Old Feb 23, 2015, 06:46 PM
ren3 is offline
Find More Posts by ren3
Joined Nov 2005
Futaba S9156 Digital servo
In a previous post here, Futaba tech service said that the S9156, while digital, is not programmable. The "digital" only refers to the pulses controlling the motor. I am trying to use an S9156 to control a trim tab on a 60" sailboat keel. I only want 2-3 degrees of deflection from center, and the servo will be in a "Y" harness with the S9156 servo controlling the rudder which will have it's normal end points. Is it possible to use an inline servo end point controller such as the one from ServoCity? I know that this controller is designed for analog servos, but where does analog and digital separate. I am trying to use the S9156s because I want the high torque available with their small physical size. Thanks for your help. Bob.
ren3 is offline Find More Posts by ren3
Old Feb 24, 2015, 04:11 AM
MattyB is online now
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
Why not put the main rudder and trim tab servos on separate channels, and control everything with the appropriate mixes and end points in the TX? Far easier and a more optimal control setup too.
MattyB is online now Find More Posts by MattyB
Old Feb 24, 2015, 11:55 AM
ren3 is offline
Joined Nov 2005
Matty, thanks for the suggestion. I have a feeling that I will have to do that, but the idea originally was to have the trim tab deflect ever so slightly when the rudder was actuated without affecting full rudder throw. The America's Cup boat Courageous used this system in the seventies, and my hull is a model of it. Even if I use a third channel on my Futaba 3EGX radio that has been converted to 2.4GHz Faast Futaba, I do not know if I can control the trim tab rotation to only 2-3 degrees. Bob.
Sold 1/2 price of new - Futaba S9156 Hi-Torque Digital Servos (Refurb) bobzilla Aircraft - General - Radio Equipment (FS/W) 2 Jan 15, 2015 08:59 PM
Sold (8) Futaba S9156 Hi-torque Digital Servos bobzilla Aircraft - General - Radio Equipment (FS/W) 0 Jan 09, 2015 10:04 PM
Sold Set of 3 FUTABA S9156 DIGITAL/HS/HT Servo's ZIIguy Aircraft - General - Radio Equipment (FS/W) 2 Jan 07, 2014 07:49 PM
For Sale Futaba S9156 High Torque servo cheap! ATCH Aircraft - General - Radio Equipment (FS/W) 0 Nov 02, 2013 12:38 PM
Sold NEW Six (6) Futaba S9156 Digital High-Torque Air Servos Matt Gunn Aircraft - General - Radio Equipment (FS/W) 1 Jul 27, 2010 05:06 PM
