Old Oct 01, 2015, 12:34 PM
summbear48 is offline
Find More Posts by summbear48
Joined Jul 2015
BE1806 wobble naza robocat
so built a robocat (have a venture)
be1806 2300 motors
hobbyfan 12a bec esc (+ removed)
naza v2
PDB
5045 and 5045 triple blade
3s battery
everything is brand new, havent "flown" only tested. 1 motor (replacement being sent) I thought was the issue. It "stops" spinning and seems to be giving a bit of vibration.
props off it doesnt look like it has a bent shaft or anything.
I tried testing each motor with prop then in pairs, then in 3's and then in 4's to deduce which motor is the actual problem, but when taking off I have a wobble. Holding in my hand, I also experience the wobble around half stick but if I go to full throttle, the wobble disappears.
some have suggested bent shaft, unbalanced props. but wouldnt the wobbling get worse with more throttle?
any help from veterans would be appreciated, this is my first build after flying venture (which I love!)
summbear48 is offline Find More Posts by summbear48
Old Oct 01, 2015, 09:37 PM
Joined Jul 2015
anyone? I have heard perhaps change the gains? I Am using default from my quanum venture...
Old Oct 01, 2015, 10:06 PM
Joined Jul 2015
gains
changed the gains, wobble gone
60,40,70,100
100,100
Help! Naza death wobble ny help me Suffolk_speed Multirotor Electronics 7 Jul 15, 2015 01:48 PM
Discussion Naza V2 bad Yaw Wobble on Black Snapper foldable Quadcopter - SOLVED!!!! schim Multirotor Electronics 1 Aug 26, 2014 02:41 AM
Help! Tarot FY690s Hex Naza-M "Wobble" smarks Multirotor Talk 3 Aug 26, 2013 10:15 AM
Help! TBS Discovery / Naza Annoying Wobble! Jmm_jammy Multirotor Talk 12 Aug 26, 2013 12:38 AM
Discussion Wobbly flying with Naza , a gain to low or to high? WonderKing Multirotor Electronics 5 Jul 11, 2013 08:32 AM
