Old Dec 09, 2014, 03:16 PM
Joined Nov 2014
HELP ! Flip 32 Problem.
Hello,
I have a problem.
I have a Flip32 for my ZMR250. I did all the calibrates on BASEFLIGHT, my Receiver (AR610 from DX6) is ok, Roll Pitch Yaw Throttle are moving up and down when i move my sticks in the Receiver page.
I did some motor test, they all rotate in the good way (CW/CCW).
My problem is, when i unplug my Flip32 from my computer, and try to fly the quad with my Radio. That's not working AT ALL. Nothing happens.
Am i missing something ?
Would appreciate some help.
Khyss.
Khyss is offline Find More Posts by Khyss
Old Dec 09, 2014, 03:26 PM
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
Is it getting power?
waltr is online now Find More Posts by waltr
Old Dec 09, 2014, 03:38 PM
Joined Nov 2014
The Flip32 and the receiver got power, yes.
Old Dec 09, 2014, 04:20 PM
Joined Nov 2014
Some informations i forgot to give :
I got 3 flights modes on one switch, i can see them moving when i change my switch's position into the Mode Selection page...
Old Dec 09, 2014, 06:20 PM
Team WarpSquad
Joined Jan 2014
So an LED on the FC and RX light.
Did you look up and check all the question asked for all the typical beginner errors?
ESC cal?
Stick End Point values in the config?
stick center values?
ARMing?
Old Dec 12, 2014, 07:46 AM
United States, CA, Huntington Beach
Joined Jan 2013
Hello,
I have a problem.
Khyss.
did you resolve your issues, if not I may be able to help. Post a close up picture of your install, make sure all connections are shown.
hoggdoc is offline Find More Posts by hoggdoc
Old Dec 13, 2014, 04:22 AM
United Arab Emirates, Abu Dhabi
Joined Dec 2014
I have the same problem , I test the receiver and the motors on baseflight every thing fine .
When I unplug the usb and raise the throttle nothing happen ..!!!!
mhd3000 is offline Find More Posts by mhd3000
Old Dec 13, 2014, 07:36 AM
Joined Dec 2014
I think I have problem with my transmitter
I dont know why the roll is 1285 , and when i raise the throttle it changes the roll value .
See attached pics
Old Dec 13, 2014, 11:15 AM
Joined Dec 2014
See attached pics
Resting the transmitter and this problem is gone .
Old Jan 14, 2015, 07:10 PM
Joined Jan 2015
I have the same problem. Does "resting" the transmitter mean "resetting"?
I tried this too, but it didn't work. Any ideas would be very welcome!
jaymcfay is offline Find More Posts by jaymcfay
Old Jan 14, 2015, 09:08 PM
Team WarpSquad
Joined Jan 2014
In those screen shots the TX values are all wrong.
A TX Reset may help but then one still needs to properly setup the Stick center and end point values.
Old Jan 23, 2015, 02:27 PM
Joined Jan 2015
I think I worked out the problem. I had my Turnigy 9x set on HELI mode. If you switch to ACRO mode everything looks fine.
joshm549 is offline Find More Posts by joshm549
Old Mar 27, 2015, 06:41 PM
United States, GA, Bremen
Joined Feb 2015
I had the same problem as OP. I'm a newbie. Turned out I needed to set a switch on my Taranis tx to arm the FC
Thebridge is offline Find More Posts by Thebridge
Old Mar 27, 2015, 06:50 PM
Team WarpSquad
Joined Jan 2014
If the Stick End Point values are properly setup in the TX then you do not need to use a switch to ARM. It will ARM from stick commands.
Do a lot more reading about MultiWii, the MultiWii WIKI and the CF Docs in github as well as the thousand threads on this subject to learn how to properly setup the TX sticks.
Discussion Flip 32+ cruiser73 Multirotor Electronics 559 Today 06:52 PM
Wanted Naze32 Acro/Flip 32+ akcom Aircraft - Electric - Multirotor (FS/W) 1 Jul 02, 2014 12:46 PM
Sold Flip 32+ with baro and mag ( right angle pins) CoolD Aircraft - Electric - Multirotor (FS/W) 1 May 12, 2014 07:37 PM
Discussion Flip 32+ xpantz Multirotor Electronics 5 Mar 19, 2014 08:11 AM
Found Flip 32+ flight controller geekness Aircraft - Electric - Multirotor (FS/W) 1 Mar 03, 2014 10:33 PM
