Old Jun 24, 2003, 07:29 PM
wolff2000 is offline
Find More Posts by wolff2000
Joined May 2003
Messuring current into motor
Can anyone tell me how to measure the current going from the controller to the motor. I have a cheep-o digital VOM and when I hook it up in series (I know how to do it correctly) I get a current reading (about what I expect) but the motor only hums. It does not turnover? BTW Everything works fine without the ammeter hooked up
The controller is a pixie 7P and a GWS-A motor.
Thanks for any information!!!!
wolff2000 is offline Find More Posts by wolff2000
Old Jun 25, 2003, 07:40 PM
Patrick del Castillo is offline
Find More Posts by Patrick del Castillo
Patrick del Castillo's Avatar
Olathe,KS,USA
Joined Oct 2000
Wolf,
Sounds like your ammeter is adding too much resistance to the circuit. Plus, it won't really give you a good result anyway, most ammeters are designed to measure low frequency stuff.
Best way is to use a shunt resistor (.001 ohms or so) and an oscilloscope.
Anybody else have an easy way to do this?
Patrick
Patrick del Castillo is offline Find More Posts by Patrick del Castillo
Old Jun 25, 2003, 11:06 PM
Joined May 2003
Look like I'm going to have to fork over a few bucks and buy a Astroflight Super Whatt Meter ........ $ 65.90
Oh well, I guess it's cheeper then a scope!
Thanks... J
Old Jul 04, 2003, 10:48 PM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
Why not measure the current on the battery side of the ESC rather than between the ESC and the motor? On the power side of the ESC the drain is all pure DC and not pulsed.
Measure the current with the motor off so you can record the draw of the Rx, ESC and servos at rest, then crank up the motor and record that value. Subtract the first reading from the second and you should have the current consumed by the motor, minus a little for heat lost in the ESC, or am I missing something here?
If I am, aren't we still just usually concerned about how the batteries will hold up to a given prop/motor combination and not "pure" power comsumption of the motor and that should include all of the drain on the batteries?
FoamCrusher
FoamCrusher is offline Find More Posts by FoamCrusher
Old Jul 05, 2003, 12:14 PM
Joined May 2003
Yeah, I came to the same (inexpensive) conclusion! Thanks!
Reversing current on motor yodasands Micro Helis 2 Mar 04, 2005 01:46 PM
How to measure no load current of a brushless motor? Hovertime Power Systems 21 May 23, 2004 08:28 PM
Measuring current between motor and controller wolff2000 Power Systems 4 Jun 25, 2003 06:35 AM
Getting a Pinion into a motor? YZYgold Electric Plane Talk 8 Nov 03, 2002 01:24 AM
Max current into speed 280 and speed 300? rcastab Power Systems 2 Sep 20, 2001 10:33 AM
