Old Dec 07, 2014, 12:46 PM
Canada
Joined Dec 2006
Questions about Liquid sheeting/styrospray
I have to make mutiparts so I'm thinking about building a plug out of blue styrofoam
then coating it with many coats of Liquid Sheeting / styrospray. My question is this going to be strong enuf for vacum forming. Or is the heat going to go through the sheeting and melt the foam?
PETEREL is offline Find More Posts by PETEREL
Old Dec 07, 2014, 01:37 PM
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
I would not use foam of any description if I was making a plug for vacuum forming of (presumably), styrene or similar plastic sheet.
My first choice would be some laminated MDF sheet. Or even a well seasoned lump of timber that has good carving properties.
Much depends upon the shape you have in mind. One of the above will be preferred over the other for certain shapes and vice versa.
If it is a simple symmetrical shape, the laminated MDF has certain advantages; the joins make for a good guide for symmetry. The MDF can be sealed and stabilised by applying 3 coats of epoxy resin; the first coat thinned a bit with alcohol. Sanding in between.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Dec 07, 2014, 02:42 PM
Canada
Joined Dec 2006
Can I ask why not? It's just easy to carve the blue styroform
Old Dec 07, 2014, 02:46 PM
Joined Aug 2008
I don't think it would be rigid enough. Also, I have doubts about the heat problem you mention.
Give it a go if you think it would work though. A small sample plug could be shaped quickly as a test piece.
Old Dec 07, 2014, 05:18 PM
let's FLY!
JimZinVT's Avatar
United States, VT, Castleton
Joined Dec 2007
You are vacu-forming plastic sheet over this plug? The question then is what is the vacu-forming temperature going to be? As I recall, the melt point of EPS (blue foam) is somewhere in the mid 200s*F range (googling will find the exact number), so if your working temp is below that you should be fine. I don't know what liquid sheeting/styrospray is, but you'd want to check the melting point of that too. As Jim said, easy enough to cob up a test piece and see what happens. It is possible that styrofoam and styrene sheet have very close melting points? I haven't done any vacu-forming, but I doubt the vacuum used is strong enough to crush blue foam.
Then again, if you're pulling a lot of parts off this plug, foam might not be the best choice....very easy to accidentally scratch or dent it. I have enough trouble keeping a a foam wing core pristine before I can get it into the vac. bag.
- Jim
JimZinVT is online now Find More Posts by JimZinVT
Discussion Wowplane Liquid Sheeting Tommy D Scale ARF/RTF 95 Nov 05, 2013 07:56 PM
Discussion Question about Pink foam sheets from Home Depot SteveC68 The Builders Workshop 17 Nov 27, 2011 08:54 AM
Help! Questions about fiberglassing & Sheeting JurassicJet The Builders Workshop 26 Aug 01, 2011 02:29 PM
Discussion Wowplanes liquid sheeting mams1 Australia 1 Dec 22, 2008 07:13 PM
