Old Apr 16, 2014, 07:36 PM
Joined Jan 2009
Build Log
Building Yak-18 (Max) 1.2 m wingspan.
Hi everybody.
I'm starting to build a Yak-18 (Max) out of foam board using SD 3V plans. I am a newbie in building and there are a lot of new things I learn as I go through. I'll share the pictures of my work progress with you. Your thoughts and suggestions are welcome .
Yak 18 (Max) Albanian Air Forces 1951 ( screenshot taken from FSX)
Description:
Plans from SD3V
Description: Plans from Scale Drawings and 3 D Views.
I wanted the wingspan to be 1.2 m so I scaled the plans with Sketchup and measured everything.
Description: I wanted the yak to have a wingspan of 1.2 m so I scaled the drawings using Sketchup.
Drawing everything with Sketchup to see how it will look like.
Description: Drawing everything in Sketchup to see how it will look like
Description:
Drawing on ArtCAM to cut with CNC.
Description: Planing and drawing everything in ArtCAM to cut with CNC.
Cutting with CNC.
Description: Cutting with CNC.
Starting to build the body.
Description: Building the body.
Description:
Description:
Description:
Description:
Description:
Description: Just to see how will it look like.
Description:
Description:
Description:
Description: Used carbon tube on horizontal and vertical stabilizer.
Description:
Description:
Used carbon rod on the horizontal and vertical stabilizer. Planing to use green tape as extra enforcement and at the same time as color for the plane.
Description: Thinking of using green tape to enforce the foam board and at the same time it will serve as color (planing to build the Yak - 18 of Albanian Air Forces used in 1951).
Description:
Description:
Description:
I'm not sure if I should use foam board or ply instead on the top.
Description: I'm thinking if I should use foam board or plywood on the top, what do you guys think.
Description:
Also for the motor mount I'm not sure if I should use foam board as pictured below or should I replace it with wood. The front part is made of wood anyway.
Description: Also I'm not sure if I should build the motor mount out of plywood instead of foam board. The front is made of wood anyway.
I found a piece of foam (20 mm thick) that has a plastic layer in the middle and I thought of making wheels out of it.
Description: I found e piece of 20 mm foam that has plastic in the middle so i thought making wheels (60 mm diameter).
To be continued . . .
AlbEagle is offline Find More Posts by AlbEagle
Old Apr 16, 2014, 10:37 PM
Los Angeles, CA
Joined Mar 2004
for 1st time, you are doing a great job
lv2soar is offline Find More Posts by lv2soar
Old Apr 17, 2014, 12:29 PM
Joined Jan 2009
Thank you Iv2soar
Old Apr 23, 2014, 06:41 PM
Joined Jan 2009
I had to use Duct Tape, had no other option.
Weight until now: wings with servos and wires 330 gr, body with vertical and horizontal stabilizer 170 gr. What do you guys think?
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Old Apr 23, 2014, 09:07 PM
FPV Proximity is FUN!
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Looks awesome! Can't wait to see it finished.
-Ben
fOaMmaSh87 is online now Find More Posts by fOaMmaSh87
Old Apr 24, 2014, 02:33 PM
Joined Jan 2009
Adding the star and the flag
Description:
Description:
Description:
Description:
Old Apr 25, 2014, 07:02 PM
Joined Jan 2009
I have been working on the canopy, not finished yet.
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Old Apr 25, 2014, 10:05 PM
DESIGNOSAUR
DesignGeek's Avatar
United States, MI, Wixom
Joined Jun 2002
Amazing job you are doing there!
DesignGeek is offline Find More Posts by DesignGeek
Old Apr 26, 2014, 02:48 PM
Joined Jan 2009
-Ben
Thank you to both of you
Old Apr 26, 2014, 02:53 PM
Joined Jan 2009
A quick update on the canopy
Description:
Description:
Description:
Description:
Description:
Description:
Old Apr 27, 2014, 11:44 AM
Joined Jan 2009
Progress update, I'll order retracts from HK .
Total weight until now is 760 gram with motor, servo, lipo 2200 mah . Only main and tail gears missing, and the front cover.
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Old Apr 27, 2014, 06:26 PM
Who dares, wins
addictedtoplanes's Avatar
Canada, ON, Guelph
Joined Jun 2012
WOW!! Looks great!
addictedtoplanes is online now Find More Posts by addictedtoplanes
Old Apr 27, 2014, 06:30 PM
Joined Jan 2009
Originally Posted by addictedtoplanes View Post
WOW!! Looks great!
Thanks addictedtoplanes
Old Apr 30, 2014, 05:27 PM
Joined Jan 2009
Finished the front
Description:
Old May 01, 2014, 12:57 AM
fOaMmaSh87's Avatar
Australia, WA, York
Joined May 2012
Looks very scale! Nice job
Build Log 1/7 Aermacchi M-346 / Yak-130 / T-100 2x90mm Composite Scratch Build ysolomon Scratchbuilt EDFs 113 Dec 07, 2014 08:14 PM
Help! Looking for Yak-18 Max plans AlbEagle Scale Drawings and Three Views 10 Nov 16, 2014 06:19 PM
Discussion DC-6 Build / scale 1:18 / 88" wingspan | QUESTIONS AlexanderB Scale Kit/Scratch Built 2 Nov 30, 2008 05:00 AM
Discussion Scratch-build motorglider-2,5 m wingspan Cristian23 Electric Sailplanes 22 Jul 05, 2008 03:49 PM
Discussion Scratch-build motorglider-2,5 m wingspan Cristian23 Beginner Training Area (Aircraft-Electric) 6 Jun 27, 2008 11:35 AM
