Old Apr 17, 2016, 07:31 AM
John.G is offline
Find More Posts by John.G
love to fly, hate to crash
John.G's Avatar
Fort Erie Ont. Canada
Joined Jan 2005
Question
Is there a better way to remove paint from foam
Hi guys, sorry to ask but I looked through a few pages and not able to find anything so I will ask. I have removed paint before on a foamy using the tape method and rubbing alcohol(I think that's what it was) with good results but its been a while so didn't know if things have change. I picked up a well worn P.Z. SE5a 480 size plane that has been repainted and not to my liking. So I am going to do a repaint and wonder if there are any new ways of paint remove from foam or if its still the apply the tape and pull the paint off. I see that the old decals where painted over as well so I need to figure a way to remove those as well. I'm just thinking of applying the tape and pulling the paint off and what stay's behind giving it a light sanding to the airframe and then paint it. I'm using Rustulom paint and primer all in one as it gives good coverage when dusted on in light coats. So any new way of paint removal you can tell me about would be great. John
John.G is offline Find More Posts by John.G
Old May 19, 2016, 10:41 AM
flyrc61 is offline
Find More Posts by flyrc61
flyrc61's Avatar
United States, NY, New York
Joined Feb 2011
John
You could use acetone to remove the paint and stickers, will not harm the foam.
John
flyrc61 is offline Find More Posts by flyrc61
Old May 19, 2016, 12:01 PM
KRProton is offline
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
I once used compressed air - blew the paint right off!
Use care of course and may work better (or worse) on different kinds of foam and paint.
Tim
KRProton is offline Find More Posts by KRProton
Old May 22, 2016, 07:59 PM
FieldofDreamsFlyer is offline
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
Oven cleaner works as well
FieldofDreamsFlyer is offline Find More Posts by FieldofDreamsFlyer
Mini-HowTo Removing paint from foam without hurting the foam SteveC68 Foamy EDFs 26 Feb 28, 2015 08:46 PM
Question REMOVING paint from Multiplex foam bozodude Foamies (Kits) 3 Jan 05, 2014 11:18 PM
Is there a good way to remove hot glue from EPP foam Mat Foamies (Kits) 2 Jul 21, 2004 03:51 PM
Is there a good way to remove hot glue from EPP foam Mat The Builders Workshop 0 Jul 21, 2004 11:57 AM
Is there a better way to order from the US to Canada? Martin Hunter Electric Plane Talk 22 Sep 21, 2002 03:02 PM
