Old Sep 19, 2014, 12:08 PM
Altbob is online now
Find More Posts by Altbob
Altbob's Avatar
Joined Oct 2012
Build Log
Chitty Chitty Bang Bang
Chitty Chitty Bang Bang was my favorite movie as a child, and when I had a son of my own it became our favorite movie to watch together as father and son. We wore out the VCR version and then later got the Deluxe DVD edition and we've watched it more times than I can guess at. At the same time, I've also passed on my interest in aviation, and before getting into RC planes together about 3 years ago, we cut our teeth designing, experimenting and flying paper models. The closest I've come to scratch building an RC plane was a Slow Stick I put together last year, but the experience taught me how to solder and wire up ESCs, motors, receivers and servos, find CG, etc. I've done a bit of reading about airfoil design with dollar store foam board ("DSFB"), and I am reasonably handy with tools, so I've decided to take a plunge and see if I can actually build a "Chitty Flyer" as a winter building project.
To keep things "simple", I am aiming to build a non-aerobatic, hopefully slow-flying, 2D profile foamie, loosely based on a design I came up with for the Redbull FlugTag video game. This online game was really popular with my son and me around 2008 when it came out, and allowed us to design, test and fly a whole bunch of 2D "flapping wing" models. The screen capture attached will give you an idea of what my Flugtag Chitty looked like and I am aiming for with this RC build.
BTW, you can still design and play with Flugtag online at:
http://www.redbullflightlab.com/
I'm certainly no aeronautical engineer and I know I am biting off a lot with this project, so I figured I'd reach out and see if anyone would be willing to help with this project or even just give some tips along the way should I get totally stuck. Thanks for reading and following along!
Altbob is online now Find More Posts by Altbob
Old Sep 19, 2014, 12:09 PM
Altbob's Avatar
Joined Oct 2012
To get things started, I am collecting some reference material. Here's some reference shots of the actual "flying car" used in the movie -
Old Sep 19, 2014, 12:20 PM
Altbob's Avatar
Joined Oct 2012
I'm attaching also a close-up of the profile from my FlugTag "Flight Lab" effort. If possible, I would like to retain the pusher prop configuration, because anything else wouldn't really be authentic.
Here are my initial questions:
1) If the center wing was lengthened a bit, perhaps with an airfoil camber, would it fly?
2) Would the front "winglet"screw things up? Could it somehow be used as a control canard, or to provide some extra lift?
3) Should I "fake it", and have a hinge in the back of the fuselage so that the rear of the car (made from a rowboat in the movie) can act as a rudder - OR - can the rear horizontal stab be given elevons, and fly by bank and yank?
FWIW, I want this thing to be about 3 feet in length so it turns some heads!
Thanks for playing along - hopefully someone out there shares my passion for the movie, the car and the challenge!
Old Sep 19, 2014, 12:30 PM
Tcat is offline
Find More Posts by Tcat
Joined Jul 2004
Grab some FFF or a sheet of depron and make about a 16" profile glider of it. That will allow you to determine the CG and if you need more aft lateral area. You will be able to see if it is possible to get it to fly. Should be possible, have fun, this is what the hobby is all about. The new 3-axis stabilized receivers are amazing and inexpensive. Some dihedral May be needed.
Tcat is offline Find More Posts by Tcat
Old Sep 19, 2014, 12:35 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
A profile model may just fly as the wing area is very small for anything like a 'full body'.
Some more pictures --- https://www.google.co.uk/search?q=Ch...ed=0CAYQ_AUoAQ
eflightray is online now Find More Posts by eflightray
Old Sep 19, 2014, 12:45 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
But then, a bit of searching, and --
http://www.flyelectric.ukgateway.net/chitti.htm
Even has the plans for download
Old Sep 19, 2014, 01:03 PM
Altbob's Avatar
Joined Oct 2012
Wow, thanks guys! Great and fast responses - the folks here at RCGroups are amazing
With all due deference to the link eflightray (or just "Ray"?), as cool as that plane is, it's not really a very scale profile of the "real" Chitty. Granted that was a full body effort, so the wings and tail had to be a lot bigger than the phantasmagorical car imagined by Ian Flemming, et al. But as a 2D flyer I think we can get closer to the original profile, don't you? I'm sure to crash the heck out of my prototypes, but "up from the ashes grow the roses of success, yes?"
