Old Jan 16, 2016, 05:58 PM
jrstroh is online now
Find More Posts by jrstroh
jrstroh's Avatar
United States, PA, Camp Hill
Joined May 2015
So the obvious question has to be were you flying IFR?
jrstroh is online now Find More Posts by jrstroh
Old Jan 16, 2016, 06:32 PM
urrl is offline
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
VFR under extreme circumstances.
urrl is offline Find More Posts by urrl
Old Feb 19, 2016, 11:12 PM
sporn is offline
Find More Posts by sporn
Joined Aug 2007
310
sporn is offline Find More Posts by sporn
Old Feb 21, 2016, 02:49 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
Originally Posted by sporn View Post
310
Nice pics. Is that the Tian Sheng Cessna 182 ?
Old Feb 21, 2016, 09:43 PM
sporn is offline
Joined Aug 2007
Yes, Buddy1065, the one from Markham Park
Old Mar 09, 2016, 06:19 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
Morning flight. Trying to fly as gracefully as Sporn.
Dynam Cessna flight 3.10.16 (3 min 4 sec)
Old Mar 14, 2016, 01:23 PM
sporn is offline
Joined Aug 2007
Great flying urrl, love the sound!
I am planning to come out early tomorrow morning. Hope to see you there.
Old Mar 15, 2016, 11:30 AM
HeliFlyer14 is online now
Find More Posts by HeliFlyer14
United States, OR, Corvallis
Joined May 2014
Nice flying!! The Mr. Sound System really adds a lot to the flying effects for this plane. Of course, the plane is cool enough by itself, so the sound is just the icing on the cake.
HeliFlyer14 is online now Find More Posts by HeliFlyer14
Old Mar 15, 2016, 12:12 PM
chopperscott is offline
Find More Posts by chopperscott
Aaaah...........Napalm!
chopperscott's Avatar
USA, TN, Oak Ridge
Joined Apr 2004
Makes me wish I'd never sold mine. I'm seriously thinking of picking this one up again.
chopperscott is offline Find More Posts by chopperscott
Old Mar 20, 2016, 10:36 AM
blvdbuzzard is online now
Find More Posts by blvdbuzzard
The high desert of Southern California
Joined Jul 2002
The tale of two Cruisers.
My brother and I bought one at the same time. When I put mine together mine had a few issues. The glue they used to hold the landing gear mounts in was all over the place. It was in the main retracts and was actually binding the retracts up. So I pulled and cleaned the glue off and a dab of oil, grease and the retracts worked real smooth.
When I was helping my brother put his together, I checked his retracts and same thing. Glue every where. I cleaned his up and they too worked smooth as can be. One of the ESC's on his plane was missing the the plug that was supposed t be soldered to the ESC for the motor. No big deal I had one and soldered it on. His checked out and was ready to fly.
We went fly yesterday. Perfect day. Was a sunny, warm, just a great day to be outside. He plugged in the battery, and away it shot. Was air born in 10 feet. A couple clicks of trim and she was flying sweet as pie. He was just cruising it around at 1/2 throttle doing slow circuits. She does look good in the air. Landings were sweet and slow.
On his third flight, he comes in and catches a rut and both mains come off. OOPS. No real damage, all the glue that was supposed to hold the mount in, looks like it was in the retract.
After gluing the mounts in he is on his 4th flight. He is doing a slow fly by and it starts to squeal, beep and loose power. He gets it down and is checking it out. One motor is not turning, and it does not give the beeps when he plugs in the battery. He pulls the hatch and sees one of the leads has fallen of the ESC. So the solder joint failed. Looks like the one who forgot to solder the one on the other ESC soldered this one. Total crap job. So the flying was over for the cruiser for the day.
I popped the battery into my cruiser. I get her lined up and off she goes. These planes have plenty of power and take off like a rocket. I get her up , throttle back to about 1/2 and watch her cruiser around. I am checking the slow speed with gear down. It has a pretty gentle stall. Drops a wing tip a little then the nose drops. I come by for a few low speed passes.
I bring her in for a touch and go, well crap this sucks, no nose wheel. So I pull the gear up and cycle them a few times. Nope, no nose wheel. So I bring her in as slow and low as I can. She touches down, rolls about 2 feet on her nose. tore out the LED I had in the nose and scratches up the nose a bit. Not real bad.
Well I guess you can say we had a good first day flying them. They for the most part came home in one piece. We will get them repaired and ready for the next time we go flying.
Buzz.
blvdbuzzard is online now Find More Posts by blvdbuzzard
Old Mar 21, 2016, 12:42 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
I've had problems with the main gear a couple of weeks ago; one would not deploy although it had been working for weeks. It's fortunate the retracts, although I find them quirky, are only about $9 at Motion RC. I ordered two and the one I replaced now works fine.
Old Mar 21, 2016, 07:42 PM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
All Dynam retracts have an issue with temperature - COLD. So if it is a colder day then you can strike them not working - even just one. It is unknown exactly what in them causes that, or why it is so random too.
And then other than that.... many of them are a bit flakey and can not work any time, yet fine other times.
The common "PZ" retracts around (from Hobbyking etc) do not do these things at all.
I replace ALL my Dynam retracts with PZ's!!!
Then you have a 100% reliably working retract system!!
PeterVRC is online now Find More Posts by PeterVRC
Old Mar 21, 2016, 10:45 PM
Joined Jul 2002
I am not sure what is wrong with the nose gear. I have to look at it. I may just order a set from hobbypartz if there is something really wrong with them. It may be as simple as the plug came loose or they melted. I know it was not the temps, temps were in the high 80's
She did fly well. Brothers with an engine out flew straight ahead and had not strange yaw to it.
Buzz.
Old Mar 22, 2016, 05:43 PM
Herman Munster is online now
Find More Posts by Herman Munster
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
I highly recommend replacing the gear with Parkzone gear. I replaced the gear, on my GC, shortly after I got it with the Parkzone gear and haven't had an issue since, and I've had my GC for over 5 yrs, and it gets flown a lot.
I had a prop come loose during flight and didn't even realize something was wrong. The only time it had an tendency to yaw was if quickly applied full throttle at a slow speed, other than that I couldn't tell that it was flying on only one engine.
Herman Munster is online now Find More Posts by Herman Munster
Old Mar 23, 2016, 09:16 AM
USA, TN, Oak Ridge
Joined Apr 2004
The magic temperature for mine to stop working was right around 45F. Never did understand how the temp affected those gear. I traded my GC about two years ago, and have always regretted doing that. I think I'm going to have to pick up another this summer.
Sold toyota land cruiser flynfred Cars - Trucks and Parts (FS/W) 0 Sep 27, 2010 05:48 PM
Discussion Groupner "Commodore" cabin cruiser oztruck Scale Boats 2 Sep 15, 2010 07:06 AM
Wanted controller for New Bright PT Cruiser jclush Cars - Accessories (FS/W) 0 Sep 11, 2010 12:31 PM
Sold Sea Cruiser II & Kadet Senior dls Aircraft - Fuel - Airplanes (FS/W) 3 Sep 06, 2010 04:46 PM
Discussion Sterling 32' Cruiser or the Berkley 22' Express Cruiser RussellTate Scale Boats 15 Oct 26, 2009 09:41 PM
