Old May 14, 2014, 01:03 PM
I want to go flying!
BE77 Pilot's Avatar
Joined May 2010
What are you guys getting for AUW?
BE77 Pilot is offline Find More Posts by BE77 Pilot
Old May 14, 2014, 02:06 PM
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
I'm at about 8lb 10oz with a 5000ma pack. Well, I was with the stock motor. Might have changed by an ounce or two now with the P-60. stock other than that.
V2rider is offline Find More Posts by V2rider
Old May 14, 2014, 07:39 PM
lost in the addiction of flyin
furballll's Avatar
Canada, BC, Kelowna
Joined Dec 2009
here is the video of the flights from last night
Gerry test flying Glens Carbon Cub with issues (2 min 5 sec)
furballll is offline Find More Posts by furballll
Old May 15, 2014, 06:48 AM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I assume you will call Horizon and they will replace the servo and any damage to the plane.
Bill
Prof100 is offline Find More Posts by Prof100
Latest blog entry: A123 2S 2500 mah wiring diagram
Old Jun 12, 2014, 06:33 PM
NUMB-LOCK's Avatar
United States, VA, Fairfax
Joined Jul 2008
Using the GoPro...
Hi All,
Got to go flying last weekend. Winds were approx 15+. First time using the GoPro and editing with GoPro Studio. I had my friend Andrew (and expert pilot) take it for a spin. Here are some snippets of the gang at Veteran's Field.
Veterans Field 6.8.2014, Bealeton, VA (1 min 56 sec)
If you enlarge the window, you may have to replay it for the HD to kick in.
Hope you enjoy this as much as I did putting it togetherů
Bob I.
NUMB-LOCK is offline Find More Posts by NUMB-LOCK
Old Jun 17, 2014, 05:28 AM
Paradise R/C Flyers in NY
bhcnomo's Avatar
United States, NY, Utica
Joined May 2010
a club member maiden flight of his carbon cub with wheel shoes
using a 72 mhz receiver
herald,s carbon cub (7 min 8 sec)
bhcnomo is offline Find More Posts by bhcnomo
Old Jun 30, 2014, 09:58 PM
Master of Repairs
kknox's Avatar
United States, UT, Grantsville
Joined Mar 2013
Removed post
kknox is offline Find More Posts by kknox
Old Jul 07, 2014, 04:16 PM
Retired RC Flyer
clt12981's Avatar
Jacksonville, Florida
Joined Jul 2008
Enough said !
clt12981 is offline Find More Posts by clt12981
Old Jul 14, 2014, 05:01 PM
Master of Repairs
kknox's Avatar
Joined Mar 2013
Has anyone had elevator servo problems??
Latest blog entry: Spitfire Repair
Old Jul 29, 2014, 12:17 PM
United States, ME, South Portland
Joined Mar 2008
I went thru the stock motor in just about a dozen flights.
If you note a vibration at high throttle settings, remove and reposition the prop til the vibration is gone. The vibration shakes the magnets loose.
EPBDDSB is offline Find More Posts by EPBDDSB
Old Jul 29, 2014, 09:02 PM
Joined May 2014
I have noticed that the motor prop hub gets out of whack and balance and you will pick up a bad prop vibration at different RPMs. Re-positioning helps if you get it right but it is trial and error method.
I ordered a replacement hub from Horizon to see if it would fix the problem but they sent me the wrong hub. It fits the motor but not the prop. But I was able to try a couple of different props including a a 15x6 Master Airscrew that flew it well.
Dadawada is offline Find More Posts by Dadawada
Old Aug 14, 2014, 11:14 PM
NUMB-LOCK's Avatar
Joined Jul 2008
Power 60
Originally Posted by Prof100 View Post
Want more power? A Power 60 will drop in with some drilling of the back of the stock motor mount to clear the retaining collar.
Bill
I think I'll go with your suggestion and use a Power 60. I've noticed a high pitch sound with a 6S 5000 on the stock motor which I've never heard with any other motor. And I'd rather change it now rather than wait to throw a magnet.
Bob I.
Old Aug 15, 2014, 06:06 AM
Prof100's Avatar
Joined Jul 2007
Bob I.
That will improve things.
Old Aug 16, 2014, 10:18 AM
furballll's Avatar
Canada, BC, Kelowna
Joined Dec 2009
following the failure of the elevator servo that resulted in a crash, Horizon was more than willing to make it right. Here is the retest fly of the plane.
http://youtu.be/yBPu9fkWa4s?list=UU8...4RGQBSzMpoYYuA
New Product E-Flite Carbon-Z Cub ChuckTseeker Scale ARF/RTF 13988 Yesterday 11:47 PM
Help! Painting a super cub (Z foam) BiddySlayer Foamies (Kits) 4 Apr 06, 2014 07:38 AM
Discussion Eflite Carbon Z Cub shadow102 Atlanta Area RC 32 Nov 12, 2013 03:18 PM
New Product E-Flite Carbon Z Cub....... ChuckTseeker Electric Plane Talk 0 Sep 05, 2013 05:13 AM
Sold E-flite Yak 54 C-Z BNF Basic New Airframe $250 shipped $220 local pick up rblos1123 Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2013 04:33 AM
