Old Yesterday, 07:07 PM
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Originally Posted by PeterVRC View Post
Now that I think about it.... my first Su-35, on its maiden flight from a football oval (grass of course), and weighed 3.0Kg then, plus it had only 2000W of 6S power, took the entire oval length before it finally leapt into the air. It flew fine, off into the steep climb of that leap, but I never flew it off grass again! A football oval is typically 150m long.
So 4.0Kg off grass is going to have an even harder time. Even though it looks fast enough, it probably isn't.
But amazingly 4.2kg can LAND way slower than that speed! Or can be landed way slower - not a typical landing, but if you want to do it very slow.
because you can capitalize on the lift and braking from the increased AoA with zero ground friction.
But if you're 4.2 kg it's a similar concern we have with the F-16 and big batteries in 8-12S. The basic model starts at 2000W but most in that weight are pushing 2800-2900W out of a single 90mm which is less thrust area than these twins, but is needed to get out of the grass, thrust around 4.1 kg.
That said the wing area is bigger on the F-16 is bigger. Not by much but bigger with a taller stance and a positive static wing profile. So if we're finding it challenging for some off pavement let alone grass it'll be even harder with the 35 that definitely has the TV in its favour.
Add more pitch throw just short of being fully stalled and see if that can't get you your ROG force that you're looking for....
Maxthrottle is online now Find More Posts by Maxthrottle
Latest blog entry: Freewing 90mm F-16C
Old Yesterday, 08:28 PM
Comin' in HOT!
tdford's Avatar
United States, CO
Joined Dec 2012
Originally Posted by Maxthrottle View Post
Down Under physics..... thats what's holding Pete down. Down Under physics.
For what ever reason Pete has a much harder time flying out of grass so all the advise given ain't gonna change his laws of physics.
All tounge and check but Petes a smart enough guy. He's likely already thought about many of our comments before we're about to make them but for some reason I don't think there's anyone else in this forum who has had such repeated difficulty flying from where ever he does off grass. Same as his first model.
Wet grass or grass species cause this model doesn't have that much difficulty breaking free of grass....
He needs to reverse his y-axis.....
It's like the guy that has to play a first shooter with standard sticks (not inverted), then you grab the controller and everything is back asswards.
tdford is offline Find More Posts by tdford
Old Yesterday, 08:36 PM
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Asswards*
Thanks fred, that's gotta be the funniest word I've ever heard
SU-4ever is online now Find More Posts by SU-4ever
Old Yesterday, 09:50 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
that was td's word
fredmdbud is online now Find More Posts by fredmdbud
Old Yesterday, 11:13 PM
teshiecat's Avatar
Australia, SA, Adelaide
Joined Jul 2012
re Pete's maidens - sounds like it should have taken off ok with flaperons, just something wasn't right with pitch settings and/or inputs once it got off the ground.. (like elevator position, tv nozzle position & elev comp for flaperons)
did you have a little bit of up elevator compensation for the the flaperons set? (just a touch)
if you have that footage from you fpv camera it might tell us something.. did it record sound too? (I was thinking we could hear throttle inputs at that moment, plus front view)
mines only a bit over 3kg, but with flaperons it gets up from thickish grass in less than 10m
teshiecat is offline Find More Posts by teshiecat
Old Yesterday, 11:24 PM
teshiecat's Avatar
Joined Jul 2012
btw Physics seems to work fine for me down here in Australia.. or maybe my thumbs and muscle memory have just adjusted to asswardness
good stuff Jandro! looking forward to the footage.. I'd love to see your heli flights too - heli 3d has become my most favourite sort of flying.. I just set up my goblin 500 stretched to 525, with a crazy KDE motor.. sharing 5000 6s packs with my su-35.. it's an absolute beast (though a pack - killer!)
Old Yesterday, 11:55 PM
Antaeus's Avatar
NEWPORT BEACH, CA, USA
Joined Oct 2001
What a deal! Thanks for the Taranis gear. Keep the Euro light. Don't be afraid to slow down that delta wing (of course with power at aoa). You will be surprised how slow it can fly.
Originally Posted by IntheTubeDeep View Post
Picked up a used FW 90mm Eurofighter Typhoon today Thanks Antaeus
Antaeus is offline Find More Posts by Antaeus
Old Today, 12:26 AM
ITTD you're Clear for Takeoff!
IntheTubeDeep's Avatar
United States, CA, San Diego
Joined Jan 2011
Cool, I was looking at fans,
Changesun 90mm Ducted Fan (12 blade)with 1600kv motor
http://x-flight.com.hk/index.php?sp=...&more=&lang=en
XRP90mm 14Blade with 1450Kv Outrunner Brushless for 6s Dynamic Balanced
Supreme Hobbies 90mm EDF 1500Kv (13 Blade) For 6S
XRP 90mm 14 Blade Power Unit 1550Kv is For 6s With Dynamic Balanced !
What you think is the best option?
IntheTubeDeep is online now Find More Posts by IntheTubeDeep
Old Today, 03:23 AM
Österreich, Stmk., Graz-Umgebung
Joined Sep 2011
blade count
Hi, do you know the discription from JePe about blade count? Maybe it could help you to find a sweet combo:
http://www.jepejets.com/jepeshop/fan...90-9-12s-.html
Regards, George
GeorgeStyriaII is offline Find More Posts by GeorgeStyriaII
Old Today, 09:17 AM
High Orbit.....
Joined Jun 2009
Regards, George
wish either he or Jetfan would make this fan in a 70C 72mm version. It looks like a JetFan with a little more pitch to the fans root.
ITTD; show us all your Euro mods over in the Euro thread.
Old Today, 12:59 PM
Antaeus's Avatar
Joined Oct 2001
I would go with the lowest blade count with highest thrust in your search. Just go with a light plastic shroud setup, then it will be very forgiving.
It had flown with a metal shroud stock FW outrunner and the upgraded FW inrunner. Both were heavy and would dropped like a brick if you are paying attention when flying slow aoa.
Old Today, 04:48 PM
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
Old Today, 05:16 PM
Joined Jan 2011
Just came across this
Sukhoi Su-30MKM RMAF Training: Cockpit View 2013 (11 min 20 sec)
Discussion LX F-35 Vs Freewing F-35 Mmarshall Foamy EDFs 17 Jul 09, 2014 06:49 AM
Found SU-34 Freewing lw777pilot Aircraft - Electric - Jets (FS/W) 1 Dec 15, 2013 01:25 PM
New Product Brand New SU-35! 70x2,TV and made by Freewing!Update:Worldwide Availability neversommer Foamy EDFs 593 Jan 09, 2012 09:02 PM
For Sale Freewing SU-34 stock battery - Brand New JGuilty13 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 29, 2011 02:01 PM
For Sale Freewing SU-34 stock battery JGuilty13 Aircraft - Electric - Jets (FS/W) 0 Nov 29, 2011 10:29 AM
