Old Sep 03, 2014, 04:40 PM
DownUnderPilot is online now
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Build Log
Composite Fuse
Hi all,
Just wanted to share my success with making a fuse mould for my speedplane. It's approx 1.2M long and is designed for Speedcup style flying. I made the plug using 5mm MDF laminated together with coloured wood glue for ease of shaping.
The mould is made with a tooling coat using graphite powder and high density filler and ATH, and the backing is a poured layer of resin / ATH. This is a really fast way to make a mould!
Next is the h stab....
Dean.
DownUnderPilot is online now Find More Posts by DownUnderPilot
Old Sep 03, 2014, 05:13 PM
arcticflyer is online now
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
If you produce any extras would be interested Looks good what will the overall specs be on the airframe?
arcticflyer is online now Find More Posts by arcticflyer
Old Sep 03, 2014, 05:20 PM
Joined Mar 2006
Unlikely I'll be building extras at this point - it's a long way off before a completed airframe is ready I think.
The design is to allow 50mm spinner on the front, 40-XX outrunner or whatever else you can fit in there... Lipo carrying capacity will be up to approx 12S 3000. Wingspan is likely to be in the 1.6m area, T tail and wing saddle fillets for minimised drag. Wing 'foil is MH-54, tail airfoil is SD-8000.
Construction will be whatever is required I guess - I'm going to lay up a fibreglass trial and see how heavy/strong it is. I have "adequate" stocks or carbon and kevlar for improved strength / weight....
Old Sep 03, 2014, 05:53 PM
D.English is offline
Find More Posts by D.English
Hemet California
Joined Jul 2009
Nice! you will really enjoy making your own
DE
D.English is offline Find More Posts by D.English
Old Sep 04, 2014, 10:19 AM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Looks nice
How will you key the mold haves together? I don't see any holes or dimples.
Steve C is offline Find More Posts by Steve C
Old Sep 04, 2014, 03:24 PM
Joined Mar 2006
Originally Posted by Steve C View Post
Looks nice
I knew someone would ask!! - well spotted - actually they are there, on the right hand side - holes for dowels. Also the other half of the mould has a small flange that allows for positioning.
I'm attempting the first layup tonight, opinions please on the layup - would 48g/100g/200g/100g glass be sufficient? More? Less? It's a trial really to establish my technique and also determine if it would be strong enough.
Old Sep 05, 2014, 02:15 AM
blitzu is offline
Find More Posts by blitzu
The Prop is Where its At!
blitzu's Avatar
New Zealand, Bay Of Plenty, Omokoroa
Joined Dec 2012
Sorry Skip-Kiwi's first!
blitzu is offline Find More Posts by blitzu
Old Sep 05, 2014, 09:34 AM
Joined Jan 2006
Hey!....he needs a tester
Old Sep 05, 2014, 10:58 AM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
What is ATH? Poraver, sand/silica, ....?
Troy is offline Find More Posts by Troy
Old Sep 05, 2014, 01:45 PM
Joined Mar 2006
ATH is alumina trihydrate, it can be mixed with resin to create a really stable and strong mould backing. Du pont calls their version of it Corian, it's used for bench tops.
It's mixed to a consistency of runny honey and then you just pour!
Old Sep 05, 2014, 03:14 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Beach Sand, plenty and free!
Dean, I'm getting practice on double layer winding!
ApexAero is offline Find More Posts by ApexAero
Latest blog entry: no comment
Old Sep 05, 2014, 03:24 PM
Troy is offline
Troy's Avatar
Joined Feb 1999
Just got the scoop from our chemist... your mold is also very fire resistant now, too
I guess it's not as hard as silica so it might be considered less brittle as a highly filled system. It's also low cost, so good to learn something new today.
Old Sep 05, 2014, 04:31 PM
Joined Mar 2006
Originally Posted by apexaero View Post
beach sand, plenty and free!
Dean, i'm getting practice on double layer winding!
Old Sep 05, 2014, 05:37 PM
ptxman is offline
Find More Posts by ptxman
Calgary, AB, Canada
Joined Oct 2002
Also seems to be getting some negative press with lengthened exposure to workers, so I guess exercise caution working with the raw powder.
http://www.nejm.org/doi/full/10.1056/NEJMc1404786
Just curious, does it react with the resin to increase exotherm temp, or would it be the same temp as any other typical silica type filler?
ptxman is offline Find More Posts by ptxman
Old Sep 05, 2014, 06:17 PM
jackosmeister is online now
Find More Posts by jackosmeister
Non Eius A Stupri Fucus
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Looks badass DUP
jackosmeister is online now Find More Posts by jackosmeister
Sold JTM Viper Jet Teng 90mm Composite wings/fuse w/TJ90 & Tamjets Retracts Alkaline Aircraft - Electric - Jets (FS/W) 4 May 21, 2014 09:16 PM
Sold NIB 50 size Spitfire ARF (composite fuse /balsa built-up wings) storm57 Aircraft - Fuel - Airplanes (FS/W) 2 Mar 24, 2014 03:11 AM
Laying up a composite fuse flusterfly Slope 6 Nov 07, 2005 02:15 AM
F16C 90mm edf plug for composite fuse TGoodwin Electric Ducted Fan Jet Talk 715 Jul 14, 2004 10:54 AM
Retiring my wood LiteSik fuse for composite rod....ideas? pullin-gs Parkflyers 2 May 02, 2001 11:02 AM
