Old Jan 07, 2014, 01:14 PM
Joined Dec 2012
Help!
Quad build help for FPV
Hey!
I wanted to ask, what frame you would recommend best for FPV, aerial photography?
And what you would say about this setup? Maybe i should change something?
KK 2.1 control board
http://www.hobbyking.com/hobbyking/s...mel_644PA.html
ESC - http://www.hobbyking.com/hobbyking/s...202&aff=398199
Motors - http://www.hobbyking.com/hobbyking/s...247&aff=398199
Battery - http://hobbyking.com/hobbyking/store...dProduct=10383
Props - 10x4,7 http://www.hobbyking.com/hobbyking/s...on_Black_.html
11x4,7 http://www.hobbyking.com/hobbyking/s...7SF_4_pc_.html
http://www.hobbyking.com/hobbyking/s...ion_4_pc_.html
chip22 is offline Find More Posts by chip22
Old Jan 07, 2014, 04:27 PM
Joined Dec 2012
Forgot to mention, that i am planning to take up pretty heavy camera (200gr).
Old Jan 08, 2014, 01:59 AM
4props's Avatar
United Kingdom, England, Cressing
Joined Oct 2013
My parts came from Hobbyking UK warehouse, you pay a slight premium for using the UK warehouse although it is not enough to worry about. The KK2.1 is only available from the International warehouse at the time of writing.
Motors
NTM Prop Drive Series 28-26A 1200kv / 250w (short shaft version) http://www.hobbyking.com/hobbyking/s...84&aff=1174941
Motor Mount
NTM Prop Drive 28 Series Accessory Pack http://www.hobbyking.com/hobbyking/s...19&aff=1174941
Flight Controller
KK2.1 http://www.hobbyking.com/hobbyking/s...54&aff=1174941
ESC (speed controllers)
Hobby King 30A ESC 3A UBEC http://www.hobbyking.com/hobbyking/s...54&aff=1174941
Props (you need 2 right hand rotation and 2 left hand rotation for a Quadcopter)
Slow Fly Electric Prop 1045R SF http://www.hobbyking.com/hobbyking/s...49&aff=1174941
Slow Fly Electric Prop 1045SF http://www.hobbyking.com/hobbyking/s...42&aff=1174941
my preferred props are the 8″
Slow Fly Electric Prop 8045R http://www.hobbyking.com/hobbyking/s...34&aff=1174941
Slow Fly Electric Prop 8045R SF http://www.hobbyking.com/hobbyking/s...35&aff=1174941
Battery
Turnigy 3300mAh 3S 30C Lipo Pack http://www.hobbyking.com/hobbyking/s...00&aff=1174941
Frame
Q450 Glass Fiber Quadcopter Frame 450mm http://www.hobbyking.com/hobbyking/s...27&aff=1174941
I bought 6 motors, mounts and ESCís. The motor mounts sometimes are out of balance, having a couple spare doesnít hurt. Having a couple of spare motors and ESCís doesnít hurt one bit.
You will also need the following
Male to male servo wires (used to connect the receiver to the KK2) http://www.hobbyking.com/hobbyking/s...147&aff=117494
Bullet connectors (3.5mm) to connect the ESC to the motor (3 per ESC) http://www.hobbyking.com/hobbyking/s...28&aff=1174941
Male battery connector (this will depend on your battery connector type), leads with power are always female. http://www.hobbyking.com/hobbyking/s...77&aff=1174941
Silicon wire AWG12 (to solder to the battery connector which is then soldered to the frame)
Hex Screw M3x12 screws (to fix the motors to the frame, the supplied ones are not strong enough) http://www.hobbyking.com/hobbyking/s...94&aff=1174941
Things you may want
A prop balancer, out of balanced props cause havok with multi-rotors and will most certainly effect the quality of the video.
5.6mm x 10mm M3 Nylon Tapped Spacer http://www.hobbyking.com/hobbyking/s...70&aff=1174941
M3x8 Nylon Screws (for fixing the KK2) http://www.hobbyking.com/hobbyking/s...81&aff=1174941
Battery strap http://www.hobbyking.com/hobbyking/s...74&aff=1174941
Velcro (for sticking to the battery to hold it in place Ė in addition to the battery strap) http://www.hobbyking.com/hobbyking/s...04&aff=1174941
For the best performance the KK2 should be flashed with the latest firmware and the ESCís flashed with SimonK firmware. This allows the KK2 to give you the best response and self-levelling and the ESCs to perform to their best ability. The difference is really noticeable. It does require the purchase of a USB tool however the cost is far outweighed by the different in the performance of the Quadcopter.
