Old Feb 10, 2015, 01:39 AM
lv2soar is offline
Find More Posts by lv2soar
Los Angeles, CA
Joined Mar 2004
Help!
Damaged Elapor foam
I have a Multiplex plane that is made of Elapor
that the aileron got slightly crushed and warped. I read somewhere
that you can use Hot Water to restore the foam. Is that correct?
If so, whats the procedure? Thanks
lv2soar is offline Find More Posts by lv2soar
Old Feb 10, 2015, 03:19 AM
jiggz is offline
Find More Posts by jiggz
"its not a hobby its obsession
jiggz's Avatar
United Kingdom, Meopham
Joined Jul 2014
I poor boiling water into a large bowl and dip the miss shaped.foam in holding there for a.few.seconds and checking....u don't want to leave it to long else the foam cells will notice.like orange.skin
Some people cover in a cloth and gently iron over.to get.the heat in .....
jiggz is offline Find More Posts by jiggz
Old Feb 11, 2015, 09:11 AM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Yep foam soup is the answer. You can pour the water over the part, and if need be pull on the foam to help it. Do it in steps to work it back into place. If you get the foam too hot, as stated it will expand the beads too much. Easy fix, take the back side of a spoon and rub them down flat.
Glacier Girl is offline Find More Posts by Glacier Girl
Old Feb 14, 2015, 11:06 AM
Lou is offline
Lou
Find More Posts by Lou
Lou
Ground Penetration Tester
United States, VA, Waynesboro
Joined Dec 2005
Elapor Soup. Seach for it here, should be plenty of examples. Here is one of mine ....
http://www.rcgroups.com/forums/showthread.php?t=2304023
Do not get the water too hot, work slow and deliberate. Use wood braces, etc. to help with the bending. As you can see from my example above that careful planning and work will deliver excellent results for you.
Lou is offline Find More Posts by Lou
Old Feb 14, 2015, 05:00 PM
lv2soar is offline
Los Angeles, CA
Joined Mar 2004
Thank you for the help guys!
Question What filler stuff do people use to fix foam damage? Lancair 888 Electric Warbirds 20 Feb 06, 2015 11:49 AM
Article Multiplex Shark RR Electric Elapor Foam Plane Review Michael Heer Foamies (Kits) 17 Oct 29, 2014 12:04 PM
Sold Multiplex Sky Cat Elapor Foam plane - NIB arnard Aircraft - Electric - Airplanes (FS/W) 1 Jun 08, 2014 10:27 AM
Discussion EPO Foam, Elapor Foam and "Z" Foam drypipe Foamies (Scratchbuilt) 7 Feb 05, 2010 05:04 PM
Discussion EPO Foam, Elapor Foam and "Z" Foam drypipe Electric Warbirds 1 Feb 04, 2010 10:25 PM
