Old Jun 09, 2014, 08:58 AM
AMA 697691
Rochester, NY, USA
Joined Aug 2000
Witespy "mini" ReadyToFlyer 2.6 for APM
The new "mini" ReadyToFlyer 2.6 will fit in places that other APM controllers can not. Use the power of APM on smaller MRCs or narrow fueslages.
Features:
  • APM firmware and ground station
  • 8-CH output and 8-CH input
  • ports for external GPS, compass, telemetry system and Power module
  • 12-CH function interface
  • Size: 35*35mm
Included:
  • 1x Motor cable
  • 1x Radio cable
  • 1x Gps cable
Options:
Greg Covey is offline Find More Posts by Greg Covey
Old Jun 09, 2014, 08:59 AM
AMA 697691
Rochester, NY, USA
Joined Aug 2000
Motor Setup:
The motor connection numbers are under the Connecting the ESCs/Motors section of the "First Time Setup" "Assembly Instructions" menus. The motor outputs 1-8 correspond to the numbers on the MRC diagrams. For more information, visit the APM:Copter site under the "instructions pull-down menu.
PPM Sum:mini APM to PM Cable:
  • I needed to make a cable to go from the Power Module to the mini APM because they are different connectors.
  • Pictures of the PM setup
  • Mini / PM
  • 6 GND 6
  • 5 GND 5
  • 1 .Vm. 4
  • 2 .Cm. 3
  • 4 ..5v.. 2
  • 3 ..5v.. 1
GPS/Compass Orientation:
Witespy GPS/Compass modules can be use for for either APM or Multiwii. For APM, the dot on the 5883 MAG chip goes in the upper right corner. For Multiwii, the dot goes in the lower left corner.
The image below shows the correct forward orientation for the mini GPS/Compass module (35x35mm) for APM. The patch antenna (top) side may vary depending upon how it is mounted so go by the bottom side image for forward direction on APM.
Telemetry:
I got the Telemetry port on the bottom side of the mini APM board working by making a special cable. An open ended cable came with the mini APM board which I spliced into an extra cable I had for the telemetry air module. After testing, I shortened the cable to a reasonable length.
Old Jun 10, 2014, 12:44 AM
Yana547's Avatar
Joined Jun 2013
just flashed my op revo with apm, working good. I will try this one soon...
Yana547 is offline Find More Posts by Yana547
Old Jun 10, 2014, 02:24 PM
Beaumont ,peoples republic of Kalifornia
Joined Jan 2004
subscribed ...Very interesting.....What does it weigh ?
debogus is online now Find More Posts by debogus
Old Jun 10, 2014, 03:31 PM
AMA 697691
Rochester, NY, USA
Joined Aug 2000
I'm not sure but I'll weigh it when mine arrives.
Latest blog entry: Greg's Web Hangar
Old Jun 11, 2014, 09:42 PM
Flyingfool's Avatar
Belle Chasse Southern, Louisiana, United States
Joined Apr 2002
Now he just needs to come up with a gps & compass combo that is the same size and bolt pattern as this board and we'll have a winner for minis.
Flyingfool is offline Find More Posts by Flyingfool
Old Jun 11, 2014, 10:26 PM
James not bond
jy0933's Avatar
Joined May 2012
that is actually in progress.
and
jy0933 is offline Find More Posts by jy0933
Old Jun 12, 2014, 07:23 AM
Flyingfool's Avatar
Joined Apr 2002
Hmm, Wonder how long before it is released as I would order a setup for sure.
Old Jun 13, 2014, 10:02 PM
<Marty>
United States, KY, Springfield
Joined Jul 2011
Already available...
http://www.goodluckbuy.com/miniapm-v...lticopter.html
magic_marty is offline Find More Posts by magic_marty
Old Jun 13, 2014, 10:30 PM
James not bond
jy0933's Avatar
Joined May 2012
if only you trust goodluckbuy.
Old Jun 13, 2014, 11:11 PM
<Marty>
Joined Jul 2011
I've bought a couple things from them with no problems at all and they ship pretty fast, only took 14 days for my APM to arrive.
Old Jun 14, 2014, 08:09 AM
AMA 697691
Rochester, NY, USA
Joined Aug 2000
That's a cute little 35x35mm GPS/Compass unit. I'll assume that Paul is getting a similar unit but I haven't seen it yet.
Old Jun 14, 2014, 08:19 PM
Flyingfool's Avatar
Joined Apr 2002
Come on Paul, Hurry and get a setup like that for sale as I need one.
Old Jun 14, 2014, 09:13 PM
James not bond
jy0933's Avatar
Joined May 2012
http://witespyquad.gostorego.com/fli...d-compass.html
maybe?
Discussion Witespy RTFhawk 2.4.5 for APM Greg Covey Multirotor Electronics 3442 Today 05:18 AM
Discussion Taranis 6 Position Switch for 6 Flight Modes w/APM 2.5 & Mission Planner yourbrother Multirotor Talk 1 Oct 26, 2014 11:49 PM
Discussion Witespy ReadytoFlyer w/GPS (APM 2.5 clone) DavidMarderATL Multirotor Electronics 8 May 07, 2014 06:38 PM
Sold TBS Discovery, witespy APM 2.6 ARTF samsking Aircraft - Electric - Multirotor (FS/W) 6 May 06, 2014 09:38 AM
Sold Lea-6H GPS w/Magnetometer for APM 2.5/6 ghenders Aircraft - Electric - Multirotor (FS/W) 4 Oct 31, 2013 06:35 PM
