Old Mar 13, 2015, 03:36 PM
Leo Henriques's Avatar
United States, FL, Placida
Joined Apr 2011
Originally Posted by JONBOYLEMON View Post
Yes, d47 tails only!!
+ 1000 and I also throw hard enough
Leo Henriques is online now Find More Posts by Leo Henriques
Old Mar 13, 2015, 07:39 PM
Soyrico's Avatar
United States, CA, Hollister
Joined Jan 2006
I received one of the kits above that came with this new "linkage" but haven't been able to find any installation documentation for the bag of included Macgyver parts.
I found the wing installation section which was easy.
I post a over all review soon.
Soyrico is offline Find More Posts by Soyrico
Old Mar 14, 2015, 12:19 AM
United States, AZ, Arizona City
Joined Sep 2001
Let us know when you figure out what the long skinny white "H" part in the plastic bag is used for????
GaryO is offline Find More Posts by GaryO
Old Mar 14, 2015, 05:00 AM
Joined Aug 2009
i just send the manuals to oleg , he will mail them to everyone.
krikkens is online now Find More Posts by krikkens
Old Mar 14, 2015, 05:05 AM
Joined Aug 2009
Originally Posted by GaryO View Post
What is the current thinking on servos on the XXLite? D-47's? I want to use 1S lipo.
i tried 4 ds75k's in it and i'm very happy with it (1s lipo, no booster)
the ds75k can be mounted in the supplied servotray (same way like the d47)
in the past i tried d47 with stock springs on the tails but they where very slow to the side the spring pulls.
but i used the 3th hole on the d47 .
last builds i used the first hole on the d47 horn and increased my end point , haven't tried it on 1s but as others comment it should work well on 1s.
Old Mar 14, 2015, 07:41 AM
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
I only use the d47 at the first hole with 150% on the end point. This way it's strong enough. I also use 1S and it works just fine.
The ds75 looks good but costs 3 times more than a d47...
roydor is offline Find More Posts by roydor
Old Mar 14, 2015, 08:35 AM
Joined Aug 2009
i like the ds75k's very much , if one would use pushrod driven tails i would certainly recommend those .
on pull-spring (which i always use) d47 are just perfect.
Old Mar 14, 2015, 01:50 PM
Soyrico's Avatar
Joined Jan 2006
Will do Gary, That H piece has me scratching my head too. Maybe a battery strap of some sort???
Waiting for Oleg to send email. Hopefully soon. Looks like Gmail servers are down.
Old Mar 14, 2015, 02:19 PM
Joined Sep 2001
Krikkens,
What is the "H" shaped piece (white) with the hole in the middle used for? Can't figure out what to do with it.
Can't you just post the new instructions? If you mailed to Oleg, and he mails to us, it's not going to get in our hands very quickly
Old Mar 14, 2015, 02:32 PM
Joined Aug 2009
Krikkens,
hi ,
manuals will be in post 1 in a few minutes...
the H piece you refer to must be the aileron servo tray , just like the old rectangled one but with more material removed en thus lighter.
Old Mar 14, 2015, 04:02 PM
Full disclosure, not sponsored
JONBOYLEMON's Avatar
United States, UT, American Fork
Joined May 2002
Flew my trusty old XXL today in very tough dynamic conditions. She did very well!!!!! Really love the XXL, wish she was easier to pack and travel with!!!! Interested to see how the new flaperon connection works out.
JONBOYLEMON is offline Find More Posts by JONBOYLEMON
Old Mar 15, 2015, 08:32 AM
Joined Aug 2009
dan,
please contact me (pm) again , i cleared all my messages and don't know how to reach you
Old Mar 15, 2015, 07:20 PM
Joined Sep 2001
Nice set of instructions. I'm a bit confused (nothing new) about Item 8 in the fuse build. It says:
8. Put a mark (line) inside the fuselage at 136mm from the nose tip , screw the M3x25mm bolt in the servo tray (screw it in all the way , the bolt will protect the threaded hole from glue) , glue it in with epoxy , the bolt hole on the 138mm mark , make sure it runs centered and the bolt stands up straight.
In one spot it refers to 136mm, the next it refers to 138mm. Should they both be the same? If so, which one?
Old Mar 16, 2015, 02:57 AM
Joined Aug 2009
138 is correct , i'll fix it.
