Old Mar 19, 2015, 12:40 PM
Black_Angel's Avatar
Joined Jan 2015
Originally Posted by Busher View Post
Unless the yellow kbar has the governor function which mine hasn't, then your governor settings will be done in the esc not the FBL unit.
I suggest you use the card as it is much easier to set up the esc with that
ok sounds great....never done it before. I dont need anythine else than esc and the card? how it detect rpm?
BA
Black_Angel is offline Find More Posts by Black_Angel
Old Mar 19, 2015, 01:47 PM
Joined Apr 2011
BA
The esc, detects the rpm via the motor leads, and makes its calculation based on them, the software loop then feeds into the throttle loop and aims to keep the headspeed constant.
The card and the esc is all you need
Busher is online now Find More Posts by Busher
Old Mar 19, 2015, 02:20 PM
South London United Kingdom
Joined Jun 2003
Hi BA
Sorry if I misled you. I use the YEP 40a and a Kbar, and it works fine, but
I do not use governor.
Having said that, there a number of opinions as to how to set the governor.
You might find this thread useful
http://www.helifreak.com/showthread.php?t=444674
I think post 17 might be the closest to what I understand to be correct.
Let us know how you get on.
Cheers
Jeff
Border Lord is online now Find More Posts by Border Lord
Old Mar 20, 2015, 01:05 AM
Joined Sep 2013
Full Size Kbar spare power ports?
Hey guys Using 2 sats and Kbar and making a y harness to get 2 plugs from Rx Life pack into Vbar.
On the back side with usb cable is the common power supply and needed one more point to plug into. Will any of the other side be ok? There are a bout 5 ports free.
Diggiz is offline Find More Posts by Diggiz
Old Mar 20, 2015, 07:21 AM
Joined Jan 2015
Great thanks
BA
Old Mar 20, 2015, 07:23 AM
Joined Jan 2015
Originally Posted by Border Lord View Post
Hi BA
Cheers
Jeff
No problems Jeff..Yes i will post some updates...Im building a stretched Black Angel where i want to try governor..
BA
Old Mar 21, 2015, 02:12 PM
Joined Jun 2003
Hi Black Angel
Posts about governor prompted me to re-visit mine.
Started with my newly built Garrt GT450L, and used the sequence as in the link I posted to you.
Couple of random thoughts.
First of all, you enable gov store using the card, then unplug it and replace the esc wire.
Logic says you should leave the heli powered up while doing this. I did, but when I tried to spool up, nothing happened.
I can only assume when the esc is unplugged, it sees no signal, and goes to sleep.
Anyway, when you do yours, power down the model before unplugging the card.
Second, I was worried about spooling up to 100% without blades. Thought without the extra drag there was a danger of overspeeding the head.
As it happened, needn't have worried, all very sedate, however I did weigh the heli down with some magazines, and stepped well back, just in case.
Finally, I was expecting a dip in h/s when the esc registered the maximum.
In fact I got an increase in h/s. Ho hum.
Anyway, couldn't resist a quick hover, despite a howling gale.
Obviously couldn't fly for long, but enough to tell the governor has made a major difference.
Tomorrow threatens to be flyable, so I will post my impressions then, but so far, so good.
Cheers
Jef
Old Mar 23, 2015, 04:26 AM
Joined Jan 2015
I got quite disapointed today, i got my Hobbyking YEP 40A and connected it to my zippy compact and RX to bind to my taranis...but the esc just get hot and also no bec...so contacting HK on this...they should have some better qualitycontroll..
BA
Old Mar 23, 2015, 11:59 AM
Joined Jun 2003
Hi BA
I know you didn't but I have to ask.
Did you wire it up correctly?
Sorry
Jeff
Old Mar 24, 2015, 04:56 PM
France, IdF, Paris
Joined May 2007
BA
hello
Attention check the voltage I have a BEC 15v
AIRBUSA800 is offline Find More Posts by AIRBUSA800
For Sale Vintage Techi Models Mini Bar Fli pattern kit nero1156 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 15, 2013 07:40 PM
For Sale Vintage Techi Models Mini Bar Fli pattern kit nero1156 Aircraft - Fuel - Airplanes (FS/W) 1 Jan 28, 2013 02:27 PM
Sold Mikado Mini V-Bar Pro with 2 DSMX satts. e-heliflyer Aircraft - Electric - Helis (FS/W) 0 Jan 16, 2013 04:11 PM
Sold Mini V-Bar "Blueline" 5.3 Pro xxrando Aircraft - Electric - Helis (FS/W) 0 Jan 02, 2013 09:36 AM
Sold Vintage Free Flight Midwest FU-BAR '36' 1/2A Kit NIB $45.00 FREE SHIPPING!! stevster Aircraft - Fuel - Airplanes (FS/W) 2 Jan 14, 2012 08:07 PM
