Old Nov 17, 2010, 08:14 AM
HoverDown3K is offline
Find More Posts by HoverDown3K
Vampyre Inc
HoverDown3K's Avatar
Rochester, New York
Joined Nov 2004
Question
FPV interference and Carbon Fiber
I have noticed that most pan and tilt systems are made of wood, is there any reason NOT to use carbon fiber?
Would a carbon fiber pan and tilt cause any interference?
What a about mounting the Video TX on a carbon fiber plate?
thanks
HoverDown3K is offline Find More Posts by HoverDown3K
Old Nov 17, 2010, 09:20 AM
sverlander is offline
Find More Posts by sverlander
Sam in Virginia
sverlander's Avatar
Hampton Virginia
Joined Jul 2005
thanks
I just installed the large carbon fiber pan and tilt from Hobby King onto my Busy Bee plane and it works great. I dont think carbon fiber is a good idea anywhere around the video transmitter or antenna but if you try it , just be sure to range check it before flying.
FPV Busy Bee first flight (8 min 39 sec)
sverlander is offline Find More Posts by sverlander
Old Nov 17, 2010, 11:36 AM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
http://vimeo.com/16871610
I'm pretty sure that mount is just fiberglass....
aaronredbaron is offline Find More Posts by aaronredbaron
Old Nov 17, 2010, 11:55 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
treat CF as you would metal. They have similar RF blocking properties.
ashdec87 is offline Find More Posts by ashdec87
Old Nov 17, 2010, 02:15 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
They actually don't behave the same. Carbon fiber tends to attenuate signals while
metal reflects them. A steel rod can create obnoxious multipath interference for a
nearby Tx or Rx. Carbon rods and ribbons tend to not do that, and only become a
problem when you physically block the whole signal.
I use a carbon fiber pan/tilt mount, and it has been no better or worse than
the identically shaped wood mount it replaced Rf-wise. It has lasted much much longer.
A metal cased camera near the video Tx antenna is likely to be a bigger problem.
ian
Daemon is online now Find More Posts by Daemon
Old Nov 17, 2010, 04:54 PM
Sam in Virginia
sverlander's Avatar
Hampton Virginia
Joined Jul 2005
You are correct, I just looked at HK web page and it say's fiberglass.
I guess because it is black in color I assumed it was carbon fiber.
Anyway it seems like a good mount so far, differently light weight but strong.
Old Nov 18, 2010, 01:15 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
ian
thanks for correcting, I meant they both block, not so much the metal reflecting part. Either one will create a nice blind spot behind it (right?)
Discussion carbon fiber casue radio interference? grant31781 Radios 4 Dec 09, 2006 11:54 AM
Question Carbon fiber and interference? kc8qvo Composites Fabrication 16 Jul 05, 2006 06:18 PM
Help! Carbon fiber products and interference wollins Power Systems 5 May 13, 2005 02:42 PM
Omega carbon fiber fuse interference Johnnie Sailplane Talk 4 Sep 17, 2004 10:00 PM
Carbon Fiber rods and radio interference? crashnburn Power Systems 15 Jan 05, 2002 11:50 AM
