Old Jan 26, 2014, 01:39 AM
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
New Air Hogs Zip Wing powered glider
I saw this at Target for 14.99 and being an AH fanatic, I had to get it.
it features a 22" wingspan motorized foam on carbon fiber body with a folding prop. In all a good concept design; however, I couldn't understand why AH opt to use AAA batteries. AAA's are notoriously heavy.
I made sure to use 2 new fresh Duracell AAA (both measured 1.57v). I also made sure all surfaces were straight and true. The installation was straightforward. Just plug the wings in, then tape it in, plug the stabilizer in, tape it in. Done.
unfortunately, with the weight of the AAA batteries, it felt very heavy for it's size. The airframe came out to 40grams, and the batteries were 22 grams for an AUW of 62 grams. I did roughly 10 flights, each time making adjustments and they all failed. Conclusion - it's simply too heavy to fly.
I've flown many, many AH planes, and this is the first AH plane that I'm disappointed in.
well, check it out...
Air Hogs Zip Wing crash, crash, crash! (4 min 8 sec)
rcalldaylong is offline Find More Posts by rcalldaylong
Old Jan 26, 2014, 02:49 AM
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Why not just stick lipo's in and eliminate the problem.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Latest blog entry: Some Books About Flying
Old Jan 26, 2014, 03:31 AM
Kamov's Avatar
CA
Joined May 2007
banks to the left…..maybe its from propeller/motor torque ? or the wing trailing edge need to be adjusted to compensate or maybe some rudder adjustment …also check the cg
and yeah put a small 1 cell lipo on that at 3.7 volts it will probably work no problem
Kamov is offline Find More Posts by Kamov
Old Jan 26, 2014, 10:02 AM
pjdog350's Avatar
Joined Apr 2013
I'm with Kamvo. I think she want to fly with a left back. Check the balance. See if she's heavy on the left side. If that proves to be good then it could be a wing warp. Work a little trim tab to raise that left wing.
Now all you have to worry about it will it fly away. I'd rather have a plane that goes for a second than crashes than a plane that just flies away.
I had a friend (Dick Garrett) in Indianapolis, Indiana that had a little plane he built that flew free flight. He fired it up and gave it a through. It circled up to where it looked like a little dot on a piece of paper. Then the motor stopped. The wind was from the north. The plane headed straight when the motor stopped and it was on it way to Kentucky. Dick and his son floowed it for a while until they ran out of road to stay with it. So that;s what I meant about I'd rather have a crash than a fly away.
I use to trim my planes so that the had a little down and little left or right so If the single failed they would at least be in the area.
You could go to plan 'B'. Put a small RC brick in it for RC and use 1S battery. Looks like most the work has already been done.
Now that I'm in my seventies most my RCing is building rather than flying. I've really lost my skills. But I can still do RC helicopters at least.\
Good luck with it. Maybe I'll get one and do the RC mod to it.
jack
pjdog350 is offline Find More Posts by pjdog350
Latest blog entry: 4 new AR6100E from Target Hobby
Old Jan 26, 2014, 10:05 AM
Joined Dec 2007
I'm sure I could make it fly with some mods, but the goal of the review/vid was to fly it as is, vanilla out of the box provided by AH; And as is, this thing will never fly.
I've tried many things, and I'm quite sure the banking is just the porky weight causing it to stall and bank left.
I've tried putting in rudder to compensate at no avail.
also, there's very little torque on the motor
anyhow, just thinking aloud, but if I can't make it fly, just imagine all the soccer moms buying it for their kid.
Old Jan 26, 2014, 10:39 AM
Eugene, Oregon
Joined Apr 2009
Looks like a great conversion candidate to me
elvill is offline Find More Posts by elvill
Old Jan 26, 2014, 11:12 AM
Joined Dec 2007
Agreed! that's probably what I'm gonna end up doing to mine. Either that or it's going back to Target.
on a side note, if anyone picks one up and gets it to fly vanilla, pls get vid before you convert.
Old Jan 26, 2014, 03:28 PM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
thanks for the review. too bad it didn't go well but you showed a lot of patience.
cmdl is online now Find More Posts by cmdl
Old Jan 27, 2014, 01:41 PM
Eugene, Oregon
Joined Apr 2009
depending on how the wings connect to the fuse - looks like it could be a wingeron candidate with regular rx, 5g servos and 2s 5g or 10g bl motor
Old Jan 27, 2014, 02:49 PM
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Looked like tipstalling to me. ?
But if it worked looks like it'd be a fun toy.
And those Airhogs AeroAces are what got me started in RC Flight. They were unbelievable and awesome for thier time.
kenstogie is offline Find More Posts by kenstogie
Old Jan 27, 2014, 04:06 PM
Joined Dec 2007
Oh yea! Don't get me started on the AA
God knows why AH discontinued those.
Anyways, yes it does look like tip stalls. The thing is just too heavy and not enough power. Wish AH would of put a 1s in it...would of been fun.
I hope they don't repeat what Estes did- that is make gorgeous airframes that never got off the ground.
Old Jan 27, 2014, 04:34 PM
Eugene, Oregon
Joined Apr 2009
here is one of those Estes airframes that did make it off the ground
Avengers Glider to RC Conversion (2 min 9 sec)
Old Jan 27, 2014, 05:22 PM
Joined Dec 2007
http://www.youtube.com/watch?v=nUexmdp2gpc&safe=active
Nice! LOL! Estes only gets off the ground with lots of help.
Here's my Estes Blue angel twin converted:
estes blue angles with a brushless motor (0 min 16 sec)
Old Feb 02, 2014, 12:28 AM
Eugene, Oregon
Joined Apr 2009
completely gutted the airframe 18g
going v tail with 5g bl
300 2s
ar6400 for control
should make an decent glider conversion
Old Feb 02, 2014, 04:04 AM
Weltherrschaft will be mine
Germany, SN, Leipzig
Joined Nov 2012
it looks like made for a brick and 8mm gearbox conversion... a shame they arent sold in germany yet, would love to have one
borkencorter is offline Find More Posts by borkencorter
Discussion Air hogs glider w/e-power chuckds RC Toys 1 Dec 22, 2013 09:28 PM
New Product Hawk wing 286 B delta wing powered glider justeyfly Foamies (Scratchbuilt) 0 Dec 10, 2013 01:19 PM
Discussion air hog glider wilf370 Foamy EDFs 0 Nov 11, 2013 01:18 PM
Discussion Air Hogs Titan Glider Power Conversion JettaManDan Pusher Prop Jet Models 11 Feb 22, 2011 07:57 AM
Sold Bunch-o-micro (single wing, air hogs, air hogs helis) for sale! (PRICE DROP!!) Sherlock Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 18 Feb 04, 2010 10:13 PM