4props is offline Find More Posts by 4props
Old Jan 08, 2014, 10:28 AM
Joined Dec 2012
What ESCs you would recommend without flashing myself? One of these will be ok?
http://hobbyking.com/hobbyking/store...Firmware_.html
http://www.hobbyking.com/hobbyking/s...364&aff=171252
So i need USB tool for KK2?
Old Jan 10, 2014, 05:25 AM
Joined Dec 2012
What control board you would recommend instead of KK 2.1?
Old Jan 10, 2014, 05:35 AM
4props's Avatar
Joined Oct 2013
The afro ones are really good, or you can buy the RCMan Child ones which are meant to be really high quality
http://rcmanchild.com/escs.html
You may find it easier to buy a KK2 already flashed on ebay etc.. saves having to buy the tool and mess around with flashing it yourself.
Old Jan 10, 2014, 05:38 AM
4props's Avatar
Joined Oct 2013
It depends on budget and tech level.
The Naza is expensive but more or less plug and play (although you must follow the instructions of you end up with a fly away)
The MultiWii offers a lot of functionality but requires more tech to get setup correctly.
Old Jan 12, 2014, 06:00 PM
Joined Dec 2012
What you would say about - AIOP V2.0 ALL IN ONE PRO Flight Controller ?
Old Jan 12, 2014, 07:28 PM
Loveable rouogh
Joined Nov 2013
good board, steep learning curve to get it going, runs miltiwii or megapiratsng, both are not plug and play systems,
CreativeGirl is offline Find More Posts by CreativeGirl
Old Jan 13, 2014, 02:07 PM
Joined Sep 2013
Motors
Motor Mount
Flight Controller
Battery
Frame
Things you may want
I have the same motors and esc's and ive found that 9x5 inch graupner props are really great but im not sure if they can take 10 inch props for too long. If, make sure you use 4s when flying with 10 inch props with those motors.
You learn the best from experience so try it out yourself
JumpTyw00p is offline Find More Posts by JumpTyw00p
Old Jan 13, 2014, 02:19 PM
4props's Avatar
Joined Oct 2013
I ran 10" props for quite a while with no problems at all, temp etc.. was all OK and I tested the current load. What problems did you see?
I moved to 8's and have not gone back. I like the way it handles with 8's. I am looking at the graupner's after my HK props shattered mid air on Sunday due to the cold
I found it with one motor buried about 2" in the ground Took me a while to get it out lol
Old Jan 15, 2014, 02:46 AM
Joined Jun 2008
1200kv + 8" props on a 4cell battery is a great combo.
Multiwii has been better for me than kk2, smoother. And I like how easy it is to change code and muck around with things.
Witespy flip 1.5 is a good starting point for Multiwii.
dogz85 is online now Find More Posts by dogz85
Latest blog entry: Dji naza v2
Old Jan 15, 2014, 08:27 AM
Joined Sep 2013
Im running 9 inch props on 3s and the motors dont even get warm. Im considering upgrading to some 10 inch props. Like i said, i read about it that people were over loading the motors with 10 inch and that they would get burn outs (burn out the motors). A quick look inside with a soldering iron should fix that ?
I would suggest them with 9 inch props as you get a tiny bit more efficiency and enough power!
Cheers
Old Jan 15, 2014, 08:31 AM
4props's Avatar
Joined Oct 2013
I have to be honest I didn't see any problems with heat etc.. but everyone's mileage can vary.
I have rebuilt my quad with 9", I get really good flight times with the 8's so will be good to see how the 9's work out.
Build Log Building first quad need help shortbus1989 Multirotor Talk 13 Feb 12, 2014 08:56 PM
Question 1st Quad Build - Need Help w/ Parts SiliconKnight Multirotor Power Systems 1 Sep 21, 2013 09:22 AM
Discussion need help build my first quad for long range fpv adam88888 Multirotor Talk 24 Jan 20, 2012 06:50 AM
Discussion Tri or Quad build help (Gopro + FPV) xe2bls Multirotor Talk 7 Nov 08, 2010 04:37 PM
