Old Sep 11, 2012, 02:24 PM
moto mike is offline
Find More Posts by moto mike
moto mike's Avatar
Illinois
Joined Mar 2008
For those who are tinkerers, and are not satisfied with the touchy potentiometers, they might consider removing them from the board and wiring in something like this:
http://www.ebay.com/itm/5pc-Multi-Tu...item2eac2a595d
You could then mount the pots remotely so that you could access them from the exterior of the airplane. Of course, I have not measured the value of the existing pots so don't know if 100k ohm are appropriate or not. these pots take the entire range of the potentiometer and spread it out over 25 turns (dependign on the pot) they are small and they are light and in this case, cheap.
I'm not saying this needs to be done and I know that the price of admission is $15 and you could say, what do you expect for 15 bucks? But if you are handy, this is very do-able.
moto mike is offline Find More Posts by moto mike
Old Sep 11, 2012, 03:27 PM
richard9999 is offline
Find More Posts by richard9999
richard9999's Avatar
Sydney, Australia
Joined Jan 2007
The ORX pots are 10k.
richard9999 is offline Find More Posts by richard9999
Old Sep 12, 2012, 09:13 AM
Beancounter is offline
Find More Posts by Beancounter
Beancounter's Avatar
United States, MA, Sterling
Joined Sep 2009
I have 2 of these for sale, brand new with connectors.
http://www.rcgroups.com/forums/showt...0#post22712493
Beancounter is offline Find More Posts by Beancounter
Old Sep 12, 2012, 11:09 PM
tengarang is offline
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
subscribing
http://www.hobbyking.com/hobbyking/s...19X4383X53.pdf
I find this document to be very informative and helpful.
tengarang is offline Find More Posts by tengarang
Old Sep 13, 2012, 05:14 AM
dav3uk is offline
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Originally Posted by tengarang View Post
subscribing
Its a good stab at a manual pity they get the aileron setup reversed....
"Aileron:
Now with everything powered up, Turn the Aileron Dial all the way Clockwise (CW) to full gain. Quickly Roll the airplane Right. The right aileron should have lifted when you were rolling it right."
The right aileron should drop..........to try to lift the right wing if rolled to the right.
Set it up like this and its gonna be a short flight........
Dave
dav3uk is offline Find More Posts by dav3uk
Old Sep 13, 2012, 03:55 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
subscribing
I wish whomever uploaded it would delete it.
I wrote that and someone found a critical mistake that I later corrected.
Here is a link to the post with the correct most updated version
http://www.rcgroups.com/forums/showp...&postcount=300
This attachement is easily found by doing a search attacments in this thread.
thx
Melnic is offline Find More Posts by Melnic
Old Sep 13, 2012, 04:37 PM
tengarang's Avatar
Joined Aug 2010
Thanks for bringing this to date Dav3uk and Melinic. effectively saved me from at least 1 casuality
Hobbyking please delete the files as they are incorrect on the files tab for this product.
thanks team
regards
tengarang
Old Sep 13, 2012, 10:01 PM
CurtissP40 is offline
Find More Posts by CurtissP40
Bona Fide Cub Nut
CurtissP40's Avatar
Northwest Oregon
Joined Jan 2006
thanks team
regards
tengarang
I Don't think Hobbyking has anything to do with this document.
CurtissP40 is offline Find More Posts by CurtissP40
Old Sep 13, 2012, 10:21 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Hobbyking does not even monitor this thread I don't think. Try posting to a HobbyKing site.
Old Sep 13, 2012, 11:29 PM
tengarang's Avatar
Joined Aug 2010
will do
there should only be one document up to date...not a bunch of obsolete misleadng information...cause alot of good people uneeded grief...though they are there with good intentions...not pointing fingers...just makes life easier
Old Sep 13, 2012, 11:31 PM
tengarang's Avatar
Joined Aug 2010
thx
so will this setup routine be applicable for this as well? In terms of mechanical adjustments to avoid servo binding and all the CCW and CW step by step procedures?
http://rc-castle.com/shop/product_in...oducts_id=2318
Old Sep 15, 2012, 11:10 AM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Windy this morning, at the field.
While the other guys kept their stuff on the ground, the Parkzone F4F Wildcat -- with ORX -- was awesome.
Smooth and strong through gusts, with scale-like mild aerobatics (loops, rolls, inverted - the real thing was a sturdy, pudgy, slugger.....not an aerobatic diva!) .
pugsam is offline Find More Posts by pugsam
Old Sep 15, 2012, 11:49 AM
Schrottflyer is offline
Find More Posts by Schrottflyer
Deutschland, BY, Augsburg
Joined Nov 2010
Il get the RX3 last Week from the King, now i will fix it in Plane.
The Stabi has one Input for Ailerone and 2 Output for Servos
In my Orange RX are the 2 Servos in Ail and Aux how i must Program the TX
and fix the Wire from Servos. All Flaps going up and town together and i cant fly
Has onyone a Picture how il fix the Wires, Need Help thanks Schrotty
Schrottflyer is offline Find More Posts by Schrottflyer
Old Sep 15, 2012, 12:05 PM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Originally Posted by Schrottflyer View Post
......Has onyone a Picture how il fix the Wires, Need Help thanks Schrotty
Look just above the top post on this page.
Click on Thread Tools -- Show Attachments in this Thread.
That will bring-up a gallery of photos, including several showing setups.
Old Sep 15, 2012, 12:44 PM
dav3uk is offline
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Schrottflyer
If your plane has 2 standard servos and you used to have them connected with a Y lead into the RX just connect the Y lead from the 2 servos into Ail1 on the Stabi and connect the ail on the RX to the ail on the Stabi.
If your plane has 2 servos connected to 2 channels on the RX eg Ail and Aux1 and you mix these together for perhaps flapperons then you are out of luck as the unit does not support anything fancy. So if you want to use the unit you will need to Y lead the servos together and connect to Ail1. You will of course lose any mixing ability
The Ail2 pot on the Stabi is reversed from Ail1.....no one has come up with a good reason they did this........they just did, and 99.99% of people will not use the Ail2 port.
There is a work around however if you want to try the Stabi out on a model with flaperons.
Connect the unit between one of the servos and the RX, only that servo will react to the gyro so only 1 aileron will give corrections but it will work. The gain may need to be higher than normal to compensate. This however is a cheat that will result in asymetric roll inputs. No big deal with just slight corrections but may become noticable at higer gain settings. It also may induce bigger yaw reactions than normal but the Stabi should take care of that.
If in any doubt stick to the standard 2 servos on a Y lead connected to Ail1, thats what the unit was designed for and it can perform ok like that.
There are some unusual ways these can be used experimentaly, V tail, delta etc by mounting them at different attitude in the plane and alligning them differently but these experiments can lead to some strange and potentialy catastrophic effects.
Dave
Discussion 3 axis stabilizer by HK Early Electric Plane Talk 17 Nov 18, 2012 02:11 PM
New Product OrangeRX 3-Axis Flight Stabilizer 14g (advertised) nemoskull Scratchbuilt Indoor and Micro Models 7 Sep 21, 2012 09:50 PM
Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro eyeinsky1 Aerial Photography 3 Jun 06, 2012 03:38 PM
Sold CPD-4 Co-Pilot 2 axis flight stabilization system ecampos FPV Equipment (FS/W) 6 Oct 26, 2011 01:34 PM
Discussion ******* 3 axis gyro stabilized video gimbal powerblimp Aerial Photography 10 Feb 23, 2006 06:00 AM
