Old Jul 03, 2015, 05:40 PM
Paul Kenney is offline
Find More Posts by Paul Kenney
Paul Kenney's Avatar
Joined Jul 2015
30" Standard J-1 Build
I started this model a while ago and was considering converting it to electric power with rudder and elevator controls. Does anybody have any advice if this Dumas kit would be a good candidate and what components to use? I am yet to start on the tail feathers while I decide on rubber power or electric conversion.
Paul Kenney is offline Find More Posts by Paul Kenney
Old Jul 03, 2015, 07:33 PM
HanksGB is offline
Find More Posts by HanksGB
confused poet
HanksGB's Avatar
USA, CA, Orange
Joined Feb 2004
Paul
Do a search for Pat Trittle threads. He converted one years back. With today's equipment any 5 g or smaller servos would be fine. Don't need much power but it will be nice to swing a big enough prop so maybe 250 size out runner.
Good luck
Hank
HanksGB is offline Find More Posts by HanksGB
Old Jul 04, 2015, 12:18 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Yep, look up Pat's thread (it may still be in the Scale RTF forum).
I remember it flew, but, don't remember how well. Also don't remember if Pat used an IPS or SP280 on it (was a long time ago ).
charlie
portablevcb is offline Find More Posts by portablevcb
Old Jul 04, 2015, 10:55 AM
HanksGB is offline
confused poet
HanksGB's Avatar
USA, CA, Orange
Joined Feb 2004
Found the there'd on Pats build
http://www.rcgroups.com/forums/showthread.php?t=263738
Enjoy
Hank
Old Jul 05, 2015, 02:08 PM
Joined Jul 2015
Wow, thanks so much! That'll be a big help!
Old Nov 15, 2015, 11:13 PM
Joined Jul 2015
Flight Gear
So I chose to use a 15 gram E-max GT 2203 brushless motor, 10 amp e-flight ESC, micro reciever and two 3.5 gram servos for rudder and elevator control powered by a 2C 300 mah Battery. Total build weight all included came to 5.2 oz
Old Nov 15, 2015, 11:26 PM
Joined Jul 2015
Covering and finish
I wanted to use as much of the supplied materials from the kit as possible, so the covering was light weight natural linen silkspan applied with clear dope and then finished with two coats of buff colored flat dope. Supplied graphics were cut from peel and stick decals and coated with flat dope. All the flying wires and rigging wire .004 beading thread found at craft store pull pull for both elevator and rudder.
Old Nov 15, 2015, 11:43 PM
Joined Jul 2015
Maiden flight
My first couple attempts to rise off of the ground produced scary results. I need about 6-8 clicks of right rudder correction and some down elevator trim to avoid a sharp climb and left spiral, after making trim corrections and calming my nerves I achieved controlled flight!
Balance seems to be just right with the battery as far forward in the front cowling, I have a small hatch under the bottom wing for access. I am not sure if I have a small twist to the vertical stabilizer or a slight mis-alignment in the wings but with the right trim the model flies extremely well.
Old Nov 15, 2015, 11:51 PM
Joined Jul 2015
How to post video?
I am not sure how to post video?
Does anybody have any suggestions?
Old Nov 16, 2015, 12:14 AM
HanksGB is offline
confused poet
HanksGB's Avatar
USA, CA, Orange
Joined Feb 2004
The standard looks great. Most guys up load the video to you tube and then post the link.
Hank
Old Nov 16, 2015, 12:21 AM
gmwahl is offline
Find More Posts by gmwahl
United States, UT, Garden City
Joined Aug 2011
Beautiful plane! Well done!
gmwahl is offline Find More Posts by gmwahl
Old Nov 16, 2015, 12:27 AM
HanksGB is offline
confused poet
HanksGB's Avatar
USA, CA, Orange
Joined Feb 2004
Also reading your description of the test flight make sure you have enough down and right thrust.
Hank
Old Nov 16, 2015, 12:50 AM
Joined Jul 2015
Take off video
MVI 5398 (0 min 11 sec)
Old Nov 16, 2015, 01:31 AM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Great job Paul. Looks very scale and I'm sure it flies the same.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Nov 16, 2015, 08:21 AM
Joined Jul 2015
Right and Down thrust
Quote: Also reading your description of the test flight make sure you have enough down and right thrust.
Hank
I probably did't include enough, next model I will try 2 or 3 degrees down and right. Problem is with how I attached the front cowling I cant make any adjustments now. Seeing as it flies really great I am going to leave alone
Discussion Standard J-1 Bigfoot21075 Scale Kit/Scratch Built 7 Nov 18, 2013 12:23 PM
Build Log Building the PCM Standard J-1 Yankeeone Vintage & Old-Timer Designs 15 Feb 21, 2010 10:39 PM
Discussion 2.75oz "Diddle style" Standard J-1 Bipe MISTERSCOTT Scratchbuilt Indoor and Micro Models 4 Dec 23, 2006 02:10 AM
Looking for standard j-1 documentation... silverpoz Scale Kit/Scratch Built 6 May 05, 2006 11:50 AM
Discussion Dumas standard J-1 rays89 Scale Kit/Scratch Built 14 Oct 08, 2002 01:04 AM
