Old Jul 03, 2015, 08:07 PM
Xcessive Carts is offline
Find More Posts by Xcessive Carts
Joined Oct 2014
Boat Died....Need help
Heres what happened today, it was the 4th run on a new HobbyKing Relentless all stock.
Running 4s 2200 40c battery. After about 3 minutes of a great run, I came out of a turn at 1/2 throttle, pulled the trigger and it just died. I recovered it, took the lid off. Dry inside, Nothing was really even warm, no smoke, no burnt smell. Tried a different battery. Nothing, no beeps, no power to Motor or Steering Servo. Need some input here.
Xcessive Carts is offline Find More Posts by Xcessive Carts
Old Jul 03, 2015, 08:38 PM
ApexpretadorGT is offline
Find More Posts by ApexpretadorGT
United States, FL, Fort Lauderdale
Joined Nov 2014
If theres absolutely nothing I would bet it's the rx. Try leaving it out in the open to air dry it could be a build up of moisture over time. Do you store it with the lid on or off?
ApexpretadorGT is offline Find More Posts by ApexpretadorGT
Old Jul 03, 2015, 08:43 PM
micromodder is online now
Find More Posts by micromodder
micromodder's Avatar
United States, IN, Greensburg
Joined Jun 2014
Yea that happened to me a few weeks ago and my Rx was sealed off inside of a balloon.I think balloons promote condensation and are just a hassle, I'm going to start using corrosion x on all of my Rx's and servos.
micromodder is online now Find More Posts by micromodder
Old Jul 03, 2015, 08:46 PM
Joined Oct 2014
Yes it was in balloon, lid always left off. I will pull it out of balloon and let it air out for a bit. The RX would be alot cheaper to replace than the ESC.
Old Jul 03, 2015, 09:14 PM
f.a.r.m.e.r is offline
Find More Posts by f.a.r.m.e.r
Farmer
f.a.r.m.e.r's Avatar
United States, CA
Joined Oct 2011
IF it was dry inside it could be a couple things, for one balloons cause more harm then they are worth imo take that reciever out blow dry it test it if it works just spray the inside of the reciever with corrosion x hd and don't ballon it, dont for get to tape the hatch aswell!
worst case senerio you fried the bec, which is not a big deal you can pick up a UBEC for 3 to 6 dollars on ebay.
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Jul 03, 2015, 09:40 PM
Joined Oct 2014
Rx
I took the receiver out of bag, it was damp. Plugged battery in and noticed the red led is blinking twice in a cycle.
The receiver is a Associated RC, TRS-402-SSi 4 channel. Dont have the manual for the TX or RX. Anybody know what that 2 blink code means?
Old Jul 03, 2015, 09:57 PM
Farmer
United States, CA
Joined Oct 2011
IDK could explode though 2 blinks cant be good
I mean dry it out and re-bind it
Old Jul 03, 2015, 09:58 PM
Joined Oct 2014
Tried to bind the TX and RX. Rx will not go into bind mode which is Red/Green flashing, just stays Red 2 flash mode. I think it is a goner
Old Jul 03, 2015, 10:04 PM
Farmer
United States, CA
Joined Oct 2011
take it out the case and blow dry it! you said it was damp and you plugged it in thats not good you should of dried it out completely first.
Old Jul 03, 2015, 10:11 PM
Joined Nov 2014
Definitely the rx, there's still hope. Open it up and let it air dry preferably under an ac vent or a fan.
Old Jul 03, 2015, 10:14 PM
Farmer
United States, CA
Joined Oct 2011
i would blow dry it with a hair dryer if you have
btw here is the manual http://www.teamassociated.com/pdf/di...SSi_manual.pdf
Old Jul 04, 2015, 06:54 PM
Joined Oct 2014
Problem Solved
I replaced the RX, working good again. Thanks for all the input.
Old Jul 04, 2015, 06:56 PM
Farmer
United States, CA
Joined Oct 2011
Awesome, glad you're up and running again!
Question Camera Boat project help needed 4ch/6ch & servos confusion? mildman Dock Talk 25 Jun 15, 2015 08:11 PM
Help! Need Help to ID this boat-Unlimited hydro Hollywood2979 Dock Talk 0 Jun 04, 2015 11:07 AM
Question New to boats, need help identifying... bluebayou Dock Talk 7 Jun 03, 2015 10:37 PM
Help! Boat Project - We need your help! MECProject Racing Boats - Electric 3 Jun 01, 2015 11:11 AM
Discussion New to Rc Boats, Need Help!!! With The Joysway Surge Crusher. barg Racing Boats - Electric 1 May 17, 2015 09:21 PM
