Old Jul 11, 2012, 06:44 PM
A Day @ a Time - Matt. 6:25-34
ruff1's Avatar
North AL, USA
Joined Nov 2009
Winglets - What Have You Guys Found?
Hey,
As promised from my last post, a question. A lot of the airliners people have interest in building have winglets (K's MD-11).
What kind of information have you uncovered in your research about winglets? Are there any best practices on how to make these in the RC-size arena? I'm curious as to what you guys have done so far.
I haven't had a chance to look at any commercially-available models like the WindRider 737 to even get an idea how they are shaped. I would think you better know what you are doing alignment-wise otherwise you'll be trimming-out unwanted yaw if not getting into an out-of-control situation.
WHOOP WHOOP! Thread diversion... I'm a ways-off from building an airliner, but maybe a year or so from now. If I get lucky I can work on one over the next winter, I have several in my club that can fly her if I'm not ready (I probably won't be!) Still interested in the Caravelle SE210. No winglets there, but there are vanes...
ruff1 is offline Find More Posts by ruff1
Old Jul 11, 2012, 07:13 PM
Sittin' on my hands
depronair's Avatar
United States, WA, Seattle
Joined Jan 2005
I honestly dont think they'll do anything for an RC airplane. There just wont be any wing-tip vortices to cancel out because our foam planes are going only like 50 knots. But they look cool. I could be wrong though. Maybe they'll produce happy side-effects. Might be worth experimenting on a glider.
as far as build is concerned.. perhaps a spar cut like an "L", glue foam on both sides, and sand-to-shape probably.
depronair is offline Find More Posts by depronair
Old Jul 11, 2012, 09:52 PM
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Winglets help reduce wintip vortacies which reduce drag which helps any aircraft. . . . . .plus they look cool!
demondriver is offline Find More Posts by demondriver
Old Jul 11, 2012, 10:01 PM
RC = Empty wallet
InvalidUsername's Avatar
Australia, VIC, Melbourne
Joined Jan 2005
^^+1 On rc aircraft, they would do next to nothing, more for looks than performance. They come in many shapes and sizes
InvalidUsername is offline Find More Posts by InvalidUsername
Old Jul 12, 2012, 05:28 AM
Up-Out-&-Gone
Joined Mar 2007
Wow!. . . . now those are what you call winglets Lol
Old Jul 12, 2012, 06:17 AM
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
if you get them outta line the case a lot of drag and will stall the wing Quicker however the advantage of having winglets on an RC model is the improve take-off/landing performance... (due to winglets increasing the span) and for that very same reason you can fly at 1 maybe 2% lower throttle when Cruising which means slightly longer flight times..
Keenan smith is offline Find More Posts by Keenan smith
Old Jul 18, 2012, 11:44 AM
Avoid The Ground!
Flexserve's Avatar
United States, FL, Tampa
Joined Sep 2008
I get more gas mileage... XD
Flexserve is offline Find More Posts by Flexserve
Old Jul 22, 2012, 10:39 AM
M0unt@in M0del$ minion
turbojoe's Avatar
United States, AZ, Mesa
Joined Jul 2002
I've only used winglets on one airplane for 3 build comparisons. It's a scratch build from Eastwind Models Gemini Twin plans. This plane does outstanding touch and goes and for some crazy reason I just love trying to fly it on the ragged edge of tip stalling. Sometimes I get bit and she falls out of the sky.
#1 build was with tall winglets as seen on most airliners and flew pretty good. This first one was completely destroyed in a trip and fall (don't ask).
#2 one was also done with the high winglets This wing was damaged in a crash from stupid flying. (Stall turns at 12 feet AGL )
#3 was rebuilt from what was left from the crash of #2 and has Horner style tips. These gave the plane a different feel. Just seemed all around smoother. There is a definite decrease in tip stall tendency. Much more stable at super low speeds.
I think the high winglets look the coolest and may possibly have some affect on yaw stability but the Horners made the most noticeable overall improvement. I doubt the Horners have any tip vortice affect as on a full size aircraft. They most likely act as added washout on our smaller planes. In any case I'm working on a 50% larger version and it will have the Horner tips. As soon as I sell off some more planes to make room I'm going to drag the bigger one out and finish it up. Another 2 months or so and it'll finally be cool enough to fly again.....
Joe
turbojoe is offline Find More Posts by turbojoe
Old Jul 22, 2012, 07:57 PM
ruff1's Avatar
North AL, USA
Joined Nov 2009
Horner tips... never heard of them, but these look like what is on my Sensei.
Old Jul 22, 2012, 08:52 PM
turbojoe's Avatar
Joined Jul 2002
Originally Posted by ruff1 View Post
Horner tips... never heard of them, .
Because I misspelled it as usual. It should read Hoerner. Mine are probably better described as a drooped Hoerner. I got the idea after seeing a GWS E-Starter wing. It looked cool so I figured what the heck. They work well for me.
I'm posting a .pdf file I found that gives a brief look at the different kinds of wing tip devices in use. There is a TON of info out there on wing tips and STOL devices. I'm sure you'll find something that you want to try. I had a book around here on STOL R/C aircraft. I believe it was by Andy Lennon. Don't know where the heck it might be but I'll have to see if I can dig it up sometime. It had a lot of cool stuff in it.
Joe
Old Jul 22, 2012, 09:44 PM
ruff1's Avatar
North AL, USA
Joined Nov 2009
Outstanding information, thanks for the presentation.
Old Jul 22, 2012, 10:01 PM
turbojoe's Avatar
Joined Jul 2002
You're welcome. Hope it helps a bit. Don't forget to check some of the links on the last page of the .pdf.
Joe
Old Jul 22, 2012, 10:05 PM
Up-Out-&-Gone
Joined Mar 2007
I totally agree. . . thanks Joe!
Old Jul 23, 2012, 12:00 AM
Tennessee
Joined Sep 2003
Winglets do work but only at one speed. For transports, winglets are set for crusing speed and can increase drag if the speed is too far off the design speed. In 1979, I conducted extensive flight testing on a low aspect ratio sailplane and found up to 10 percent increase in glide time from a fixed altitude when the winglet toe out angle was set for minimum sink airspeed. I wrote an article that was published in the May, 1980 issue of Model Aviation about the experiment that contained a lot of the data. I concluded that winglets work for model airplanes but aren't usually worth the extra effort.
ChuckA is offline Find More Posts by ChuckA
Old Jul 23, 2012, 08:02 AM
Up-Out-&-Gone
Joined Mar 2007
Amazing work Chuck! Nice glider!
Discussion Hey guys look what I found usmc_VTOL_mech Dock Talk 14 Jul 12, 2012 02:09 PM
Discussion What do you guys think about this article. D-OCHO Multirotor Talk 8 Jun 28, 2012 06:10 PM
Discussion What tripod do you guys prefer? Lpbug FPV Talk 4 Jun 18, 2012 07:41 PM
Discussion What do you guys have the NAZA voltage monitor settings to on a 4s battery jasper7821 Multirotor Talk 5 Apr 29, 2012 10:04 PM
