Old Oct 23, 2014, 01:59 PM
Joined Aug 2009
Airfoils selection for blended wing
Hi guys.
Need your advice about an airfoils selection and aerodynamics analysis.
I try to design the blended wing like on the photo but I am not sure what airfoils to chose to make it fly good. I understand that they should be S-foils with around zero or positive pitching moment but how to understand more detail or simulate in XFLR. Maybe some kind person help me with XFLR analysis
Some requirements:
Wingspan ~1.8m, weight ~5.5kg. I want to fly @90-100km/h as cruise, have a landing speed as minimum as possible, no aerobatic just good, stable airframe, also stable in windy weather.
Airfoils at the root and tip of the wing I presume around 13% and middle at the fuselage I want ~15% to get some volume inside.
In general, is this top-view shape is good/not bad or you see some poor design?
jetigm is offline Find More Posts by jetigm
Old Oct 24, 2014, 06:23 AM
Joined Aug 2005
The design is certainly pleasing to my eye in planform, but a roughly 1 meter length root chord at 15% thickness in section will be a lot of drag to overcome.
Since this is to be a powered model, unless you're striving for maximum efficiency, I'd just use your favorite symmetrical section and change the outer panels to full span control surfaces. The trimmed position of the control surfaces in flight will create a positive pitching moment similar to the specialized plank airfoils.
Good Luck!
DT56 is offline Find More Posts by DT56
Discussion Seeking a Complete Plan (airfoil, dimensions, washout) for Light Lift Glider Wing andrewwl Flying Wings 11 Oct 14, 2014 02:00 PM
Discussion Airfoil for (flat-winged) FT-22 ah6 Modeling Science 10 Sep 30, 2014 01:27 PM
Discussion Need help selecting an airfoil for a flying wing gauravag Flying Wings 7 May 09, 2014 12:20 PM
Discussion Blended Wing-Body 48in lift and airfoil Q...? uriah Foamy EDFs 0 Apr 17, 2007 10:21 PM
wing design question - blended airfoils wingnutt Flying Wings 11 May 28, 2005 07:37 PM
