Old Feb 19, 2012, 07:54 PM
showmaster is offline
Find More Posts by showmaster
showmaster's Avatar
Joined Aug 2006
Originally Posted by Teamsherman View Post
So can someone tell me whats the best HobbyKing Lipo or other battery for this TX?
I bought this one on a hunch, was i right?
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Yes life batteries are a good choice. I use the 1400/1500 ma version and it fits the battery box.
http://www.hobbyking.com/hobbyking/s...5Fpack%5F.html
I'm sure the 1800 will as well because that's it's purpose.
The chemistry seems to be perfect for replacing nicads and not messing with the tx low battery alarm settings.
So far I'm very happy with my LiFe battery.
SM
showmaster is offline Find More Posts by showmaster
Old Feb 19, 2012, 08:28 PM
Mauricio2346 is offline
Find More Posts by Mauricio2346
Mauricio2346's Avatar
Medellín, Colombia
Joined Jan 2010
that battery works fine. remember that lower voltaje can trigger low voltage alarm on the radio. that's all.
im working with this one:
http://www.hobbyking.com/hobbyking/s...poly_Pack.html
it last for about 2 months of normal use between charges (simulator+radio). and is not puffed yet.
Mauricio2346 is offline Find More Posts by Mauricio2346
Old Feb 19, 2012, 11:12 PM
TyCarp is offline
Find More Posts by TyCarp
When in doubt, mumble
United States, NC, Lincolnton
Joined May 2008
What voltage do you let that lipo get to before recharging? Right now I have mine set at 10.5 just to protect the lipo. Have no idea if it can go lower
TyCarp is offline Find More Posts by TyCarp
Old Feb 20, 2012, 02:33 AM
ReSt is offline
Find More Posts by ReSt
Joined Jul 2009
I'm afraid it will not fit into the battery compartment with
Dimensions: 100mm x 27mm x 33mm
as the battery holder is 105mm x 30mm x 30mm only and has a tight fit already.
Reinhard
ReSt is offline Find More Posts by ReSt
Old Feb 20, 2012, 03:42 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Reinhard
I'll make it fit. If not, i'll tape it to the outside.
Teamsherman is offline Find More Posts by Teamsherman
Old Feb 20, 2012, 03:50 AM
redline022 is offline
Find More Posts by redline022
redline022's Avatar
Australia, QLD, Riverhills
Joined May 2010
I have that battery in mine and it fits just fine
redline022 is offline Find More Posts by redline022
Old Feb 20, 2012, 05:48 AM
Stuka_99 is offline
Find More Posts by Stuka_99
Callsign: Zulu
Stuka_99's Avatar
Somewhere in the skies!
Joined Feb 2011
I'm afraid it will fit too!
Life 1800 in 9x
Stuka_99 is offline Find More Posts by Stuka_99
Old Feb 20, 2012, 08:28 AM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Same here. It's a snug fit but not too tight. Doesn't need foam to keep it from moving around like the 1500.
Ted
G550Ted is offline Find More Posts by G550Ted
Old Feb 20, 2012, 09:00 AM
Medellín, Colombia
Joined Jan 2010
LiPos can get as low a 3.0V per cell, but, it's better to charge the battery when cell get 3.3V. remember always to balance battery after charging.
Regards;
Mauricio
Old Feb 20, 2012, 09:05 AM
drcigg is offline
Find More Posts by drcigg
drcigg's Avatar
United States, MN, Chaska
Joined Sep 2011
I just heard a rumor the Turnigy 9x has been discontinued and they are bring out a new model....
drcigg is offline Find More Posts by drcigg
Old Feb 20, 2012, 09:07 AM
Stuka_99 is offline
Callsign: Zulu
Stuka_99's Avatar
Joined Feb 2011
heard that too, wonder if its founded!
Old Feb 20, 2012, 09:11 AM
Danlb25 is offline
Find More Posts by Danlb25
United States, IA, Glenwood
Joined Jan 2012
Has anybody ordered from Leadershobby lately? If so what was delivery time and did you still get the module mounted anteanna?
Danlb25 is offline Find More Posts by Danlb25
Old Feb 20, 2012, 09:12 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
I hope it has a programming port pre-installed.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Feb 20, 2012, 09:13 AM
Stuka_99 is offline
Callsign: Zulu
Stuka_99's Avatar
Joined Feb 2011
Now, they get the bright idea to crank out another one just when I decided to order mine. Great!
Old Feb 20, 2012, 09:23 AM
showmaster's Avatar
Joined Aug 2006
I helped that rumor with a post after reading about the possibility on another thread. I did email FlySky that question since they make all the radios but no answer yet. There is no proof to back this rumor so I'm guilty of spreading it also.
What has me worried however is the sudden variations of CPU boards in the radios. Many are reporting getting the older boards with the programming pad error. Why so many old boards and alternate antenna locations all of a sudden?
Supplies drying up maybe?
Here is a "fact", there will be plenty of 9Xs at over $100 for some time to come.
Our concern is a under $80 supply
SM
For Sale Two Spektrums AR9000 DSM2 9-Channel Rx Brand NEW JR 2.4GHz theant1 Aircraft - General - Radio Equipment (FS/W) 1 Oct 19, 2008 09:00 PM
For Sale Two Spektrums AR9000 DSM2 9-Channel Rx Brand NEW JR 2.4GHz theant1 Aircraft - General - Radio Equipment (FS/W) 1 Oct 15, 2008 11:42 PM
Sold JR X9303 2.4ghz TX. With R921 9 channel 2.4ghz rx and a 6100 end pin RX cryhavoc38 Aircraft - General - Radio Equipment (FS/W) 5 Dec 26, 2007 02:01 PM
Discussion Next News: Kyosho 2.4GHz FHSS Rudy Vienna Radios 1 Feb 13, 2007 10:43 AM
Best 9 channel radio under $500? jwood Electric Plane Talk 9 Jan 31, 2002 04:30 AM
