but if I connect using the computer I get the lights. I think the protection diode went out.
Edit: I think it's this diode here.
RM_Sparks is offline Find More Posts by RM_Sparks
Help! Guide for sailplane setup & triming Ken Smith Sailplane Talk 6 Apr 06, 2015 06:53 AM
For Sale AfroFlight Flight Controller (Naze32) Box/Container/holder Made from Delrin Greasetattoo Aircraft - Electric - Multirotor (FS/W) 8 Feb 14, 2014 12:03 PM
Help! beginner's guide to Rhino for dummy's ????? grover CAD/CAM 4 Oct 16, 2011 05:56 AM
Help! Walkera 4#3 easy setup guid ? dendirk Micro Helis 3 Mar 15, 2008 11:45 AM
Discussion Tips for Red Necks (Like myself.) Don Sims Humor 0 Feb 11, 2002 10:53 PM
