Old Yesterday, 04:45 AM
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Originally Posted by Pat Lynch View Post
The XT90 connectors are MUCH easier to do/undo than either Deans or XT60s due to the more 'sophisticated' metal connector parts.
That's good to know - I was basing my comment upon what I know about XT60s, which are my connector of choice (I only once used Dean's - with the moulded ribs to improve grip - and I thought they were bloody awful things!).
Colonel Blink is offline Find More Posts by Colonel Blink
Old Yesterday, 05:45 AM
a.k.a Maltone
Australia, NSW, Goulburn
Joined Jan 2005
My last activity for the evening was to do the inevitable 'vroom vrooom' thing and put it all together and play The flaps immediately jammed themselves about 20 deg past 'up', the rudder wacked itself to one side and was reversed, one undercarriage leg collapsed, and the tailwheel did nothing. Oh, the elevator was spot on
An hour of mixing tailwheel steering with rudder, setting up flaps on a 3 position switch and generally end-point adjusting, sub-trimming etc, it is all working.....whew. The flaps close unevenly so there's a small mechanical adjustment to make, the rudder control lines are loose (always have been) and I need to check the limits on the undercarriage. The most important UC position is fully down and currently one leg is bent at the knee! Easily fixed I hope.
Wound both motors up with some gash 11X6 props and bl--dy hell I'll put all the tools and magazines back in place tomorrow
Main thing is - everything works and I can progress from the 25% stage to something better.
Pat
Pat Lynch is online now Find More Posts by Pat Lynch
Latest blog entry: A New Year's Project
Old Yesterday, 06:46 AM
Joined Nov 2008
I always love that first spin up of the motor(s) - sort of lets you know that it is alive!!!
Old Yesterday, 09:01 AM
Is it suppose to do that?
moscow580's Avatar
USA, CT, Waterbury
Joined Sep 2006
Hi Pat
It is good too know that even the Masters have that same issue the novices had - "I just built everything and nothing works?"
I speak for myself on the novices part.
Sounds like Annie is going to be one Powerful Mama.
Sean
moscow580 is offline Find More Posts by moscow580
Old Yesterday, 01:59 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Gulp! Even though I've been an electronic engineering 'professional' all my life, I find the connecting up of a complex system always a little bit daunting Two batteries with provision for paralleling, provision for both ESC BECs to be paralleled, etc etc...... but it all went together and all worked - first time
That's amazing. As an engineering technician who fabricated circuits from an engineer's hand scribbled schematic diagrams, I can attest that I never encountered an electronic engineer who could solder worth a tinker's whatever.
Nice work. Looks like a daunting task.
Larry
Lnagel is online now Find More Posts by Lnagel
Old Yesterday, 03:34 PM
Power Upward
GeorgeG97322's Avatar
United States, OR, Albany
Joined Jun 2007
Very Impressive Pat.
Looks to me like you will have a lot of A$ tied up into this build. Two big motors, two big speed controllers, batteries, extra servos, and so on...
George
GeorgeG97322 is offline Find More Posts by GeorgeG97322
Old Yesterday, 04:23 PM
a.k.a Maltone
Joined Jan 2005
Originally Posted by Lnagel View Post
That's amazing. As an engineering technician who fabricated circuits from an engineer's hand scribbled schematic diagrams, I can attest that I never encountered an electronic engineer who could solder worth a tinker's whatever. Larry
Larry don't get too amazed - I started the bottom, worked in various Telecom and Aerospace companies (worked as a NASA contractor for about 15 years, and then drifted into engineering and military prototype development. I never became a proper 'engineer' - just did the whole thing - design, development, building and project management. Much more interesting than handing 'scribbled diagrams' to someone else. Learnt Mil-spec/NASA soldering, PC fabrication etc. along the way! Does it all help when building a model aeroplane? - not sure as I still make the same dumb mistakes I did 20 years ago
Pat
Old Yesterday, 10:30 PM
a.k.a Maltone
Joined Jan 2005
Just foolin' around
At the risk of seeming childish, I just had to see if the Anson could be driven around a back yard that desperately needs mowing (when it stops raining...)
I needed full up elevator to stop nose overs but she taxied in 3" high grass without a problem. As usual, a twin electric sounds great
I re-adjusted the flaps, undercarriage and rudder to work correctly and so Annie may even dance for the club members on Sunday !
I don't do selfies, but a few have commented on how huge the model seems - without its wings, not very. Sorry about my serious expression - it was starting to drizzle so back inside!
George - I suppose any large model gets expensive but the only expensive items were the wood pack and the two E-Flite motors. All the rest is Hobby King and cheap LHS stuff. I've been collecting the parts since the beginning of last year so with a bit of planning, the cost is spread out over a longish period.
Pat
Old Today, 12:26 AM
Power Upward
Joined Jun 2007
Pat, looks like fun... Annie does not look quite as big in the yard and with you behind it as it dose on the work bench.
George
Old Today, 01:56 AM
shoey's Avatar
Australia, SA, Adelaide
Joined Jan 2009
Looking great Pat, glad you got the gremlins sorted out. Wish I had more than "after the kids go to sleep" time to progress as quickly as you!
shoey is online now Find More Posts by shoey
Old Today, 05:55 AM
CH Spring
Canada, ON, Osgoode
Joined Mar 2008
I am impressed as all heck. You are doing a very nice job. Don't worry about the selfie. Its allowed.
Cheers!
Spring is offline Find More Posts by Spring
Old Today, 11:04 AM
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Its always good to have a face to put with a build. The plane looks marvelous!! Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
For Sale What, no Pilot? New Faces! 2 sizes WWII Pilots already painted for only $12.50!!! unclegeorge Aircraft - Fuel - Airplanes (FS/W) 7 Jan 24, 2013 09:55 AM
For Sale What, no Pilot? New Faces! 2 sizes WWII Pilots already painted for only $12.50!!! unclegeorge Aircraft - Fuel - Airplanes (FS/W) 0 Jan 04, 2013 12:27 PM
Discussion What do you do to prepare a glow model for electric? depronair Glow to Electric Conversions 1 Sep 03, 2010 04:06 PM
Discussion Evolution Model Technology, preparing to open for business Evolution Staff Product Announcements 0 Aug 07, 2006 07:13 PM
Question Whaddoya Think- Preparing for Axle build Hutch Slope 11 Aug 04, 2005 04:10 PM
