Old Jun 22, 2015, 05:06 AM
frank48 is online now
Find More Posts by frank48
Went to mow a meadow
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Hi
You might like to try Alex's firmware I found it to be much more accurate
http://www.rcgroups.com/forums/showthread.php?t=2123788
Frank
frank48 is online now Find More Posts by frank48
Old Jun 26, 2015, 05:40 AM
kalliber is offline
Find More Posts by kalliber
Joined Apr 2008
Originally Posted by frank48 View Post
Hi
Frank
Hi Frank,
to be "Frank" with you, I didn't know about the AlexFW. updated it the day you wrote but I still have my GPS problem.
thanks for the info!
kalliber is offline Find More Posts by kalliber
Old Jun 26, 2015, 06:31 PM
kalliber is offline
Joined Apr 2008
Same plane same setup, this time with uOSD
FPV Hobbyking Dragonfly with uOSD and RSSI.26-6-2015 (12 min 55 sec)
flew today and can say that this firmware supersedes the cl-osd, although
cl-osd is also very good. thanks to all the developers!
don't put any device near the gps antenna as this will drop all the satellites.
I had the hobbyking HD wing camera just beneath the gps --> no satellites
when removed I had 5 satellites instantly. it takes about 1min30 seconds to
lock the GPS.
Old Jul 11, 2015, 04:24 PM
ratbird911 is offline
Find More Posts by ratbird911
United States, CA, Castro Valley
Joined Jun 2012
I have just discovered this thread and I wam super excited to get started on this! I have just a couple questions that I havent been abvle to answer with my searches.
1) Will cl-osd work on both the g-osd2 and g-osd 3? I have one of each
2) Is ther a more centralized resource for all this information on these 275 pages, like a summary of the main points of issues and advice for flashing etc.?
Thanks!
ratbird911 is offline Find More Posts by ratbird911
Old Jul 13, 2015, 06:59 PM
Joined Jun 2012
I accidentally flashed my OSD using the altmega88 chip setting instead of the altmega88PA setting. Now I believe that it is toast.
Would that be enough to brick this board?
Old Oct 15, 2015, 04:35 AM
Gygax is offline
Find More Posts by Gygax
FPV Plank Scratcher
Gygax's Avatar
Australia, NSW, Keerrong
Joined Jan 2013
ripping my hair out guys..
Hey everyone. Just been trying for hours to flash this thing..
I think I have it soldered fairly cleanly (for me at least), the pins are correctly matched up(?)
One thing that makes me wonder is that unlike what I saw in a youtube vid that detailed this process, whilst the led on my usb burner stick came on when I plugged it in, the led on the OSD came on steadily, and did not flash when plugged in.. Is this relevent?
Its been a long day, so maybe Im just missing something obvious..
Ive been trying to use extreme burner. Any helpful folks want to give me some clues?
Gygax is offline Find More Posts by Gygax
Old Oct 15, 2015, 05:55 AM
odontologo98 is offline
Find More Posts by odontologo98
Joined Oct 2008
Originally Posted by kalliber View Post
https://www.youtube.com/watch?v=nz6t...ature=youtu.be
lock the GPS.
Nice cāmera.
which camera FPV you use?
odontologo98 is offline Find More Posts by odontologo98
Old Oct 15, 2015, 09:46 AM
Joined Jun 2012
I never had success with this process. Try the U osd with the configurator.
This worked perfectly!
Old Oct 15, 2015, 05:17 PM
Gygax is offline
FPV Plank Scratcher
Gygax's Avatar
Joined Jan 2013
Thanks for that link.. I read through the first few pages of that thread, and the critical point to me seems to be..
When i plug in my osd to usb programmer, then into computer..
The usb programmer led is steady on, and the osd led is steady on, NOT flashing like it should be..
All my solders are ok, no bridging, pinouts look correct, although therere two gnd pins on my usb programmer and im not sure which to connect to..
Any ideas please?
Old Oct 16, 2015, 03:57 PM
BRENOROCKENBACH is offline
Find More Posts by BRENOROCKENBACH
Joined Aug 2013
Good afternoon friends. Use the E- OSD to RSSI , I upgraded our fellow Atx_Heli forum. The problem is that as the use fy41ap along with the E- OSD the numbers were subscribed , follows attached photo to see the result. Does anyone know this climb characters few millimeters ? thank you
[/QUOTE]
BRENOROCKENBACH is offline Find More Posts by BRENOROCKENBACH
Old Jan 03, 2016, 11:49 PM
jackheli is offline
Find More Posts by jackheli
Joined Aug 2006
Hi guys,
which is the coolest firmware people are now using?
jackheli is offline Find More Posts by jackheli
Old Jan 18, 2016, 07:56 PM
1flyguy is online now
Find More Posts by 1flyguy
to live and let fly!!
1flyguy's Avatar
Joined Jul 2013
anyone know of a code to use on a arduino mini??
1flyguy is online now Find More Posts by 1flyguy
Old Jan 19, 2016, 05:17 AM
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Try this one?
http://www.rcgroups.com/forums/showthread.php?t=1473207
Build Log Super OSD ($90): Open Source Graphic OSD: Vario, 6xADC, Games, Datalog, Dual Video tom66 FPV Equipment 1928 May 24, 2014 11:07 AM
Discussion Open Source Remote Control System (OSRC) Gizmoman31 Radios 152 Apr 24, 2012 06:01 PM
Discussion Open source OSD for FPV UFO_MAN FPV Talk 75 Sep 07, 2011 02:03 PM
Question Open Source Octo Design Available...Looking for someonw who can cut a copy for me... Schatham421 Multirotor Talk 14 Apr 12, 2011 05:22 PM
