Old Oct 02, 2014, 12:19 AM
Joined Nov 2012
Originally Posted by oldsamer View Post
Why is "moment" used to describe the relative position of weights on a seesaw?
Moment = force X distance
2 pounds at 1 ft = 2 ft-lbs = 1 pound at 2 ft
On the seesaw, 100 lb at 6' = 600 ft-lbs moment = 150 lb at 4'
TennFlyer is offline Find More Posts by TennFlyer
Old Oct 02, 2014, 04:27 PM
Wamp's Avatar
Joined Mar 2012
Thanks, it is creeping back in
Wamp is offline Find More Posts by Wamp
Old Oct 11, 2014, 02:05 PM
GLHS592's Avatar
United States, TN, Nunnelly
Joined Aug 2012
I have a set of Eflite S75 servos and an Eflite Park 480 from my retired Mini Pulse XT. Would those servos work good with this plane?
GLHS592 is offline Find More Posts by GLHS592
Old Oct 11, 2014, 06:16 PM
Cherokee Flyer's Avatar
United States, KS, Rose Hill
Joined Sep 2007
Yep.
L.
Cherokee Flyer is online now Find More Posts by Cherokee Flyer
Old Oct 19, 2014, 06:53 AM
oldsamer's Avatar
El Paso
Joined Jan 2011
I've always been leery of using salvaged servos. Servos are mechanical and eventually wear out.
oldsamer is offline Find More Posts by oldsamer
Old Oct 19, 2014, 09:51 PM
Leawood, KS
Joined Nov 2010
Just got a G-Force G10 motor from Value Hobby, and mounted it into my Leader. A little higher KV than the Power Up 480 plus motor, and quite a bit more power. I got a bit of work travel now, so I'm not sure when it is going to go up, but before winter sets in, I hope. The 480 plus, is going to move to a Mini Pulse.
sjair is offline Find More Posts by sjair
Old Yesterday, 12:25 PM
United States, MA, Medfield
Joined Jul 2010
I looked up the G10 and it's specced at 140g which is I think a fair bit heavier than the PU 480 Plus.
Did you have to do anything to keep the CG correct?
-l2t
learn2turn is offline Find More Posts by learn2turn
Old Yesterday, 10:20 PM
Leawood, KS
Joined Nov 2010
G10 shows at 95 grams on Value Hobby. Weighed in at 111 grams on my scale. I haven't balanced, yet, but I got enough room for adjustment on the battery. Shouldn't be a problem.
Sold 3DHS 41" Blue Edge NIB + Eflite 480 Cabledawg1 Aircraft - Electric - Airplanes (FS/W) 5 Sep 03, 2010 12:58 AM
Question Thoughts on the Ultrafly P51D w/ Retracts lafuerza Electric Warbirds 3 Sep 01, 2010 02:16 PM
Discussion Should I try high Timing on a Eflite 480? Cabledawg1 Power Systems 4 Jul 19, 2010 01:16 PM
Discussion Can't replace shaft on Eflite 480? Lowezz Electric Motor Design and Construction 6 Apr 07, 2009 10:42 AM
Any thoughts on airfoil for 400/480 stuka with scale wing kit basher Power Systems 3 May 19, 2001 11:21 AM
