Old Oct 30, 2012, 01:26 PM
Mmacro is offline
Find More Posts by Mmacro
Joined Sep 2012
Help!
Futaba T7C and Novatech RTR-12
I got a second-hand Axial and got it all hooked up. It turns left and right... And the throttle moves it forward. But I'm having problems.
The steering is backwards, and I know I can easily reverse it. But the throttle does not reverse. If I turn it on with the throttle arm in the middle it goes forward when the arm is pulled. When set to the extreme it will go forward. But I can not get the arm positioned to go in reverse. And advice?
Mmacro is offline Find More Posts by Mmacro
Old Oct 30, 2012, 08:03 PM
Mmacro is offline
Joined Sep 2012
Ok... Discovered that I have to pause in neutral before it goes into reverse.
But I'm also having problems with the servo turning hard right when I turn it on. ???
Old Oct 31, 2012, 07:05 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Is the transmitter turned on before the car?
wparsons is offline Find More Posts by wparsons
Old Nov 02, 2012, 07:06 AM
Mmacro is offline
Joined Sep 2012
I have tried it both ways...
Old Nov 02, 2012, 09:19 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Does the servo return to center after a second?
You should NEVER have the car turned on without the transmitter on, without a signal it could glitch or run away on you.
Old Nov 02, 2012, 09:39 AM
Mmacro is offline
Joined Sep 2012
No... The servo keeps trying to hold the right turn.
I know about turning it on after the transmitter is on... And off before you shut down the transmitter. But in the process of elimination I wanted to try it both ways to see if there was any difference in action. Either way the servo goes right.
Old Nov 04, 2012, 06:56 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Does it respond at all, or just goes to full right and stays stuck?
If it's responding the servo arm was probably just put on without the servo centered.
Old Nov 06, 2012, 05:58 PM
Mmacro is offline
Joined Sep 2012
I thought of that also. I removed the arm and turned it on and let the servo center and then reattached the arm. It worked for a short time. But after turning it off and then back on it started to do the right turn thing again.
It responds; kind of. It tries to turn left but stops before it even gets to center. And when I let off it returns to trying to turn right.
Old Nov 07, 2012, 06:35 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Check to see if the arm is skipping on the output gear of the servo, or if there's any stripped teeth inside the servo (if you rotate the arm you'll hear/feel it).
Discussion Flaperon & Futaba T7C KiloMeater Beginner Training Area (Aircraft-Electric) 16 May 15, 2012 10:13 AM
Found Futaba T7C hbsurfer Aircraft - General - Radio Equipment (FS/W) 4 Apr 30, 2012 09:27 PM
Sold Futaba T7C 2.4 Complete System W/R617FS RX & 4) S3004 Servos NIB $265.00 SHIPPED!!! stevster Aircraft - General - Radio Equipment (FS/W) 1 Apr 18, 2012 11:28 AM
Discussion Where to find a DSM2 Module for Futaba T7C? Daddio327 Radios 2 Mar 29, 2012 04:25 PM
Sold Futaba T7C 2.4 FASST Tx & 2 Rx Mr.Greenjeans Aircraft - General - Radio Equipment (FS/W) 2 Feb 23, 2012 09:40 PM
