Old Oct 06, 2008, 12:29 PM
Tobbe
Twistringen
Joined Oct 2008
Engine for Kyosho Spitfire 50
Anyone know if the OS MAX FS-70 ULTIMATE will fit INTO the Kyosho Spitfire 50? I don't want to cut big holes in it. Or should I stay with O.S. MAX FS A-56 ?
Tridde01 is offline Find More Posts by Tridde01
Old Oct 06, 2008, 08:55 PM
St. Peters MO.
Joined Apr 2005
If your going to go with a 4 stroke. Stay with the 70, the 56 will be underpowered. But anyway you go you will still have to cut holes in the cowl.
DOZZ is offline Find More Posts by DOZZ
Old Oct 11, 2008, 02:44 PM
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
You'll have to cut holes in the cowl anyhow for cooling. BTW, I have a saito 72 in my Kyosho ME-109. so your 70 OS should work out very well.
kahloq is offline Find More Posts by kahloq
Old Oct 13, 2008, 01:02 PM
Joined Dec 2005
I have a Saito 82 in mine and the thing rocks!!! Just make sure your cg is right on or a little nose heavy.
helifann is offline Find More Posts by helifann
Old Oct 14, 2008, 05:34 PM
What plane do I need now?
Yorba Linda, CA
Joined Jul 2004
I have a choice between my OS .46AX or an OS .70 Surpass. Any opinions as which way to go in the Spit 50?
Larry
60+Retiree is offline Find More Posts by 60+Retiree
Old Oct 14, 2008, 07:45 PM
stallwart's Avatar
Central Arkansas
Joined Jan 2006
Gotta say go for the OS 70. The 46 will fly it well, but still sounds like a tiny leaf blower. The OS should let you fly longer on a tank and will sound so much better--not like a Merlin--but still better.
stallwart is offline Find More Posts by stallwart
Old Oct 14, 2008, 11:17 PM
Hamilton New Zealand
Joined Jun 2008
Larry
Hi Larry.I have the 70 surpass in mine with 11/8 3blade
and shes super. No problem with cg just put batt right back and balanced sweet.
biggles2008 is offline Find More Posts by biggles2008
Old Oct 16, 2008, 03:12 PM
Yorba Linda, CA
Joined Jul 2004
Thanks for the opinions re: 46 vs 70 Surpass. Here's a follow-up.
I have the OS .70 Surpass nib, or a Saito .72 on another plane that I could swap.
Is the 70 pleanty of power, or do I need to go with the .72?
Thanks - Larry
Old Oct 17, 2008, 03:55 AM
Joined Jun 2008
Thanks - Larry
plenty of power go with the 70 larry..
Old Oct 19, 2008, 11:16 PM
Yorba Linda, CA
Joined Jul 2004
Did you use the stock gas tank or install a bigger one? The stock tank is appx. 8 oz. Doesn't seem large enough to me?
Also, I read in another thread that the Kyosho 90 Spit has a problem with the covering not being fuel proof. Have you seen any problem with the 50?
Larry
Old Oct 20, 2008, 03:37 AM
Joined Jun 2008
no problems with covering at all so far all looks good..
Have not changed tank yet but will be doing so,
It is abit to small..Flight time is abit short..
Old May 09, 2009, 02:46 PM
Joined Jan 2009
Gms 2000 0.47 Or Os Max 55ax ???
Hi guys.
What do you think, what engine will be better for Spitfire 50 KYOSHO ?
1) GMS 2000 0.47 RN - 485g (1.47 KM)
or
2) OS MAX 55AX - 520g (1.74 KM)
I'm waiting for opinion.
Best regards
Peter
peter2102 is offline Find More Posts by peter2102
Old May 09, 2009, 03:18 PM
uk
Joined Oct 2007
none of those, it needs a four stroke!!!
my saito 62 flies it scale like, 72 would be great too
mk1spitfire is offline Find More Posts by mk1spitfire
Old Jul 01, 2014, 02:43 AM
Joined Jan 2009
Os max 55ax
My flies with OS MAX 55AX. It was best decision. Bravo.
My one (6 years old) is still alive ! ! !
Besrt regards
Old Jul 01, 2014, 05:19 AM
Tobbe
Twistringen
Joined Oct 2008
Well done Peter2102! My only got some month old. But I bought a new one.
Discussion best 4 stroke engine for a cessna 50 Erwin Z Fuel Plane Talk 3 Aug 12, 2007 05:25 PM
Discussion Alternative engine for Kyosho's Ferrari F2004 1/8 dshakes Large Scale Cars 0 Nov 30, 2006 07:32 AM
Discussion New to glow, what engine for Kyosho 109? patrick181 Fuel Warbirds 16 Sep 11, 2006 09:37 PM
Discussion Engine for Kyosho SQS 40 Warbird? JTF Fuel Warbirds 9 Sep 01, 2006 05:11 PM
Wanted: Fuselage for Kyosho Spitfire .40 ARF iceman857 Aircraft - Fuel - Airplanes (FS/W) 0 Jun 04, 2002 06:42 AM