Tcat - yes, a bit of dihedral will be necessary for sure, but I want to keep it to a minimum so I can stay "scale" I assume what you mean by "aft lateral area" are horizontal stabilizers of some kind? I had hoped that the winglet at the back end, using some form of elevon arrangement, might work. Obviously I'm going to have to play around a bit. I don't suppose there is any decent software for this kind of brainstorming, is there? I have Phoenix Sim and Phoenix Builder - has anyone tried that as a virtual testbed for a 2D profile design?
I am going to assume off the bat (knowing very little about quadcopters) that the idea of putting a vertical rotor on the end of each wingtip is simply too fanciful to work. If I'm wrong about that, chime in!
Old Sep 19, 2014, 01:36 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Considering there has been flying go-carts, flying race cars, even flying trucks, I suppose anything is possible, to a degree.
The major problem as I see it is wing area, the scale model just doesn't seem to have sufficient.
The above mentioned flying models use internal surfaces by allowing air to pass through the front, plus the prop is at the front increasing the airflow. Plus they are designed for minimum weight.
It could probably come down to how 'scale' the model needs to be.
Old Sep 19, 2014, 02:18 PM
Altbob's Avatar
Joined Oct 2012
Perhaps if I build it as a full fuse plane I can stick an EDF engine under the hood???
Old Sep 19, 2014, 02:28 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I think you need some or at least a after that quote.
Old Sep 19, 2014, 02:56 PM
Altbob's Avatar
Joined Oct 2012
You're right
I am of course willing to fudge the dimensions of the wings and winglets/canards a bit, in the interest of actually being able to fly a pattern with this thing. One thing that is somewhat notable is that the sweep of the wings was a little less on the car designed for the stage play vs. the movie. I think I can push this a little further and still look relatively authentic.
http://movi.ca/im/mio/chittybangwp1024.jpg
Old Sep 21, 2014, 06:11 PM
Thechittyfather is offline
Find More Posts by Thechittyfather
Damn this gets addictive.
Thechittyfather's Avatar
United Kingdom
Joined Oct 2011
Good choice. Hope you have success with this I'll be keeping an eye out.
I chose my handle because my first build was a chitty. I basically built a simplified version of the car out of foam and modified a EZfly to drag it around. Gave it a paint job with all the non chitty bits left white and it looked pretty cool in the air. I will attempt to upload a photo.
Graeme (tCF)
Thechittyfather is offline Find More Posts by Thechittyfather
Old Sep 22, 2014, 08:55 AM
Altbob's Avatar
Joined Oct 2012
Nice work Graeme!
Old Sep 22, 2014, 09:38 AM
United Kingdom
Joined Oct 2011
PS. Don't make the same mistake I did. I gave it working wheels but set the wing at 0 incidence to the wheels which made for very fast take offs. Funny watching it zoom around the field though.
Might have been made worse because I used a Kfm airfoil. Something with more lift might be ok.
Old Sep 22, 2014, 12:11 PM
Altbob's Avatar
Joined Oct 2012
Yeah, I want the smallest possible wing loading - this thing shouldn't fly all that fast. That's why I am thinking a 2-D foamie could be best.
Discussion Bang Bang! Bang Bang Bang! Bang Bang Bang Ping! logan5 Life, The Universe, and Politics 42 Apr 01, 2014 09:29 PM
Discussion Chitty Chitty Bang Bang Heading to Auction MtnGoat Life, The Universe, and Politics 18 Apr 27, 2011 01:12 AM
Himax/Phoenix25 goes like "Chitty Chitty Bang Bang" cabbie Power Systems 10 Oct 02, 2004 11:55 PM
