Old Jun 26, 2012, 12:30 AM
Raj Quest is offline
Find More Posts by Raj Quest
Joined Aug 2004
Help!
HK KK 2.1 Settings help
I'm using the HK-KK 2.1 board on my quad.
At present I intend to use the default '+' configuration and firmware.
My question is with PID settings.
1) Which firmware does the default HK-KK-2.1 have?
2) Roll, Yaw, and Pitch - on the default board (pots) - do they actually control R,Y,P or do they stand for PI
3) I have simonK flashed F-20A ESCs, I've set all the 3 pots to almost 90% the quad seems to take off just about fine, I've tried to reduce the drift using trims on the Tx. The drift is not constant - sometimes on one direction and sometimes some other direction.
4) Even at almost 95% pot settings, I could not see the quad oscillating - so I left it at about 90%
5) Any instructions video? link? webpage? on how to fine tune the settings?
6) Is it possible (at all) to have a steady hover using the HK-KK board?
7) For my next quad will it be better to get the HK-KK2 (with built in LCD) - it has accelerometers - so I believe it will hover steady and better?
Pls help as best as you can.
R
Raj Quest is offline Find More Posts by Raj Quest
Old Jun 26, 2012, 12:43 AM
Boxhead is offline
Find More Posts by Boxhead
Look outside the Square
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Hi Raj. Mate have a look through this. This is a great setup guide by RCExplorer.
http://www.rcexplorer.se/Educational...uide/quad.html
Bx
Boxhead is offline Find More Posts by Boxhead
Old Jun 26, 2012, 12:58 AM
Joined Aug 2004
Thanks Box,
Here is a clip from that page:
Finding the correct gain:
- Increase the gain in small steps until the platform starts oscillating (overcompensating making the platform rock from side to side)
- Reduce the gain a bit
- You now have the optimum amount of gain.
- Fast forward flight requires lower gain.
- Too low gain is recognized by a hard to control platform that wants to tip over.
- Too high gain is recognized by oscillations.
Increasing the gain in small steps is referring to all 3 pots simultaneously??
which one of the 3 (Roll pot, pitch pot, or Yaw pot?)
R
Old Jun 26, 2012, 01:18 AM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Raj, I might be wrong but I do it indivdually. I set the pots at 50% ( all pots ) and do it one at a time. Take it up and see. etc etc till it starts to occilate ( jump around , shake , ) on that pot. Then take it back until it stops occilating. Then go to the next pot and do the same etc. You might have to take the pot increment below 50% to achive this as well.
Bx
Old Jun 26, 2012, 01:23 AM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
On one of my Tri's the rear (Yaw ) was wagging its Bum in flight. I tried it between 0 - 50% on the Yaw pot and it still wagged its tail. Its now set at 75% and the (yaw) now does not wag its Tail its rock solid. The other 2 pots are set at about 40 - 50 %. Adjust and test till your happy with it.
Bx
Old Jun 26, 2012, 01:26 AM
signal15 is offline
Find More Posts by signal15
Atomic Playboy
United States, MN, Inver Grove Heights
Joined Jun 2012
I believe with 2.1, the pots actually control pitch, roll and yaw. With version 1.6, 2.5 and 4.7 they control P and I.
Roll = P for pitch and roll
Pitch = I for pitch and roll
Yaw = P for yaw, or PI for yaw
There's no D on the KK board as far as I can tell. If you want PI, then upgrade to 4.7.
signal15 is offline Find More Posts by signal15
Old Jun 26, 2012, 04:24 AM
Joined Aug 2004
OK, thanks.
Let me try that ... step by step.
For now, let me get it right in the default HK-KK-2.1, once it is done,
I'll move on to re-flashing.....
I think 4.7 would be the best?
where can I dnload the most authentic 4.7 upgrade firmware?
From the KK multicopter home page?
R
Old Jun 26, 2012, 04:26 AM
Joined Aug 2004
Re-flashed with the 4.7 upgrade, is there a noticable improvement in the performance of the HK-KK-2.1?
I mean easy to tune? steady hovering? easy to control?
Old Jun 26, 2012, 09:46 AM
Dave8888 is offline
Find More Posts by Dave8888
United States, AZ, Seligman
Joined Nov 2011
Bx
I have this board and this is exactly how you do it with the default "+" config.
v4.7 will be harder to tune because now you have PI (pots are now like what signal15 said)
more steady hovering
you will have more control
Dave8888 is offline Find More Posts by Dave8888
Old Jun 26, 2012, 11:45 PM
Joined Aug 2004
Thanks Dave
Old Jun 27, 2012, 02:56 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
Multicopter PI-tuning: How to recognize different settings. (7 min 52 sec)
er9xuser is offline Find More Posts by er9xuser
Old Jun 27, 2012, 06:06 AM
Joined Aug 2004
Thanks er9xuser,
I had seen this video, but just wanted to know:
Roll, Yaw, and Pitch - on the default board (pots) the HK-KK-2.1- do they actually control R,Y,P or do they stand for PI?
(questions on my post # 1)
Old Jun 27, 2012, 06:25 AM
er9xuser is offline
Slovenia, Ljubljana
Joined Sep 2011
Originally Posted by Raj Quest View Post
Thanks er9xuser,
Pots are: Roll, Pitch and Yaw. With 4.7 FW from kapteinkuk they stand for PI. So Roll pot is for P term for Roll and Pitch, Pitch pot is I term for Roll and Pitch. Yaw pot is just P term, I si hardcoded.
Old Jun 27, 2012, 11:38 AM
Dave8888 is offline
Joined Nov 2011
Thanks er9xuser,
On the default HK KK v2.1 the pots control R,Y,P. The default board does not have PI.
Old May 19, 2015, 03:53 PM
nikunj sharma is offline
Find More Posts by nikunj sharma
Joined May 2015
i have kk2.1 board..
930 kv motor 2200 mah lipo 3s
my quadcopter drifts on the ground it self...doesnt lifts...?????
specially in the backward direction....and in right backward...
pls help me out..........
nikunj sharma is offline Find More Posts by nikunj sharma
Help! Yaw problem with HK KK Board V2.1, KK firmware 4.7 count74 Multirotor Talk 2 Jul 18, 2014 03:37 PM
Discussion Help flashing a hk v2 and kk blackboard 5,5 Garrett1234567 Multirotor Talk 13 Aug 13, 2012 07:23 PM
Discussion HK KK V2.1 will NOT flash gibatron Multirotor Talk 43 Apr 27, 2012 08:36 AM
Discussion Help with KK Multicopter blackboard set up grgrgrgr4444 Multirotor Talk 15 Apr 26, 2012 06:51 AM
Discussion Hk kk v2.1 help jwalker590 Multirotor Talk 7 Mar 09, 2012 06:09 AM
