Old Sep 18, 2015, 08:55 AM
Teddy Ong is offline
Find More Posts by Teddy Ong
Teddy Ong
Teddy Ong's Avatar
Joined Nov 2012
Which is the best WW2 bomber to build?
Hi folks! I'm thinking of building a WW2 Era bomber with limited wingspan of 80cm-100cm. I have previously done some load-carrying aircraft, but not historical.
So, which is the best bomber! Time to open fire!
Consider dry weight, bomb load, aerodynamics, looks etc
Currently I'm thinking of the mosquito, any other ideas?
Also, is there an easy way to make open-and-close bomb bay doors with enough strength to withstand some weight? Or some internal release mechanism? Ideas pls, thank you!
Teddy Ong is offline Find More Posts by Teddy Ong
Old Sep 18, 2015, 10:14 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Trouble is, the more 'gadgets' you add the heavier it gets. 80 - 100cm is pretty small.
eflightray is offline Find More Posts by eflightray
Old Sep 18, 2015, 10:18 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Though having said that, Guillows do four multi-motor models just over the 1meter span.
B-17, B-24, P-38, and PBY5.
Old Sep 18, 2015, 12:07 PM
IAFoamie is offline
Find More Posts by IAFoamie
IAFoamie's Avatar
Joined May 2012
My 2 cents the Douglas A-26 Invader
IAFoamie is offline Find More Posts by IAFoamie
Old Sep 19, 2015, 01:51 AM
TomKat is offline
Find More Posts by TomKat
Joined Nov 2006
Have you considered a single engine , like the Grumman Avenger or the Curtiss SB2C-1 Helldiver. As single engine aircraft of generouse wing area you don't have the weight or mass of nacelles & extra esc to drag through the air, leaving more of the lifting ability to use for scale details. ........... ken
TomKat is offline Find More Posts by TomKat
Old Sep 19, 2015, 02:02 AM
TomKat is offline
Joined Nov 2006
I know I've already put in my two cents , but what about a Stuka , or any bi-plane . They don't have retracts and carry their bombs on external racks , not Bombay doors only bomb releases to deal with . Ideas for releases might be found in the sailplane forums. ........ ken
Old Sep 19, 2015, 07:40 AM
awrightbrother is offline
Find More Posts by awrightbrother
Wowplanes.com
awrightbrother's Avatar
Florida
Joined Nov 2007
I have some nice bombers from 55" to 80" span. Check them out at http://www.wowplanes.com
awrightbrother is offline Find More Posts by awrightbrother
Old Sep 19, 2015, 10:02 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Big Horten wing ...
gpw is offline Find More Posts by gpw
Old Sep 19, 2015, 11:40 AM
insomaniac45 is offline
Find More Posts by insomaniac45
Not always grumpy!!
insomaniac45's Avatar
UK, Eastleigh, Eastleigh
Joined Jul 2010
and how many of those are capable of being converted to flying models. I knw the B-17 is a static model
but, yes the Mosquito would be very nice at that size. just make sure you have Counter rotating props, to eliminate torque roll they were a bitch if one engine went
The trouble is, 100cm is not alot of wing for 4 engines, 2 perfect,
so i would consider,
Mosquito,
P-38,
the less commonly known Westland Whirlwind
AW38 Whitley,
Avro 679 Manchester,
Bristol Beaufort,
Bristol Blenheim,
Handley Page, Hampden
or the vickers Wellington.
All the above are classed as medium bombers, and all are twin engined. Great for the size you want to do,
My favorites, are the Mozzie, and the Blenheim. But there are some great examples from germany like the Heinkel,
insomaniac45 is offline Find More Posts by insomaniac45
Old Sep 19, 2015, 06:35 PM
wwmoggy is offline
Find More Posts by wwmoggy
Canada, ON, Peterborough
Joined Dec 2014
Beriev MBR-2 Russian flying boat
wwmoggy is offline Find More Posts by wwmoggy
Old Sep 20, 2015, 12:20 AM
Teddy Ong
Teddy Ong's Avatar
Joined Nov 2012
Thanks for the reply guys! A Stuka would be cool, but the wing could be troublesome, will read up more.
Maybe you're right that medium bombers don't have enough wing area at this scale...
Old Sep 20, 2015, 12:29 AM
JD-Slow-Thumbs is offline
Find More Posts by JD-Slow-Thumbs
Requires Further Research :)
Joined Feb 2010
FWIW one of the most popular WWII era twin engine warbirds is the the B-25-Mitchell. I think it used-to-be sold by both TowerHobbies and HorizonHobby, now I see it sold by HobbyKing and NitroPlanes. Pretty sure that it is in most of the RC-Flight-Simulators; RealFlight, Phoenix, and ClearView.
After looking at more pictures of it I think the B-25-Mitchell would work well if built out of flat sheets of foam. (Foamies-Scratchbuilt)
Good luck
JD
P.S. I started out comparing it to the DC3/C-47-SkyTrain-Dakota, and I decided that the C-47 has a lot of round fuselage that would be harder to build using sheets of foam.
JD-Slow-Thumbs is offline Find More Posts by JD-Slow-Thumbs
Old Sep 20, 2015, 06:42 AM
Not always grumpy!!
Joined Jul 2010
not really, as you can roll the foam quite easily, just takes pratice. As for the nose, form it out of solid foam, carve it, sand it, model it
the B-25 is quite beautiful, but i also like the lines of the C-47, and what it stands for It wasnt a bomber, but it did pretty much all the heavy lifting of WW2, without the C-47, i think the outcome of WW2 would have been very different. But again this can be said about many planes. but i have always been drawn to the C-47 (DC3)
Old Sep 20, 2015, 10:09 AM
nuteman is offline
Find More Posts by nuteman
Joined Apr 2013
Lockey's Mosquito came out beautifully and flew great (when both motors/props were working).
He did it slightly "off-scale" to keep the handling somewhat tamer.
See post 103 here for the maiden flight: http://www.rcgroups.com/forums/showt...2208432&page=7
One of his props came-off, but once he worked that out it flew great.
nuteman is offline Find More Posts by nuteman
Old Sep 20, 2015, 12:38 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Use a flat sheet build Profile type.
Reasonably quick /easily built.
Airtime is what it's All about with Foamies
Look! in the Stickies at the top of this Forum.
Really good chance you can find something that appeals.
Bare is offline Find More Posts by Bare
Discussion Web Videos: Thundering P-47s, WW2 Test Pilots, F-105s, WW2 Subs, 8th AF Bombers zeno Other Websites 0 Jul 12, 2012 01:11 PM
Discussion Web Videos: Thunderbolts attack, WW2 Carriers & Subs, plus bombers against Rommel zeno Other Websites 0 Feb 10, 2012 12:03 PM
Discussion Which is the best simulator/model to practice take offs and landings WW2 planes? _-:I:-_ Simulators 5 Jul 05, 2011 12:09 PM
Sold Bristol Blenheim WW2 British Light Bomber kit Kilowatts Aircraft - Electric - Airplanes (FS/W) 0 Nov 19, 2009 12:55 PM
WW2 bomber book and thoughts... Mikey C. Electric Plane Talk 0 Dec 27, 2003 01:14 AM
