Old May 10, 2016, 09:25 AM
carteraveri is offline
Find More Posts by carteraveri
United States, LA, Opelousas
Joined May 2016
reverse cable
Can anyone tell me what a servo reversing cable is used for?
carteraveri is offline Find More Posts by carteraveri
Old May 10, 2016, 09:39 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
The hint is in the name...it's used to reverse the direction the servo turns in.
These days since it's so easy to reverse servos in the TX they're only really useful when you have two servos on a Y-lead driving ailerons or elevator and you can't easily move the servo to get it turning correctly. Never needed one myself.
Steve
slipstick is online now Find More Posts by slipstick
Old May 10, 2016, 09:52 AM
Joined May 2016
I installed a eflite safe receiver in a pulse 15e and it will turn inverted by itself when I put it in beginner mode. Trying to find out what is causing it.
Old May 10, 2016, 09:53 AM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Steve
Exactly - I needed one for the elevator on my F/A-18E because they are both on a y-harness. Since I couldn't mount it backwards, I had to buy a reversing cable.
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old May 10, 2016, 09:55 AM
Joined May 2016
I installed a reversing cable but the ailerons will move in the same direction
Old May 10, 2016, 10:16 AM
Lynxman is offline
Find More Posts by Lynxman
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
You don't use then for ailerons, but for flaps or elevators where the servos are installed in a mirrored arrangement. Ailerons operate correctly without a reversing lead.
Lynxman is offline Find More Posts by Lynxman
Old May 10, 2016, 10:18 AM
Joined May 2016
I was told that I need a reversing cable for that ailerons.
Old May 10, 2016, 10:34 AM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
United States, AR
Joined Nov 2014
It is the wrong rec!
BHOFM is offline Find More Posts by BHOFM
Old May 10, 2016, 10:49 AM
ChillPhatCat is offline
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
It was bad advice.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old May 10, 2016, 10:57 AM
Tucci is offline
Find More Posts by Tucci
Learn to build with wood.
Tucci's Avatar
United States, NC, Newport
Joined Sep 2012
Receiver mounted upside down?
Tucci is offline Find More Posts by Tucci
Old May 10, 2016, 11:39 AM
Joined May 2016
It is mounted just like in an apprentice
Old May 10, 2016, 11:52 AM
taz101 is online now
Find More Posts by taz101
taz101's Avatar
Australia, QLD, Gold Coast
Joined Oct 2010
Originally Posted by ChillPhatCat View Post
It was bad advice.
Guys, he has put a 'Safe' RX in a plane that it is not programmed for.
The AS3X system in the Safe RX's cannot be programmed. And because it (the RX) was designed for a different plane, on some planes you have to reverse some of the control surfaces. The easiest way to do this for some, is a servo reverser. Others can physically swap the servos around or even the servo arms.
It is all plane dependant. Each plane is different, unfortunately.
So, he was infact not given the wrong advice.
carteraveri, you are just going to confuse yourself with this thread and asking questions in the Safe thread aswell. Best off closing this one and listening to the guys in the other thread. As they are the ones that know what you need to do!!
LURCH
taz101 is online now Find More Posts by taz101
Old May 10, 2016, 11:56 AM
Joined May 2016
LURCH
Ok thanks
Discussion Walt Mooney Boston Revere Speedster build scigs30 Free Flight 9 Apr 12, 2010 10:32 PM
Help! Motor reveres on puch out Hellysmack Mini Helis 13 Mar 30, 2008 10:00 AM
do i need normal rotation or revers rotation to use with gearbox? daltrey Electric Plane Talk 5 Dec 11, 2004 12:21 PM
F/S Hacker B20-18L New rever mounted or ran. rickc Aircraft - Electric - Helis (FS/W) 3 May 30, 2004 10:08 PM
Cool Looking for Books/reverence for basic building aeajr The Builders Workshop 5 Sep 25, 2003 05:58 AM
