Old Mar 12, 2015, 02:18 PM
Sink stinks
Montag DP's Avatar
United States, GA, Atlanta
Joined Apr 2005
Originally Posted by Geoff_S View Post
Dan, there were two further suggestions for possible enhancements which I've added as tickets on the SourceForge site. They relate to the output airfoil name in the .dat file, and including a max_thickness constraint. Hopefully they work (I haven't tried compiling or running the modified code), and are considered useful.
Hey Geoff,
Those are good suggestions. I just uploaded a new version and responded to your tickets on Sourceforge. There is now a max_thickness constraint (which is basically off by default as the default value is 1000.0). The second command line option now indicates the output airfoil name, which is written to the first line of the file, instead of the file name itself. The file name is just the airfoil name you specify + '.dat'.
When you get a chance, try it out and update the tickets on Sourceforge. I'll close them if it works as desired (or you can, if you are able to do that).
Dan
Montag DP is offline Find More Posts by Montag DP
Old Yesterday, 05:15 AM
Joined Mar 2015
Hi Dan,
I've been looking into XoptFoil but need the ability to generate symmetrical foils, is this something XoptFoil can do?
Regards,
Toby.
carvegybe is offline Find More Posts by carvegybe
Discussion Airfoil Optimization Using Genetic Algorithms Ghost_ Modeling Science 38 Apr 24, 2014 06:18 AM
Discussion Airfoil Optimization with XFOIL Montag DP Modeling Science 168 Feb 03, 2014 08:14 PM
Discussion Evolutionary airfoil design optimizer available kcaldwel Modeling Science 3 Dec 10, 2012 04:03 PM
Profili - Xfoil and reflexed / autostabilizing airfoils surfimp Modeling Science 29 Mar 30, 2005 06:32 AM
