Old Feb 17, 2015, 08:45 PM
dbc
United States, FL, Brooksville
Joined Apr 2008
Picture and the manual for MK2 Sonic are now up at Tower website. And I'm not liking what I'm seeing. Many changes and none really look to be improvements:
Hatch is much smaller. Wings now glue together and mount in a saddle under fuse. Servos now inaccessible and inverted under wing. One piece elevator with shorter rudder.
Does anyone see these changes as improvements?
http://www.towerhobbies.com/manuals/...230_manual.pdf
dbc is offline Find More Posts by dbc
Old Feb 17, 2015, 09:22 PM
dbc
Joined Apr 2008
How tacky looking is this recommended ESC installation ????
Old Feb 17, 2015, 10:50 PM
United States, MO, Fenton
Joined Jan 2012
Fentonflyers is online now Find More Posts by Fentonflyers
Old Feb 18, 2015, 10:46 AM
I want just one more plane!
timwj1's Avatar
United States, ID, Idaho Falls
Joined Feb 2013
That is a great spot for cooling and there must not be room in the fuse for an ESC any more, but that looks horrid and I'd never buy one of these.
timwj1 is offline Find More Posts by timwj1
Old Feb 22, 2015, 08:36 AM
AMA 34191
Vulgar Vulture's Avatar
Fayetteville, PA
Joined Dec 2002
I think the new wing attachment IS an improvement. That being said I only bought mine because it was $65! How much is it now?
EDIT: I kinda' like the looks of their .46-.55 "Scanner".
http://phoenixmodel.com/Product.aspx?ProductId=17
Vulgar Vulture is offline Find More Posts by Vulgar Vulture
Old Feb 22, 2015, 10:08 AM
dbc
Joined Apr 2008
Originally Posted by Vulgar Vulture View Post
I think the new wing attachment IS an improvement.......
I guess it could be considered an improvement as there are some minor issues with the current setup. The serious downside I see is that the saddle cutout in the lower fuse probably required the smaller hatch to retain enough axial (bending) strength in the area of the fuse over the wing.
The larger Phoenix Tiger Sport wing mounting design is like the new Sonic - including a small hatch. I really like my Tiger but the small hatch is a little inconvenient.
I think Tower has indicated the Scanner is coming.
Old Feb 22, 2015, 11:19 AM
Joined Jan 2012
That Scanner looks like a Kaos.
http://www3.towerhobbies.com/cgi-bin...&I=LXZT80&P=ML
Old Feb 22, 2015, 05:18 PM
jpurcha's Avatar
Canada, MB, La Salle
Joined Sep 2004
Looks more like a Warlord. The Convertible would have been nice to have on this side of the pond.
http://phoenixmodel.com/Product.aspx?ProductId=332
jpurcha is offline Find More Posts by jpurcha
Latest blog entry: How time flies
Old Feb 22, 2015, 06:29 PM
umpf umpf
basser's Avatar
United States, NV, Sparks
Joined Nov 2008
so my sonic is done. well i still need a receiver. its on the way though.
im using a power 25 on a 4s 3000 and a 11x7 prop. i use this same set up on a pulse 25 and it works great. this set up draws about 50 amps.
basser is offline Find More Posts by basser
Old Feb 22, 2015, 06:32 PM
umpf umpf
basser's Avatar
Joined Nov 2008
just for fun here is a pulse 25 and a sonic. they are pretty much identical in size.
Old Feb 22, 2015, 06:33 PM
umpf umpf
basser's Avatar
Joined Nov 2008
so the dreaded part...balancing.....
verdict....................
i did remove more wood than first pic shows. i removed 1 more panel at rear of fuse on both sides.
elevator servo installed in the throttle spot to move cg forward.
motor extended a little more forward to help also.
the manual says to balance at 65 to 70 mm behind leading edge on wing.
im at 68mm with no weight added.. hells yeah
also using wing nut conversion for wing attach
Old Feb 22, 2015, 06:47 PM
umpf umpf
basser's Avatar
Joined Nov 2008
sonic build weight.
4.06 lbs with 4s 3000 lipo
64.90 oz. with 4s 3000 lipo.
3.292 lbs. no lipo
52.65 oz. no lipo.
lipo is 12.20 oz.
just for fun :
the pulse 25E weighs:
3.20 lbs no lipo.
51.10 oz. no lipo.
I still need a receiver. so that will add a few ounces.
at this point the pulse 25 is 2 ounces lighter than the sonic.
im very pleased with the results.
I think a smaller/lighter lipo would start to push this plane quickly to the tail heavy side.
it should be a decent flying aero-chine
Old Feb 23, 2015, 11:46 AM
dbc
Joined Apr 2008
That looks great basser, and it should fly very well.
My all stock Sonic weighs 4lb 1oz with the 3300 4s installed. But I used much lighter micro servos. I considered mounting the motor forward a bit like you did, but ended up just putting 1/2 ounce of weight on the inside of each fuse cheek.
I'm looking forward to hearing your flight report.
Old Feb 26, 2015, 01:47 PM
JamesonC's Avatar
United States, SC, Greer
Joined Feb 2014
I am strongly considering copying your look for my sonic. After seeing pictures of yours, I can't stand to look at mine!
JamesonC is offline Find More Posts by JamesonC
Old Mar 01, 2015, 09:58 PM
dbc
Joined Apr 2008
Aw.....your going to hurt your little Sonic's feelings. It can't help it if it's a bit homely. And it trys hard to make it up to you with fine flight manners.
Sold (WITHDRAWN) Sonic by Phoenix Models LPU $50 dbc Aircraft - Electric - Airplanes (FS/W) 10 Feb 21, 2014 10:57 AM
Help! Phoenix Models Sonic High Wing.. Please help!!! ace1726 Beginner Training Area (Fuel) 28 Sep 29, 2007 07:39 PM
For Sale Phoenix Models Sonic 25 with OS.25FX-$80 Stav5 Aircraft - Fuel - Airplanes (FS/W) 1 May 15, 2007 12:31 PM
Question Phoenixs Models Sonic 25 arf???? Pilot_Scott 3D / Fun Fly Fuel Planes 2 Nov 22, 2004 10:09 PM
Phoenix Models Sonic 25 High Wing ARF Sport trainer Bud Morrison Aircraft - Fuel - Airplanes (FS/W) 2 Feb 19, 2004 04:42 PM
