Old Dec 21, 2014, 09:35 AM
qwerty1000 is offline
Find More Posts by qwerty1000
qwerty1000's Avatar
Russia, Moscow, g. Moskva
Joined Sep 2007
J-35 Draken AeroTetris/Bukvorez
hi
We are starting a new development J-35 Draken
lenqth 2000mm
Best regards, Egor
qwerty1000 is offline Find More Posts by qwerty1000
Site Sponsor
Old Dec 22, 2014, 03:08 AM
Mankan is offline
Find More Posts by Mankan
Mankan's Avatar
Sweden, Stockholm County, Stockholm
Joined May 2013
Hi Egor!
Hope you get some christmas and not only a lot of work for us all out there.
Do you think you can add 2 drop tanks as well? If flying this as a hand launcher it is perfect to belly land it on the tanks.
Se the movie of me flying my F100, and hand launching it. I guess the Draken will weigh about 3,5 kg, at most, flight ready.
F100 Super Sabre (HD) EDF Jet (6 min 57 sec)
Mankan is offline Find More Posts by Mankan
Old Dec 22, 2014, 06:09 AM
qwerty1000's Avatar
Joined Sep 2007
hi Mankan
Thank you for your congratulations
merry christmas!!!
First, we draw the model and cut it into parts.
If there is free space, we do stand or fuel tanks.
Regards, Egor.
Site Sponsor
Old Dec 22, 2014, 08:21 AM
Mankan is offline
Mankan's Avatar
Joined May 2013
Some interesting Draken movies:
The Saab 35 Draken at Wing F10 Sweden.mp4 (5 min 54 sec)
First to do the Cobra?
Saab J35 Draken trainers doing the Swedish Cobra Maneuver (3 min 8 sec)
Nostalgic film:
Saab J 35 Draken, 1960 (3 min 38 sec)
More nostalgia:
Saab J35 Draken Marketing video (9 min 55 sec)
Old Dec 23, 2014, 12:17 AM
qwerty1000's Avatar
Joined Sep 2007
hi guys.
length 2000mm
show please approximately (+-50-80mm) where you will install the 120mm EDF
Regards, Egor
Site Sponsor
Old Dec 23, 2014, 02:49 AM
Mankan is offline
Mankan's Avatar
Joined May 2013
Originally Posted by qwerty1000 View Post
hi guys.
length 2000mm
Regards, Egor
Well, I am not 100% sure but I think it is a good idéa that the intake channels not curve to much. As on the real plane (wich I have worked on). The marked spot is what I suggest.
However, this is an EDF, not the full scale plane. So others might know better.
Old Dec 23, 2014, 02:43 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
If the fan is too far back the batts will end up in the cockpit.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Dec 23, 2014, 04:24 PM
Mankan is offline
Mankan's Avatar
Joined May 2013
Where should the CG be, any ideas?
Old Dec 23, 2014, 05:30 PM
Alpha.MotionRC is offline
Find More Posts by Alpha.MotionRC
Kicking Tires
Joined Jan 2014
The CG is just forward of the point where the wing "steps out", essentially just forward of the main landing gear. Here's a picture from someone's scratchbuilt plans. I flew my HK 90mm Draken slightly further forward that what is shown in this picture. It was better on the nose heavy side of the CG range. Approaching the tail heavy side of the CG range would tempt a very nasty stall during turns.
Please also choose an airfoil with a good amount of reflex in the trailing edge.
Alpha.MotionRC is offline Find More Posts by Alpha.MotionRC
Old Dec 24, 2014, 02:31 AM
Mankan is offline
Mankan's Avatar
Joined May 2013
Ok, the fan should be a bit more forward than I suggested? Not fun to have the batterys as long forward as possible.
Old Dec 24, 2014, 03:34 AM
Flygaresset is offline
Find More Posts by Flygaresset
Joined Dec 2014
Im looking for draken 1200-1400mm legth and 90mm fan.
Flygaresset is offline Find More Posts by Flygaresset
Old Dec 24, 2014, 03:47 AM
qwerty1000's Avatar
Joined Sep 2007
may be...?
Site Sponsor
Old Dec 24, 2014, 10:40 AM
Kicking Tires
Joined Jan 2014
That is the position of the 90mm EDF in my Draken on 6s 5800. It also appears to be similar in position to Claus' 70mm Draken flown earlier this autumn. I'm looking at the rear of the fan shroud: I'm imagining the forward lip of the fan shroud will actually be slightly further forward than this picture, because the red fan shroud outline is not to scale.
With the narrow dimensions of the cockpit area, perhaps a better approach would be to measure the largest width in the cockpit area and the area behind it. This will determine the placement of the battery. Knowing that location in the front, then position the fan to correctly offset that weight in the rear. An 8s pack would be able to fit further forward, requiring a fan further back. But large packs, for example 12s, would likely sit further back, requiring a fan further forward.
In any case, I think we can agree that the battery would not be situated on the main landing gear.
An adjustable-depth duct for the fan mount may be a good idea as well. Adjust the fan's position instead of adding dead weight.
Old Dec 24, 2014, 10:54 AM
Kicking Tires
Joined Jan 2014
Moving the fan too far forward would require the battery to move back, which would put it near the gear, where the ducting is converging. Not good.
Consider the Mirage and Eurofighter for comparisons of fan/battery placement on different deltas. The bifurcated duct of the Mirage is closer.
Old Dec 24, 2014, 02:06 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Start your cg 1" fwd of the wing break.with all the servos and a tail retract that last pick has the fan too far back.ck my scratch build I did from clausxpf's scale drawings....my fan is too f as r back so move fwd a couple more inches.lots of pics in that thread.plane flew very well.
Discussion JA-37 Viggen AeroTetris/Bukvorez qwerty1000 Foamy EDFs 143 Jun 01, 2015 08:12 AM
Discussion Viper MK-IV AeroTetris / Bukvorez qwerty1000 Foamy EDFs 10 Apr 12, 2015 01:27 AM
Discussion Saab Draken J-35 cyclops2 Japan 1 Aug 10, 2007 01:37 PM
Discussion J-35 Draken from blue fanfold. soarrich Pusher Prop Jet Models 0 Jan 08, 2006 06:27 PM
