Old May 08, 2016, 06:37 AM
noamhagai8084 is offline
Find More Posts by noamhagai8084
Joined Apr 2016
Hobbyking 1620mm Beaver ARF
Hello
I plan to put an Rx battery pack in my new balsa model the Beaver 1620mm wingspan by Hobbyking
And I was wondering what size of pack to use
Thinking to use the Zippy 1600mah pack that weight about 88g
or go for something a little bit smaller like the 1100mah or even 700mah.
the battery need to power the reciver, 4 servos and LED light system that consumes 30mah.
specs :
Beaver 1620mm balsa
Servos : AeroStar™ AS-470HB High Torque Standard Servo 6.21kg / 0.12sec / 48.5g
Reciver : JR PROPO RG812X
Light system : Turnigy R/C LED Lighting System
any suggestions ?
thanks
noamhagai8084 is offline Find More Posts by noamhagai8084
Old May 17, 2016, 04:29 AM
Joined Apr 2016
Up.
Old May 17, 2016, 07:21 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
http://www.buddyrc.com/a123a-2s1p-receiver.html
Charles
Old May 17, 2016, 08:38 AM
Jaketheone46 is offline
Find More Posts by Jaketheone46
Jaketheone46
United States, KY, Florence
Joined Nov 2014
I use the zippy 1100mah 2s 6.6v life pack for all my receivers and if I don't think it's enough at first I'd run 2 parallel to get a idea of what's being consumed in a few flights. Then decide on my final setup. So far 1 has always worked for me. Heck even the 700 mah does the job I just like extra just in case.
Jaketheone46 is offline Find More Posts by Jaketheone46
Old May 21, 2016, 01:34 AM
Joined Apr 2016
Can you tell me on what servos do you test the 1100 pack?
Noam
For Sale Brand new 1620mm (64") Balsa Piper J-3 ARF xzd Aircraft - Electric - Airplanes (FS/W) 0 Jan 09, 2016 09:52 PM
For Sale Brand new 1620mm (64") Balsa Piper J-3 ARF xzd Aircraft - Electric - Airplanes (FS/W) 3 Jan 03, 2016 11:18 PM
Discussion VQ DHC-2 Beaver .46 ARF HobbyKing Lambro Fuel Plane Talk 128 May 29, 2014 05:55 PM
Discussion Hobbyking DHC-2 Beaver (Bush Plane) ARF CrashingDutchman Parkflyers 77 Sep 16, 2010 11:22 AM
Discussion DHC-2 Beaver (Bush Plane) STOL EP ARF from Hobbyking maestros Scale ARF/RTF 4 Apr 27, 2010 03:17 PM
