Old Mar 15, 2015, 11:50 PM
United States, MA, Lowell
Joined May 2004
But discharging down to a resting voltage of 3.20v/cell IS overdischarged, isn't it? If you routinely flew your LiPos long enough each flight so that the resting voltage was 3.20V/cell after the flight, that battery is overdischarged. I understand that under load they routinely drop to 3.3V/cell near the end of the flight if you go WOT, but they don't stay there.
Neil_SC is offline Find More Posts by Neil_SC
Old Mar 16, 2015, 05:23 PM
Seattle
Joined Sep 2007
Well yes. But that was not the point of the users post. His concern is that the charge failed to stop at the set voltage.
Gregor99 is offline Find More Posts by Gregor99
Old Mar 23, 2015, 03:20 AM
Joined Mar 2014
Does anyone know if you can use the powerlab 8 as a bench power supply? surely the hardware is more than capable of doing this.. it would be an awesome feature that would make this incredibly useful charger even more amazing! I've seen the "Foam Cutter" mode but that doesn't appear to let you set the voltage.. only current.
F1nn is offline Find More Posts by F1nn
Old Mar 23, 2015, 06:15 AM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
I do not think you can use a buck/boost switched mode power supply (which is what the PL8 fundamentally is) for that purpose. It is inherently unstable when the output voltage is around the same value as the input voltage.
jj604 is offline Find More Posts by jj604
Old Mar 23, 2015, 07:25 AM
USA
Joined Jan 2002
There are no provisions for this, the charger was never intended to be used as a power supply.
Ohmic is offline Find More Posts by Ohmic
Old Mar 24, 2015, 08:42 AM
Joined Jun 2005
Originally Posted by Gregor99 View Post
Correct. Its a setting on the discharge tab, as well as configurable via the console. Bryon01 uploaded his preset and he has it set to 3.20v. I looked through the preset and didn't see any issues that would cause an over discharge. I'd like to see if his second attempt at discharging provides the same results.
I can do this, just been busy. Anyone else want to try as well?
bryon01 is offline Find More Posts by bryon01
Old Mar 25, 2015, 12:21 AM
Joined Mar 2014
Any decent buck/boost/sepic power supply will work well enough when input and output voltage are the same. besides i don't mind running the input at 24V to get 12V output in a purely buck situation, i believe the hardware is capable but there is just no preset mode for it.
Old Mar 25, 2015, 05:51 AM
ancora imparo
jj604's Avatar
Joined Jul 2005
That may be true but some LiPo chargers (which are buck/boost systems) are well documented as having problems with power supplies that are around their switch over point. I just wondered if the same thing might apply to the PL8 when used as a precison constant voltage source (constant current may not be an issue).
John
Old Yesterday, 06:35 PM
Joined Jun 2005
PL8 overdischarging at low current with CCCV and cell balance on
All I have learned is I don't trust this charger with these settings on so I recommend nobody else use it with CCCV and cell balance on discharge either. My biggest concern is whatever logic bug exists may also occur in some other combo of settings. I would like FMA to look into this.
Here is a graph with 1C discharge on a 4000mah pack. CCCV and cell balance on, does exactly what it should, and stopped correctly at 3.3V. The hysteresis in the cell balance was set to 3mV which was 1mV more than default.
Also attached is the same pack, only at 1/8th C discharge rate and 3.2V setpoint. I didn't charge it to test 3.3V cutoff, just set it to 3.2V and went. The only change to this discharge was the rate, the cuttoff, and I went back to 2mV hysteresis which I believe is the default. Again, the result would be a runaway dead battery if I wasn't watching it.
Old Yesterday, 09:13 PM
Seattle
Joined Sep 2007
Originally Posted by bryon01 View Post
Also attached is the same pack, only at 1/8th C discharge rate and 3.2V setpoint. .
OK so it works fine at 3.3v, but not at 3.2v? Not sure the charge rate has any impact, but I can look at that as well.
What wiring mode are you using? What balance adapter are you using? It may not be relevant, but in case I can't repro, it'd be good to know these things.
Discussion Sneak Peek! 2, 1:8 scale scratchbuilts ooby Scale Boats 32 Sep 17, 2014 03:09 PM
Discussion Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! Matt Halton Electric Ducted Fan Jet Talk 3 Dec 20, 2009 03:11 AM
Discussion Sneak Peek at the New Creation Museum Miami Mike Life, The Universe, and Politics 38 May 30, 2007 05:01 PM
Hey Mr. Lin, how about a sneak peek at the Hellcat? splatman GWS (Grand Wing Servo) 1 Jul 05, 2003 04:43 AM
