Old Jul 02, 2015, 11:22 AM
LowlyElevated is offline
Find More Posts by LowlyElevated
Team PeasantCopter... kind of.
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
Help!
Elevon Trim?
I figured this would be the best place for advice. I have a "wild hog" combat wing using elevons for control, and the trim on it is confusing me. Using the trim tabs, moving the aileron moves one surface while the elevator moves the other surface! this makes it impossible to get completely in trim, its always rolling or pitching.
I'm using a DX8. Does anybody know how to fix it so both trims control the axis they are meant for, not the individual servos?
LowlyElevated is offline Find More Posts by LowlyElevated
Old Jul 02, 2015, 11:59 AM
H8Monday is offline
Find More Posts by H8Monday
H8Monday's Avatar
United States, CA, Orangevale
Joined Jan 2014
Push all switches away from you before you turn on the radio and start setup.
In system setup
model type........airplane
model name......?????
wing type............Elevon /tail.........normal
Main screen , function list
Servo setup..........leave alone for now
D/R and Expo...... Aileron:
D/R: 70 70
Expo: 26 26
Sw: Aile D/R
Elevator:
D/R: 84 84
Expo: 25 25
Looking at the plane from the rear Right servo goes to ELEV on receiver and Left servo goes to AIL on reciever
That will get you started.
H8Monday is offline Find More Posts by H8Monday
Old Jul 02, 2015, 12:02 PM
Joined Sep 2012
I have all of that down. The plane flys fine, my control throws are good. Its just the trim thing is bothering me.
Old Jul 02, 2015, 12:39 PM
H8Monday is offline
H8Monday's Avatar
Joined Jan 2014
ok I guess I'm not understanding what you want. While moving the trim switches next to your sticks on the tx. The ELE should move both servos up and down same direction and AIL should move both servos in opposite directions. Is that right
Old Jul 02, 2015, 12:56 PM
Joined Sep 2012
I'd imagine that it SHOULD, but it does NOT. The elevator trim moves the servo in the elevator channel, and same as the aileron trim. Thats where my problem is.
Old Jul 02, 2015, 01:02 PM
H8Monday is offline
H8Monday's Avatar
Joined Jan 2014
Go to system setup
go to switch select and make sure everything is marked : Inh
Old Jul 02, 2015, 01:04 PM
H8Monday is offline
H8Monday's Avatar
Joined Jan 2014
Go to Trim Setup and set all at 5 and trim type: Common
Old Jul 02, 2015, 01:05 PM
Joined Sep 2012
Go to system setup
Ok, just did that. According to the servo setup menu its working right, let me go check with the real plane.
Old Jul 02, 2015, 01:09 PM
Joined Sep 2012
Ok, that worked. Thanks!
Old Jul 02, 2015, 01:10 PM
H8Monday is offline
H8Monday's Avatar
Joined Jan 2014
Cheers
tenbars is online now
Find More Posts by tenbars
Joined Nov 2007
Guess you got it worked out.
tenbars is online now Find More Posts by tenbars
Old Jul 02, 2015, 01:13 PM
Joined Sep 2012
Originally Posted by tenbars View Post
I'm confused; in one post you say "its always rolling or pitching" another post you say "The plane flys fine".
I would suggest starting from scratch, unplug everything and reset the Tx or simply trim her out manually…
When I said that the plane flys fine, I was referring to H8Mondays post giving throw and wing type guidelines. It had the trim issue, but it otherwise flew just fine.
Problem is resolved now, changing the switch select to "INH" on all did it for some reason.
Help! no trim on one elevon mdrossno1 Hitec/Multiplex USA 4 Jun 08, 2015 09:48 PM
Help! Elevon trims on a JR 6102 mdennis Radios 0 Mar 09, 2007 09:12 PM
Discussion Trimming with DX6 when using elevons? rampman Radios 0 Jun 29, 2006 11:10 AM
Stryker elevon adjust/trim? squidbait Parkflyers 9 Aug 07, 2005 09:17 PM
Prism 7 elevon trim cnims Radios 0 Aug 25, 2002 12:20 AM
