Old Feb 03, 2016, 04:20 PM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Looking good Steve
Engine will definately be in next months RCME, here is the front cover That's my clubmates Storch.
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Feb 04, 2016, 03:08 AM
BigTradioman is offline
Find More Posts by BigTradioman
BigTradioman's Avatar
United Kingdom, Harpenden
Joined Oct 2009
Committed to the build now, got the plan, got all the bits from Coolwind, UHU contact on its way, cleared the table off, off to the printers today to get the plan blown up. First attempt at a scratch build since moving from my big workshop with a house attached to it a year ago. Believe it or not this model will be built in the same room I built my very first KeilKraft glider in 53 years ago! I hope it flies better than that one did! It's cost is about 110% more.
BigTradioman is offline Find More Posts by BigTradioman
Old Feb 05, 2016, 02:41 AM
Joined Oct 2009
I think my print shop enlarged the plan too much. Can someone give me a measurement to check? Say mast length, or main fuz length?
Old Feb 05, 2016, 10:13 AM
split cane is online now
Find More Posts by split cane
Joined Sep 2006
Hi Tim,
Just measured my plan and the mast is 11 inches the fuz is 26 inches from the firewall to the end of the rudder measured along the baseline.
Hope this helps.
Dave.
split cane is online now Find More Posts by split cane
Old Feb 05, 2016, 12:15 PM
Joined Oct 2009
Originally Posted by split cane View Post
Hi Tim,
Hope this helps.
Dave.
Thank you for that, it all checks out so it must be my lack of making a jig saw.
Anyway its my first time with EPP and its not going well. I am struggling with sticking this together with UHU Por. I have tried all ways to get it to take and it wont. It air dries OK in about 10 mins, house is nice and warm, I have laminated the fuz together and left it clamped under a board with a weight on for 4 hours. I took it out the clamp and it just fell apart. All the parts are warped and bowed. Its genuine UHU Por as well, and I got the EPP from Coolwind. I must have got some kind of contamination on the foam as I tried the UHU on some Depron and that worked OK. I have built several large FPV foamies with the same glue and they where OK. So I will need another sheet of foam and have a go with epoxy or Elmers polyurethane glue. If that fails I'll give up.
Old Feb 05, 2016, 02:55 PM
106flyer is offline
Find More Posts by 106flyer
106flyer's Avatar
Joined Jan 2013
Hi Tim,
My plan shows 7" from top of the fus at the mast to the head pivot and 24" from top front bulkhead to rudder hinge line.. See the pics
The other lines are those for my SE5 version
Steve
106flyer is offline Find More Posts by 106flyer
Old Feb 05, 2016, 03:05 PM
106flyer is offline
106flyer's Avatar
Joined Jan 2013
Hi Tim
That's odd... My method is...
Cut parts, run glue over surface of both pieces being stuck from tube in tracks approx 40mm apart. Spread evenly and well over whole surface with an off cut as a spreader.
Leave to dry over night completely, note it curls while wet. In the morning it has returned to being flat ... Then align and press firmly together ... Done
Originally I was using the glue as a wet joint with pressure. Always have poor results and often bent. Rich put me right to use the glue as impact adhesive and no Isues since...
Steve
Old Feb 05, 2016, 07:34 PM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
Must admit that I have never used EPP......but.. I have always found it a good idea to remove the surface of any type of foam with course grit paper to help it it key together.
Chris...
britinoz is offline Find More Posts by britinoz
Old Feb 06, 2016, 03:37 AM
106flyer is offline
106flyer's Avatar
Joined Jan 2013
Don't give up .. Get some foam from 'Flying Dog' .......
Old Feb 06, 2016, 03:47 AM
Joined Oct 2009
The let it dry overnight works, but you have to get the fit right first time. It reminded me of how I fit laminate sheet with evo stick on a worktop. After glue drying I lay wood dowels on the surface then the sheet on top of the dowels, line up and slide the dowels out one at a time. I'll crack on with this and if it looks Rubbish get another sheet from FD.
Old Feb 06, 2016, 04:42 AM
106flyer is offline
106flyer's Avatar
Joined Jan 2013
And you said you were in the building trade with years of experience !!!! ... Lol
Old Feb 06, 2016, 05:28 PM
Joined Oct 2009
You don't build many houses with EPP mate.
For Sale New, 22 inch EPP foam wing kits with 200-500 Watt motor. Add your electronics to fly sylair Aircraft - Electric - Airplanes (FS/W) 13 May 16, 2013 10:09 PM
Build Log EPP repair with 2 part foam tbroeski Thermal 9 Feb 06, 2013 08:01 PM
For Sale package deal: 2 EPP foam planes RTF with DX6i !!! MinorHobby77 Aircraft - Electric - Airplanes (FS/W) 1 Jan 18, 2013 08:04 AM
Playing with foam again.... imsofaman Bergen County Silent Fliers 0 Aug 11, 2005 11:31 PM
Playing with making a Power Pod from EPP blivsey Electric Sailplanes 45 Nov 20, 2003 07:38 AM
