Old Mar 01, 2015, 06:24 PM
United States, MA, Scituate
Joined Apr 2007
Antenna question
I'm more curious than anything. If my receiver has two antenna, one long and one short, does the actual antenna on the long wire start at the receiver, or is it after the rubber piece?
Knowing this make it easier to loop around to be perpendicular.
gobigdave is offline Find More Posts by gobigdave
Old Mar 01, 2015, 07:37 PM
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
OK, assuming 2.4GHz here; the receiver antenna length for a typical system is ~31mm, so, the last 31mm would be the active portion, and is often covered with clear insulation.
Wintr is offline Find More Posts by Wintr
Old Mar 01, 2015, 07:51 PM
Joined Apr 2007
That implies it is the short are after the rubber piece. Make sense.
Thank you.
Discussion n00b question on antennas matrixman324 Multirotor Talk 3 Nov 08, 2014 07:51 PM
Help! antenna array question anamen DIY Electronics 2 Oct 27, 2014 02:38 PM
Question Spektrum AR400 antenna question smewr Radios 8 Oct 25, 2014 07:45 PM
Discussion Antenna question kpinnc Radios 5 Oct 17, 2014 06:39 PM
Question two dumb noob cp antenna questions Pa flyer FPV Talk 2 Sep 30, 2014 07:40 AM
