Old Apr 29, 2011, 10:33 AM
Joined Oct 2010
What brushless motor is good for to produce 1000g of thrust
and what props would produce over 1000grams of thrust
thank you
rcplaneliker is offline Find More Posts by rcplaneliker
Old Apr 29, 2011, 10:45 AM
Staffs, UK
Joined Nov 2003
Just stating thrust tells us almost nothing though you will first have to decide decide whether you mean 100g or 1000g. Then decide what size battery you want to use (number of cells). Then what sort of speed you want to fly at. Then how much you want to pay.
When you get that sorted out there will still be dozens (at least) of motor/prop combinations that could meet your requirements.
Steve
slipstick is offline Find More Posts by slipstick
Old Apr 29, 2011, 11:38 AM
Joined Oct 2010
Steve
yes i mean 1000 grams an i wan to use 3cell lipo, i dont want to go top speed or i just want to cruise around.
Old Apr 29, 2011, 01:04 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Just a few of many 100 examples:
Suppo A2217K-8T (70g, ~1175Kv) with a 10x6 GWS HD:
10.7v, 20.80A, 222W, 9030rpm, 51.3mph, 1135g, 39.97oz, 5.11g/W
or:
ARC 28-47-1.5 (115g, 2920Kv) with a Zagi Carbon 5x5
10.8v, 39.70A, 426W, 25560rpm, 118.6mph, 1000g, 35.21oz, 2.32g/W
or:
Justgofly 550XT 12-magnet (90g, ~825Kv) with a 13x4 APC E
10.7v, 15.7A, 169W, 6450rpm, 24.43mph, 1160g, 40.96oz, 6.86g/W
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jul 19, 2011, 08:46 AM
Joined Jul 2011
THrust
What is actually this thrust?
Does this mean that 1000 grams thrust can make a aircraft of 500grams fly?
*considering good wings and all
shaunak1234 is offline Find More Posts by shaunak1234
Old Jul 19, 2011, 11:05 AM
Staffs, UK
Joined Nov 2003
1000g of static thrust can potentially fly an aircraft up to about 3000g in weight. If the plane only weighs 500g it will hover and/or take off vertically.
Steve
Old Jul 19, 2011, 06:00 PM
Jack
USA, ME, Ellsworth
Joined May 2008
thank you
http://www.flybrushless.com/
The prop database there will show you a bunch of props. Pick the ones you might want to use and you can see the thrust to RPM graph for it and also, below that, the motor that produced the data for the chart.
Jack
jackerbes is online now Find More Posts by jackerbes
Old Jul 19, 2011, 06:51 PM
Joined Jul 2006
Thrust, painted with a broad brush, is merely a measurement of how hard a plane will climb.
If we had a plane that weighed, say, 1 pound, or 16 ounces.... and our motor/prop combo was able to develop 12 ounces of thrust, we would have enough to do some nice climbouts, and enough to do some mild aerobatics.
If our motor/prop combo could develop 16 ounces of thrust, then the climbouts would be even steeper, and since we are developing the same thrust as the plane's weight, we could maybe get it to almost 'hover'.
And if the motor/prop combo developed say 32 ounces of thrust (twice the plane's weight) then it would have enough power to climb vertically right out of sight.
This is just a simple explanation, but there's really no sense in flooding you with a bunch of technical terms that you'll be learning in the future.... all in good time...
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Jul 20, 2011, 05:03 PM
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
I always pick the size of the prop that suits the plane first,
then how many rpm to get the thrust required Using Doc Kiwis thrust charts .
olmod is online now Find More Posts by olmod
Latest blog entry: For motor builders
Old Jul 21, 2011, 01:55 PM
mostly newbie
shimniok's Avatar
United States, CO, Centennial
Joined May 2011
I'm continuing to learn, too.
@rcplaneliker: I have a dumb question: why do you need 1000g of thrust? For aerobatics? How much does the plane weigh?
shimniok is offline Find More Posts by shimniok
Old May 17, 2013, 11:36 PM
Registered Peruser
Joined May 2013
This super helped my x-4 FPV quad build. The model is crazy heavy. and im wanting long flight time if i have an efficient prop motor battery combo it should hover at minimal amps
AnythingRC1989 is offline Find More Posts by AnythingRC1989
Old Yesterday, 05:54 AM
Jack
USA, ME, Ellsworth
Joined May 2008
One of the things that you can see for each prop there at flybrushless.com is the input power, RPM, and thrust at various RPMs. And, generally speaking, any motor that can give you the same RPM will give you the same thrust but also needs to have that same input power (or more than that if it is attaining that RPM at partial throttle).
Jack
Discussion What motor for a quadrotor would provide maximum thrust? Digimas Multirotor Talk 9 Apr 04, 2011 04:31 AM
Help! what is a good combo for a 3000 kv brushless motor warhawk crazy Power Systems 10 May 24, 2009 01:06 AM
Discussion ~75mm fan for 1000g thrust? rdeis Electric Ducted Fan Jet Talk 4 Mar 23, 2007 01:20 PM
Discussion Looking for a set up that will produce 2kg of thrust jhdgkss Electric Ducted Fan Jet Talk 3 Apr 03, 2006 07:25 AM
What brushless motor is good for aerohawk helisfreak Micro Helis 1 May 05, 2004 09:02 AM
