Old Jul 05, 2014, 07:28 PM
Toaster, not Toast
United States, OR, Portland
Joined Feb 2014
Pretty cute there. I hope it flies nicely for you. Try to get some action photos or video.
Toastermoore is offline Find More Posts by Toastermoore
Old Jul 06, 2014, 02:41 PM
dsteele37's Avatar
United States, WA, Olympia
Joined Jul 2011
Description:
Description:
Description:
Description:
My latest "design". I use quotes because I took about 4 different planes and shoved them together. Mainly the UM polecat, with it's wings and tail feathers.
Was definitely a fun build, and I was worried about using the UMX radian's propeller, but it works just fine with some glue added to the AP03's shaft to make it snug on the propeller.
It flies and handles just like the UM polecat, just way more fun because it's homemade obviously!
AUW is just over 39grams with a 250mah
dsteele37 is offline Find More Posts by dsteele37
Old Jul 06, 2014, 08:48 PM
Toaster, not Toast
Joined Feb 2014
Looks fast. Does it glide at all?
Old Jul 06, 2014, 10:20 PM
dsteele37's Avatar
Joined Jul 2011
Glides a bit. I scaled the wing area up to about 57 square inches, which brings the cubic loading to around 5.5. Definitely handles some wind though!
Old Jul 06, 2014, 11:55 PM
Death Drops are awesome.
Sabin's Avatar
Canada, BC, Sechelt
Joined May 2008
How'd you link the elevator to the servo?
Sabin is offline Find More Posts by Sabin
Old Jul 07, 2014, 12:52 AM
dsteele37's Avatar
Joined Jul 2011
Pretty much took the idea from the UMX ask-21, and it's quite effective. The backwards swept tail helps as well, from not having such a steep angle to bend the push rod, though it is possible to do a full 90 degree turn at this size.
One of my small protractors had the perfect radius I needed so I laid it on the surface and scored 1mm deep or so. Then used some 2mm plastic pushrod guide tubes and cut 2 small pieces, gluing them on at the exact angle needed to be inline with elevator.
Very very small piano wire was used to create a connection between the wire and the elevator. I used pliers to hold the piano wire and a t-pin right next to eachother, then wrapped the wire around the t-pin to creat an open cylinder for the wire holding each elevator half to fit through.
Old Jul 07, 2014, 11:14 AM
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
Originally Posted by Waffleman View Post
So I have a spare AR6400 and some small motors from a hubsan X4 quadcopter.
Do you guys think two of those would overload the single ESC?
If they don't... then there is something I want to try...
This has got to be the coolest thing ever run by an AR 6400 if you do it!
Saxguy1000 is online now Find More Posts by Saxguy1000
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 126 Mar 26, 2013 06:30 AM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
Gallery Show off your planes texan Wimberley Valley Flyers 4 Apr 13, 2006 02:10 AM
